37 wheel offset and size
Discussion in 'Wheels & Tires' started by Rubberdown, Sep 29, 2019.
  1. Sep 29, 2019 at 7:40 AM
    Rubberdown
    Rubberdown [OP] Spilling my guts here.
    i read lots, but didn’t see anything definitive. Currently running 35s on rock warriors. No Major trimming, no anything. When these go I think I want to get new wheels and go 37s.
    What is the recommended wheel offset for 37s? Would like to have the look and no rubbing just like everyone does. Should I go 17 or 18 for tire price and availability?
    Thanks fellas.
  2. Sep 30, 2019 at 6:50 AM
    Rubberdown
    No one? Come on dirty7 Peeps! I’m digging the 1552 traverse 17 inchers. They are plus 25.
  3. Sep 30, 2019 at 7:10 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    There is a huge thread about 37" tires. Several people chimed in with what offset they are running or had to change to in order to fit 37s. A 17x8.5 wheel will have a different offset than an 18x9 wheel to clear 37s.
    Also, if you are only on a 3" lift, be prepared to do some trimming.
    Sas likes this.
  4. Sep 30, 2019 at 7:12 AM
    Cfincke
    San Antonio
  5. Sep 30, 2019 at 8:24 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Unless you’re going LT or getting glass fenders, stay around +25. 0 offset is a pain in the ass to fit on MT.
    TheBeast, BestGen and BlackSheep like this.
  6. Sep 30, 2019 at 8:32 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    37s are gonna rub IMO no matter what offset you run. Compress the front hard enough and they'll hit the inner fender at the top. What front bumper do you have?
    ChargedToyo, BestGen and joonbug like this.
  7. Sep 30, 2019 at 8:38 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Like this. Smashed it hard enough to knock my battery off the hooks.
    YotaMan, BestGen, BlackSheep and 2 others like this.
  8. Sep 30, 2019 at 8:42 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Your photo just gave me a great idea. What if we cut the inner fender out, move it up and rivet/weld it back in an inch or 2 higher?
    BestGen and joonbug[QUOTED] like this.
  9. Sep 30, 2019 at 8:49 AM
    Rubberdown
    read the whole thing several times. Haven't seen a "this is the best offset" statement anywhere. I realize there are variables. Hence I'm asking. Thanks!
  10. Sep 30, 2019 at 8:50 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    On my brand new truck??? WTF? Is you crazy?? :p
  11. Sep 30, 2019 at 8:52 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Well, Yes! Yes I am.
  12. Sep 30, 2019 at 8:55 AM
    Rubberdown
    I read the whole thing multiple times. My questions weren't answered. Lots of stuff all over the place. I realize there are variables in tire sizes and wheels. I have a hammer and low self esteem so I will pound that truck till they don't rub don't worry.
    None right now. I had an ADD venom on my last one. Kind of want to keep stock bumper with one of those southern style offroad inserts and space it forward enough to clear. I have a plasma cutter, torch, a dremel with a cut off wheel, a grinder, and a hammer. I can make things fit.
  13. Sep 30, 2019 at 9:01 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Ok. Let's do it. :bananadance:
  14. Sep 30, 2019 at 9:03 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That's what you need. Cutting tools and commitment. Patience won't hurt either but not required. LOL
    dcsleeper408, BestGen and joonbug like this.
  15. Sep 30, 2019 at 9:03 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Since it's new, yours would end up looking really good.
  16. Sep 30, 2019 at 9:07 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I'm less worried about cutting out the inner fender and re-attaching as I am about relocating everything.
  17. Sep 30, 2019 at 9:14 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    @Rubberdown you can pretty much make anything work if your willing to cut and fab. What are the current specs? level kit correct? Below are the must-do items IMO:
    1. BMC. definitely help with turn radius and can fit the fatter tire
    2. Pinch weld mod. I haven't done it, but its on my list, will also help with opening up the wheel well a little bit. this will take the fender back about .5-1" if done correctly.
    3. Push that bumper forward. I snagged some washers from HomeDepot ($6 lol) and pushed the bumper about .5" forward. Makes a huge difference and you cant tell from the outside looking in, looks like stock
    4. Bumper trim. Sounds like you have all the tools you need. Pretty self explanatory
    You'll 100% need to stay away from negative offset (I don't think youre looking for a deep dish anyways) lol but youll have to be careful that the rubber isn't rubbing on any internals like the UCA. so the back spacing on the wheels are pretty critical. once you go to the wider tire, you're going to have a lot of rubber and sidewall
    btw, if you haven't seen it yet, this thread might help:
    https://www.tundras.com/threads/official-tundra-wheel-and-tire-setups-pics-and-info.95/
    From a guy that has ran a couple of "extreme" wheel/suspension ratios, do your research and figure out exactly what you want. Once you figure it out, do a little more research lol Then just pull the trigger and send it. Make more adjustments as needed. Worst case scenario, if you still rub, you'll learn the limitations of how much you can turn to mitigate. Once you get use to it, youll minimize the rub and still have a badass ride lol
  18. Sep 30, 2019 at 9:51 AM
    Rubberdown
    Yeah I’ll be on ads coilovers in front. Supposed to show up Wednesday. Mcm UCA have to be ordered. Do the resivoirs rub at full lock however ADS mounts them? My kings did.
    Yeah I was gonna just stack washer to space the bumper. No sense spending money on fancy plates. Might break down and buy something else. Shoulda kept the ADD bumper but I couldn’t find a stocker to put back in its place.
    Of course BMC, skid plate, and the fenderliners are already aggressively done for the 35s I have now.
    Looks like 17x8.5+25 wheels once I come to grips with spending money and sell my rock warriors.
  19. Sep 30, 2019 at 10:28 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The 35s didn't hit the resis. Didn't have the ADS w/ 37s.
