Remote res on rear of 1st gen
Discussion in '1st Gen Tundras (2000-2006)' started by Limu, Sep 23, 2019.
  1. Sep 23, 2019 at 8:31 PM
    Limu
    Limu [OP] New Member
    Alan
    2001 Tundra white
    Donahue coilovers front, Fox rears. Deaver 10 leaf pack
    was wondering if anyone has photos of where they mounted remote res on rear of first gen Tundra. With the offset shocks they are on different angles for each side. Or was there an easy way to mount them parallel to the axle? Guess my OCD has gotten the best of me. Lol. First priority is for them to be safely away from tires, but wanting to see if anyone got them facing the same direction.
    Thanks
  2. Sep 23, 2019 at 8:47 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
  3. Sep 23, 2019 at 9:05 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  4. Sep 23, 2019 at 9:42 PM
    Limu
    Alan
    2001 Tundra white
    Saw that Archive garage setup. Just ordered their u bolt flip to increase bumpstop height. After I ordered I notice Wheelers has one for about half but doesn't include the flip. Have had these Fox shocks sitting around for a month waiting to figure out the best way to go about this. Don't have a welder so the archive deal would take my truck out of commission for awhile and it's what I use to go to the beach and work.soooo... still thinking there is a way to bolt them rr's up as is and may just have them facing opposite ways.
  5. Sep 24, 2019 at 3:16 AM
  6. Sep 24, 2019 at 3:50 AM
    KarmaKannon
    Utah
    Some junk
    From the link "The purpose of this kit is to help you squeeze longer shocks under the bed to gain droop travel without losing ANY bump travel, for Spring Over Axle (SOA) Tundras. "
    Darkness and FirstGenVol[QUOTED] like this.
  7. Sep 24, 2019 at 6:28 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Exactly what shocks are you working with? What's the length collapsed vs extended? What springs are you running?
    I run an Alcan set and the closest fitting shock I could find was 2" Fox or SAW with 10" stroke but even then bottoming out and overextending is possible. No resi though.
  8. Sep 24, 2019 at 9:50 PM
    Limu
    Alan
    2001 Tundra white
    I am using Fox 2.5. Model 883-24-004. Ext 23.97 col 15.2. Using Archive garage U bolt flip with Wheelers superbumps and possibly a spacer to get 1inch ext. on rear bumpstop. The Foxes are for a 4Runner so bushing swap is needed as well as bumpstop ext of 1 inch. I have Deaver 10 leaf pack so the new shocks should be able to use the increase in travel. It's not 12 inches like the Archive relocate. But should be way better than a he Bilsteins I've been rockin since 2001. Lol. In the front I have Donahue 2.5 no res.
  9. Sep 24, 2019 at 9:51 PM
    Limu
    Alan
    2001 Tundra white
    I should be able to use factory brake lines with this setup as well.
