The Hooks on the Front Skid Plate...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bergmen, Sep 29, 2019.
  1. Sep 29, 2019 at 12:23 PM
    Bergmen
    Bergmen [OP] New Member
    Ukiah, California
    ...and I had a little argument. So I bent them over out of frustration (never could get these both to line up and engage the slots).
    So I modified the two center mounting points as such:
    So I leave those two bolts in place, just loosened a little. Remove the other three (plus the three thread forming screws for the front bumper tabs), slide it forward and off. With the two center bolts in place, you can remove all of the rest of the fasteners without wrestling with the danged thing.
    To re-install, slip the front edge of the skid plate under the three bumper tabs, move it forward a bit and up to align the slots with the loosened bolts. Slide rearward and the two bolts will hold the skid plate in place while you install the rest of the three bolts, then the three thread forming screws for the bumper tabs.
    Eezee pezee.
    TreeCat, bleach, Trooper2 and 2 others like this.
  2. Sep 29, 2019 at 4:31 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    I wish it was a skid plate. I had to order my 17 DC after test driving a demo 2wd tundra. paperwork stated front skid plate and fuel tank skid plate. I was expecting hefty skid plates. These are more of rock/dirt undercarriage protection. Was a little disappointed when I got up underneath the truck.
  3. Sep 29, 2019 at 5:25 PM
    AK 6.7PSD Replacement
    AK 6.7PSD Replacement New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    RCI offers legit steel or aluminum plates with oil filter door access. Glad I got mine!
    HbbTundra08 and TXMiamiFan like this.
  4. Sep 29, 2019 at 6:39 PM
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    Really like the idea. The skid plate removal is the one thing I hate the most about changing the oil on the Tundra.
    RitcheyRch likes this.
  5. Sep 29, 2019 at 7:32 PM
    Bergmen
    Ukiah, California
    Yeah, me too (except for the oil filter mess). At 70 years old, I'm not as limber as I used to be and every bit helps.
    Pudge likes this.
  6. Sep 29, 2019 at 7:43 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Just had mine off for the first time when i did the undercoat,..What a PITA! Also snapped one of those plastic inserts that hold the bottom of the bumper secured, not a great design for something as simple as a shield.:facepalm:
  7. Sep 30, 2019 at 4:22 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I fought the stock plate and decided to upgrade to the TRD skid...I have had to fight it too. Best answer would have been to keep the stock plate and mod it with a door like some others have done.
  8. Sep 30, 2019 at 4:34 AM
    That's great but if you ever take it to a shop and they have to remove it, I would let them know. Those hooks support the weight while removing the bolts if you are doing it by yourself. I could see someone getting hit in the head.....:boink:
    JohnLakeman likes this.
  9. Sep 30, 2019 at 8:22 AM
    Bergmen
    Ukiah, California
    The mod is intended for the DIY folks. If one takes there Tundra in for service that requires removal of the skid plate, let them fight the hooks.
  10. Sep 30, 2019 at 8:24 AM
    Bergmen
    Ukiah, California
    I broke one of mine the first time I removed the skid plate also. It is a really poor choice of fastener. I bought a bag of replacements from the dealer and haven't broken one since.
  11. Sep 30, 2019 at 8:27 AM
    Bergmen
    Ukiah, California
    I was very close to doing the same thing (modifying stock plate with oil filter access hole). It's a bit of work to do that successfully and in addition, I value the removal so I can totally inspect the underside to make sure nothing needs attention (coolant leaks for instance).
    Crunch527[QUOTED] likes this.
  12. Sep 30, 2019 at 8:27 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I believe Toyota refers to it as a "Splash Plate".
    Many have cut a square hole in them to remove the oil filter. Not real difficult.
    15Yota likes this.
  13. Sep 30, 2019 at 3:14 PM
    Crunch527
    Iowa
    A lot to be said for keeping an eye out for leaks.
