05 Limited Before and After
Discussion in '1st Gen Tundras (2000-2006)' started by Aiforever55, Apr 18, 2019.
  1. Apr 18, 2019 at 9:00 PM
    Aiforever55
    Aiforever55 [OP] New Member
    05 Tundra Limited 4x4 DC
    Been doing a few things little by little on my 05. Just got the Bilstein 5100’s all the way around and a toytect 1/2” top plate on the front. Put some Procomp 41 Phasers, 17x9, and 285/70-17 Nitto Ridge Grapplers
  2. Apr 18, 2019 at 9:07 PM
    NMTundra
    NMTundra New Member
    Looks great. What's the offset on those wheels and any issues with rubbing?
  3. Apr 18, 2019 at 9:14 PM
    Aiforever55
    Thanks! 12 offset. No issues so far. Haven’t got to drive it much, but rides great and drives awesome!
    NMTundra[QUOTED] likes this.
  4. Apr 18, 2019 at 9:21 PM
    NMTundra
    NMTundra New Member
    Yeah the 5100s have transformed my truck's ride for sure. Glad to hear you haven't rubbed, makes me more confident to try 285s when I buy tires next time.
  5. Apr 19, 2019 at 8:11 AM
    Aiforever55
    Yeah I think you’ll be stoked on them. Your truck looks good too!
  6. Apr 19, 2019 at 8:13 AM
    Outbound
    Aaron
    Northern Alberta
  7. Apr 19, 2019 at 8:19 AM
  8. Apr 19, 2019 at 9:14 AM
    NMTundra
    NMTundra New Member
    Thanks man, slowly getting it to where I want it!
  9. Apr 19, 2019 at 9:42 AM
    pollymath
    pollymath New Member
    2006 Limited DC 4x4 "Chunky Salsa"
    Mind you his wheels are 5mm outboard more than stock 17" wheels (+18 offset).
  10. Apr 19, 2019 at 5:42 PM
    NMTundra
    NMTundra New Member
    Yeah my XDs are actually a 0 offset so even further out. Suspension clearance won’t be the issue, might be trimming the mud flap.
    Aiforever55[OP] likes this.
  11. Apr 19, 2019 at 5:49 PM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Rad truck to start with.....even more rad after the transformation!
  12. Apr 19, 2019 at 5:52 PM
    Aiforever55
    Yeah I was looking at the wrong wheel size when I found 12, my wheels actually have a 6 offset. I don’t need to do anything to the mud flaps the way it sits now. I did remove the front ones before I put the lift on.
  13. Apr 19, 2019 at 5:53 PM
    Aiforever55
    Thanks! Got plenty more to do but for now I’m stoked with how it’s coming along!
  14. Apr 19, 2019 at 6:07 PM
    Well done!!
  15. Apr 19, 2019 at 10:10 PM
    NMTundra
    NMTundra New Member
    Yeah I've been kicking around the idea of removing them anyway. It's a mall-runner so not like I'm really saving any rock chips by keeping them.
  16. Sep 27, 2019 at 8:49 PM
    merbesfield
    merbesfield New Member
    I have the same truck and also have the 5100's installed. Next step is the wheels and the ones you have installed are one of my choices so great to see how they look. Did they change the ride going w bigger tires? Also, can you confirm the size of your wheels? There is some confusion in the posts as to exactly what size they are. Thanks for posting.
  17. Sep 27, 2019 at 8:57 PM
    Aiforever55
    The wheels are 17x9, and yeah the ride changed a little but not to much. The truck drives perfect. Haven’t had any issues since I did the work. Still loving this setup.
  18. Sep 27, 2019 at 9:15 PM
    merbesfield
    How would you describe the change? Slower? More nimble? Less nimble? I had an Acces cab which I loved. So I decided I would love the DC and ordered it with 20” wheels. Was really disappointed bc it drove completely different and much slower than the AC I came out of. I’m hoping that going down in tire size my liven my truck up some. The wheels I have now are 20”x9”. A lot of rubber on the road.
  19. Sep 28, 2019 at 8:23 AM
    Aiforever55
    I’m not really sure how to describe it. When I bought the truck it had old soft suspension and stock tires, it drove soft I guess. Not sure the difference because I’ve never had the AC but I love my truck and am super happy with everything I did to it.
    merbesfield[QUOTED] likes this.
  20. Sep 28, 2019 at 8:48 AM
    merbesfield
    Thanks. My truck is at shop now getting front differential rebuilt. Bad Spider Gears. When I get it back I will make a decision on wheels and tires.
  21. Sep 28, 2019 at 9:49 AM
    Aiforever55
    Right on. I’m sure you’ll be stoked with whatever you go with.
  22. Sep 28, 2019 at 2:56 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    What notch on the Bilsteins and whats the reason you did the ToyTec plate?
  23. Sep 28, 2019 at 3:16 PM
    Aiforever55
    I believe it’s on the 1-3/4” notch (not entirely sure since I didn’t personally install them) and after doing research on the tire size I wanted most had said to avoid rubbing I’d need a little extra lift. I’m happy I went with it, it’s the perfect height and I have zero rubbing
