Super Glue-Gel for filler?
Discussion in '1st Gen Tundras (2000-2006)' started by marbleville, Sep 27, 2019.
  1. Sep 27, 2019 at 2:48 PM
    marbleville
    marbleville [OP] Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    Several weeks ago I removed a couple gnarly patches on my rear wheel flares using a heat gun and plastic razor-like blades, and in doing so I gouged-out a small chunk of material creating a crater. I have procured the correct touchup paint and a can of Dupli-Color Plastic Adhesion Promoter for the job and I've been wondering about the filler for that one little crater. Somewhere, beats me where, I heard you can use super glue to fill little craters. Because it is on a vertical surface, I have moved to super glue gel for its ability to stick without flowing as gravity plays on it. What is the consensus here, will this work as planned? Does super glue gel meet the requirements and weather-worthiness that is needed for this purpose? Of course it will eventually be sanded and painted to match its surrounding area.
  2. Sep 27, 2019 at 2:50 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    :popcorn: Have a similar situation
  3. Sep 27, 2019 at 3:23 PM
    Rubberdown
    Rubberdown Spilling my guts here.
    Don’t do that. It’ll f it all up. How deep is the gouge?
    Tundyfundy likes this.
  4. Sep 27, 2019 at 3:40 PM
    marbleville
    Yep, last name too.
    State of Confusion
    No more than 1/8" deep. Curious as to why you state it will F it up? The cheap-ask Scot in me doesn't want to buy a filler, as they are sold in such a large size for my tiny needs, and I have a new tube of SG-gel.
  5. Sep 27, 2019 at 3:43 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I would do a bondo putty type product for plastics...good to see you’re getting on the projects!! Good luck Tundra brother.
  6. Sep 27, 2019 at 4:12 PM
    Rubberdown
  7. Sep 27, 2019 at 4:15 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    FWIW. I used epoxy and let it cure for a day clamped and the crack came right back. Super glue ain't going to stick
  8. Sep 27, 2019 at 4:39 PM
    marbleville
    Yep, last name too.
    State of Confusion
    Ha, ha! FWIW...I asked the question after applying super glue gel about four days ago. It has hardened, shrunk, and appears permanent; I would have to chip it out of the crater were I to go with another filler (not that I am opposed to that, should a better alternative present itself). Now before anyone says I put the cart before the horse, which appears so, I went with what I had read previously and only today have examined the outcome and noticing the shrinkage. I'm not too happy with the SG-gel and I'll probably remove it and use another filler, but I am waiting on advice to form my plan to proceed. So far the advice given by Rubberdown sits well with me, though I am still fence sitting for the moment.
    Even with the web's help, I am still at a loss as to the flare's material of construction - is it polyurethane, or what. I spent many hours over two days searching this out and getting nowhere, and that, plus the previous info alluded to about using super glue, decided me to go that route. What successfully bonds with what, and what is it I am trying to bond to? Cat chasing it tail comes to mind.:notsure:
    Luckydog and Tundyfundy like this.
  9. Sep 27, 2019 at 4:42 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Yea, sometimes I look for the originals and then the cost of painting. Hell might as well buy 4 new ones cuz you can only buy the set unless you get lucky at the junk yard :rolleyes: You're going to have to spend serious ass time on screwing around with it to be perfect. It's a replaceable plastic part.
  10. Sep 27, 2019 at 4:43 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I would go with JB Weld over Superglue gel. If you mix the JB Weld just right you may be able to match the truck color :D
  11. Sep 27, 2019 at 4:50 PM
    AZTundra
    Paul
    Phoenix, AZ
    Maybe you can just use some spot putty / glaze for filler then sand it? It's cheap at about $5.00. Not sure if this is only for small pinholes or if it can also be used in larger chips/gouges like yours. Maybe others can chime in on that.
    • Great for filling pinholes in body filler
    • Can be sanded and painted
    Bondo Glazing & Spot Putty
    Bondo Glazing & Spot Putty is easy to use, dries fast and stays durable without shrinking, ideal for filling pinholes in body filler and covering auto body scratches, paint chips and minor dings. This 1-part nitrocellulose putty dispenses easily and efficiently right from the tube with no mixing, affords a 3-minute working time and is sandable in 30 minutes for fast, efficient repairs.
    Big Benefits for Smaller Auto Repairs
    Applied directly from its easy dispensing tube, Bondo Glazing & Spot Putty is formulated for quality auto body repairs in less time. Its 1-part nitrocellulose formula eliminates mixing and helps to keep small vehicle repairs simple, efficient and on schedule. Unlike many 2-part putties which can require longer to dry, Bondo Glazing & Spot Putty is sandable in as little as 30 minutes. It is non-staining, so it won’t affect the color of paint or finishes around the repair area. It also shrinks very little over time, helping to ensure lasting repairs without rework.
  12. Sep 27, 2019 at 5:04 PM
    marbleville
    Yep, last name too.
    State of Confusion
    So far three possible candidates...but how well do they adhere to polywhatever plastic? Or is it ABS? That is also why I went with the super glue, as I knew from experience that it will bond with all the plastics I can recall using it on.
    Hmmm...While typing the above, it occurred to me that I have another glue sitting in my freezer that has super qualities and bonds to about anything and that is Aquaseal, a urethane glue that cures almost diluted milk colored. Question is, can it be sanded? Will it take paint? I think I will thaw it out and do a test to determine both answers, while mulling over the suggestions you guys have given me.
  13. Sep 27, 2019 at 6:49 PM
    marbleville
    Yep, last name too.
    State of Confusion
    It seems that it may NOT be the answer I am looking for...
    It is not recommended for body filler to be applied over plastic bumper covers. Most bumper covers are made from a thermo plastic TPO or PP. This type of plastic has a problem with things adhering well. Body filler is designed for steel, galvanized steel, zinc coated steel, SMC, fiberglass, and aluminum..
    www.collisionblast.com › 2016/12/08 › can-body-filler-applied-plastic-bum...
    Of course they are talking about bumper covers, but I wonder if it is applicable to the wheel flare. Again, not knowing its material composition make it hard to feel confident about the choice one has before them.
  14. Sep 27, 2019 at 7:45 PM
    marbleville
    Yep, last name too.
    State of Confusion
    JB Weld may have an answer for plastic...
    https://www.amazon.com/J-B-Weld-501...009EU5ZM0/ref=cm_cr_arp_d_product_top?ie=UTF8
    But if it is an epoxy...? Someone, 7.62Tundra I think, suggested epoxies don't work well. Hmm. Still this may be the one I am looking for, though it would be nice if there was someone to vouch for it before I commit. One saving grace for me - it is a very small area that needs filling, so if one way doesn't work it won't be too difficult to reset and change to another material.
  15. Sep 28, 2019 at 6:17 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    marbleville[OP] likes this.
  16. Sep 28, 2019 at 7:24 AM
    marbleville
    Yep, last name too.
    State of Confusion
    Thanks for the tip and the link. I read the review and it does sound promising, but there was no answer provided for my unspoken question of how does this epoxy hold up in an outside environment where it can rain off and on for 6 months or more? I plan to look a little deeper to see if I can get some word on whether or not it is waterproof.:rain:
  17. Sep 28, 2019 at 7:53 AM
    marbleville
    Yep, last name too.
    State of Confusion
    Sleepless, I spent about 5 hours pre-dawn looking for info on the super glue being used as a filler in minor auto body correction and finding none. Oh, it is a great filler for wood and plastic and porcelain, so long as its indoors. But even Loctite dot com walked a fine path around waterproof, while saying it is water resistant. I need more than that, I need an assurance that it is waterproof when used per my plan. It doesn't look like it is up to snuff, but I did email Loctite's consumer division seeking an answer to my questions. It would be so easy to use that gel, as it is half filled already and needing one last fill and screed to be ready for sanding. Hopefully by early next week I will have settled on choices #2 and #3 while expecting word from Loctite on #1.
    In the meantime I have a full set of wheels that need some serious denastification* and paint.
    *I just coined the word denastification, the act of making something less nasty, and I claim all copyrights. Should you wish to use the word in the future please send me an email so we may talk about the royalties. Be prepared by bringing some big bucks to the table. I sense the need for a new turbocharger.:turtleride:
  18. Sep 28, 2019 at 8:14 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    I haven't used the JB Weld for plastic but I did use some JB Weld regular on a 1990 Honda Fourtrax rear axle and hub where the splines were starting to strip. It held up great in the mud and water. When I needed to take the hub off 15 years later I had to use a torch to heat the hub and melt the JB Weld to get the hub off.
  19. Oct 18, 2019 at 12:33 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
  20. Oct 18, 2019 at 1:01 PM
    marbleville
    Yep, last name too.
    State of Confusion
    I believe the baking soda simply quickens the "set" time to minutes. Seems to have quite a following for indoor projects.
    Super glue gel alone, when applied to an exterior surface exposed to weather (rain) seems to hold up well, but it shrinks a fair amount and cracks far too much. Although the depression I wish to fill is small, the shrinkage makes the gel a non-contender. I will be going with J-B Weld Plastic Bonder as it works with various plastics. Just waiting for the rains to stop and temps to rise above the mid to high 40s.
    https://www.amazon.com/gp/product/B009EU5ZNO/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
  21. Oct 18, 2019 at 1:08 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    He said is friend repairs helicopter blades using that technique. Sandable too
  22. Oct 18, 2019 at 1:24 PM
    marbleville
    Yep, last name too.
    State of Confusion
    I'm sure it works fine in that application where shrinkage may not be a concern. The problem I see, and which has been addressed in my research, is the shrinkage. Whereas visual appeal may not matter to the helicopter blades, it does matter a great deal in body work. I would be remiss were I to use a filler that shrunk after all the sanding priming, painting, etc., leaving the telltale visual of the patch. Therein lies the appeal of the Plastic Bonder which is reported to have next to no shrinkage. Apply, and finish, knowing it will blend in.
  23. Oct 18, 2019 at 1:28 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Understand. I just ran across the vid and remembered your thread. It's an interesting trick that I'll put in my files for the next time I try to fix something.
  24. Oct 18, 2019 at 1:33 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Use a plastic bumper repair or filler
    https://www.amazon.com/J-B-Weld-501...r&qid=1571430763&sprefix=plastic+bumpe&sr=8-4
    Boerseun likes this.
  25. Oct 18, 2019 at 1:41 PM
    Professional Hand Model
    Fred
    Hand Protectors
    If you lived closer, then I’d gladly turn you on to a squirt of some organic based 2-part epoxy that would work perfectly. It bonds to anything, tools nicely, and contracts/expands with all/any substrates. Only drawback is that it doesn’t sand easily like Bondo, but if you are good with your hands and have the proper technique/tools it doesn’t need sanding.
    I’d post the product, but the buy-in for the product and special applicator gun is not feasible for a one time use.
  26. Oct 18, 2019 at 1:41 PM
    marbleville
    Yep, last name too.
    State of Confusion
    @SoCalPaul ...Yes. As noted above in tan color. Your's being the same in black.:thumbsup:
  27. Oct 18, 2019 at 1:45 PM
    marbleville
    Yep, last name too.
    State of Confusion
