12volts Plug & Play remote start groupbuy!
Discussion in 'Audio & Video' started by T-Rex266, Jul 31, 2019.
  1. Sep 18, 2019 at 4:14 PM
    #691
    captain_bij
    captain_bij New Member
    Bijan
    15’ Tundra Crewmax Platinum 4x4
    Never mind, shipped! :thumbsup:
  2. Sep 18, 2019 at 4:28 PM
    #692
    Scottd818
    Scottd818 New Member
    2018 Quicksand Tundra Limited TRD 4x4
    Super easy install. Took me a whole 25 min. And thats with splicing 1 whole wire!!!
  3. Sep 20, 2019 at 10:03 AM
    #693
    Rockranger77
    Rockranger77 New Member
    Alabama
    19 platinum
    After sitting on the starter for a few weeks, finally got it installed on my 19. Had one issue that was my fault when doing the install. James was outstanding with the customer service and replied within minutes of my email and knew i had installed it improperly by my explanation of symptoms. Great product and exceptional customer service.
  4. Sep 21, 2019 at 8:41 PM
    #694
    MotoTundra
    MotoTundra The Ocho
    Don
    Decisions, decisions!
    Ted4311 and TheBeast like this.
  5. Sep 22, 2019 at 4:24 AM
    #695
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Installed mine yesterday in my 2010 “Dot” key. Took no more than 2 hours start to finish, and that included test fitting everything and then soldering in the 7 wires necessary for the Dot key install. If this kit were plug and play for my truck it would have taken less than 45 minutes to install.
    Note to others with ‘07-‘10 Dot keys (No letter “G” on your key, just a little dot): The ignition harness is still plug and play, but the rest of the kit is not. There are 7 wires that have to be tapped into various other connectors (OBDII, keysense, parking lights, etc.). Overall this was still a very easy install, and I would recommend it, but I just wanted to clarify that for anyone with those model years who is a little confused. Happy to answer any questions people have about the install on a 2010.
  6. Sep 26, 2019 at 4:03 AM
    #696
    Jersey Rugger
    Jersey Rugger New Member
    KJ
    Jersey
    2019 SR5 TRD off road CM, cement
    Just installed mine. EZ PZ. Hardest part was finding a good location for the unit to stay. Great deal, thanks again. I'm even more excited for hunting season now!
    GiantsFanDan and Ted4311 like this.
  7. Sep 29, 2019 at 10:36 AM
    #697
    Yzed608
    Yzed608 New Member
    Wisconsin
    Finally installed mine, pretty easy. Watched the video twice and read the instructions twice before starting, then referenced both during install. No issues at all. This is a 2017 'G' key, no glass break sensor, just the most basic version that works off of the OEM fob. I ended up tucking all the extra wires and the unit on top of what I think is the airbag unit (right in the middle under the steering wheel, what the OBII port is attached to).
    I did accidentally turn the key too far once so far past 'On/run' and hit the starter, truck shut off then went through the start-up procedure as if I started it remotely from the fob again, no issues after it started again.
    Also this was the first time I was able to hear the truck fire up from outside with the dirty deeds 10", I like it!
    I thought I read somewhere previously, but is there a way to shut the truck off with the fob too? Also haven't tested to see if it shuts down after 15 min idle, but I don't think I'll let it sit that long. Mainly bought this to warm the truck up/defrost windows in the mornings in winter. Thanks for the GB!
  8. Sep 29, 2019 at 4:42 PM
    #698
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    Once you 3 lock press to start. Press the lock 3 times and it will shut off
    GiantsFanDan likes this.
  9. Sep 30, 2019 at 4:47 PM
    #699
    Yzed608
    Yzed608 New Member
    Wisconsin
    Thanks, just tested it and it works.
  10. Sep 30, 2019 at 5:52 PM
    #700
    Big Jeff
    Big Jeff New Member
    Western Kentucky
    2015 TRD Double Cab
    Well you guys convinced to order one so I placed my order. I went with the lifetime warranty as well. I’m kind of reluctant after getting the warranty and looking around the website. I don’t see a physical address or phone # only James’s email. Am I the only one with a concern?
    jewsNbrews likes this.
  11. Sep 30, 2019 at 6:20 PM
    #701
    T-Rex266 [OP] Fuck Cancer Staff Member
    No. James is extremely reputable.
    RangerBP, jewsNbrews and AZTundra like this.
  12. Sep 30, 2019 at 8:46 PM
    #702
    19Platinum
    19Platinum New Member
    2019 Magnetic Gray Tundra Platinum
    Just ordered mine as well. Opted for the CL6 too. Looking forward to getting into a warm truck in winter and a cool truck in summer!
  13. Sep 30, 2019 at 9:02 PM
    #703
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    Every time I see this in the feed, I just want to buy it!!! Saving up for too many things !!!!
    This forum is the best/worst.
    Ted4311 and jewsNbrews like this.
  14. Oct 5, 2019 at 6:16 AM
    #704
    19greysport
    19greysport New Member
    2019 crewmax sport
    ok im installing in my 2019 today.what wire do i splice into and whats the program instructions? been searching and barley have internet.someone please simplify for me please.
  15. Oct 10, 2019 at 8:12 PM
    #705
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Just got mine installed. Works great. Thanks James!!
    Ted4311, AZTundra and Migraine like this.
  16. Oct 17, 2019 at 5:33 AM
    #706
    19greysport
    2019 crewmax sport
    just installed mine this morning. very easy!! great customer support. highly recommend. cutting one wire is nothing.
  17. Oct 19, 2019 at 4:30 PM
    #707
    Big Jeff
    Big Jeff New Member
    Western Kentucky
    2015 TRD Double Cab
    Installed on my 2015 TRD in one hour forty five minutes MOC'ed and tools put up.
    Had to read the instructions a few times and had to refer to the video a few times, Could use some improvement.
    If I have a unrelated electrical issue later I'm thinking I might have to disconnect everything and return to factory? Man I hope not. Thanks for the thread!
  18. Nov 3, 2019 at 1:21 PM
    #708
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    Hey folks,
    Just getting around to this now.
    2017 SR5. Installed according to video & programming instructions. It worked the first time after programming while sitting in thevtruck with the door open, then it won’t start now.
    I checked all connections, reprogrammed according to the fortin pdf. Now nothing.
    I’ve tried different cadences of the 3x fob press.
    What am I missing?
  19. Nov 4, 2019 at 9:36 AM
    #709
    Need an updated programming software. Mine did the same
    RangerBP likes this.
  20. Nov 4, 2019 at 9:39 AM
    #710
    RangerBP
    Thanks for the reply. James helped with troubleshooting, but no luck. I’ll reach out to find out more about getting it updated.
    T-Rex266[QUOTED][OP] likes this.
  21. Nov 12, 2019 at 10:20 AM
    #711
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Finally got around to installing in my 2017. I cant believe how easy it was. Thanks again James.
  22. Nov 12, 2019 at 10:54 AM
    #712
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    Has anybody sprung for the long range remotes? Can't decide if I want to add them or not.... I would like the option to start the truck beyond my line of sight.
  23. Nov 12, 2019 at 11:01 AM
    #713
    801Tundra
    UTAH
    That's a tempting option as well. How's it been working for you? I've heard mixed reviews; some complain about the reliability.
  24. Nov 12, 2019 at 11:04 AM
    #714
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    Carlink in my opinion
  25. Nov 12, 2019 at 11:24 AM
    #715
    TURK8875
    TURK8875 New Member
    SKIPPER
    Is the group buy over?
  26. Nov 12, 2019 at 11:28 AM
    #716
    YsoSeRiouS!
    NorCaL
    TURK8875[QUOTED] likes this.
  27. Nov 12, 2019 at 11:37 AM
    #717
    TURK8875
    TURK8875 New Member
    SKIPPER
    Thanks for your kindness
    YsoSeRiouS! likes this.
  28. Nov 12, 2019 at 2:07 PM
    #718
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    Ordered another one of these with carlink. Finally got fed up with horrendous factory remote start. Guess I'll have to dig in and get the factory one out.
  29. Nov 12, 2019 at 2:09 PM
    #719
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I opted not to get the carlink; is that something I can add later if I decide I want it?
  30. Nov 12, 2019 at 2:56 PM
    #720
    YsoSeRiouS!
    NorCaL
    You can add it later but his group buy for 135 is the last group buy for remote start aand carlink link mentioned in the header. I purchased the remote start in the first group buy then bought the car link with this group buy. My opinion I should have gotten both in the beginning so much easier to deal with and also being able to lock and unlock without being near the truck and gos tracking but that’s just my opinion. I also have a pop n lock so when I used my key fob I got annoyed with my actuator in the tailgate going off 3 times. Now I just starts and no actuator going off using the app
