Can someone advise exactly what I need to purchase if wanting to level/lift 3” using Bilstein 5100?
Discussion in 'Suspension' started by Ephesus, Sep 19, 2019.
  1. Sep 19, 2019 at 11:15 AM
    Ephesus
    Ephesus [OP] New Member
    Jared
    2019 Tundra SR5
    Yes, I’m extremely ignorant on this. I’ve read for days this and that regarding leveling and lifting but it’s still feels like someone is talking to me from the bottom of a well with all this info.
    I drive a 2019 Toyota Tundra 2wd and I’m wanting to level it and lift 3”. It seems the recommendation that I want to go with is the Bilstein 5100. But I’m unsure as to what kit this will be and if I need to purchase anything else to make the package complete. If anyone can provide a link and info it would be greatly appreciated. Trying to figure this on my own has gotten me nowhere. Apologies for the stupidity.
  2. Sep 19, 2019 at 11:16 AM
    gdog_Tundra
    gdog_Tundra New Member
    VA
    2016 Limited CrewMax
    3 inch ToyTec coilovers, Dakar Leaf pack, Dirty Deeds 8 inch stainless exhaust, LED DRL headlights
  3. Sep 20, 2019 at 8:18 AM
    Lobodog1
    Lobodog1 New Member
  4. Sep 20, 2019 at 9:42 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    With your truck being a 19' a 3" lift up front needs to be paired with about 1.75" in the rear. this will allow your TSS system to work at 100% also help with handling and weight distribution. We will gladly help get your truck perfect. feel free to call in anytime and will go over in better detail.
    Ekstrom Design.
    801.635.4872
    https://www.shopcoachbuilder.com
    Migraine, 619Tundra and D4x4TRD like this.
  5. Sep 20, 2019 at 10:42 AM
    StrmTroop29
    StrmTroop29 New Member
    Anthony
  6. Sep 20, 2019 at 10:54 AM
    ricsha
    ricsha One is none, two is one.
    Rich
    Oregon Coast
    2019 Tundra Limited TRD
    Go with David's advice. You can't go wrong with shackles, etc., from Ekstrom Design. He won't steer you wrong!
    Coachbuilder1[QUOTED] likes this.
  7. Sep 24, 2019 at 7:07 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Check out my build thread... VVV
    Rica25 likes this.
  8. Sep 25, 2019 at 11:49 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    5100 all around
    1 coachbuilder shim for drivers lean
    +3 coachbuilder shackles
    Coachbuilder brake line and abs extension
    Upper control arms (if you’re doing 5100 you most likely will go with ball
    Joint Upper control arms. They are easy to maintain and last longer than SPC uniball)
  9. Sep 26, 2019 at 12:21 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    You throw a question like this into the fray you will get everyone’s personal preference.. let’s try to hone this in on what will actually be BEST FOR YOU. Help this thread out with the following:
    • What’s your budget to spend on parts?
      • Don’t forget about labor if your not confident to install yourself.
        • 5100s are not fun to do solo with a manual spring compressor which you would have to buy or rent if doing yourself.
    • What do you plan on using your truck for?
      • pavement queen, occasional trail runs, or...
    • What wheels/offset you planning on running and with what size tires do you want?
      • Perhaps some sample pics of Tundras that inspire.
    I would agree that some UCAs are likely required for 3” lift. Depending on your answers to the above, different UCA options should be considered.
    Cheers, and good luck!
    Migraine likes this.
