  1. Sep 22, 2019 at 10:43 PM
    #9931
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    hey @Casper421 Could you do me a huge favor and measure the pocket in your center console that has the 2 switch blanks. the console i got is missing it, not sure it had the pocket with switches or without. or if it even matters
    need to relocate the airbag off switch.. wondering if i can rewire it to this switch. which will fit in that pocket youre truck has
    https://www.ch4x4.com/product/ch4x4-toyota-push-switch-air-bag-onoff-symbol/
  2. Sep 23, 2019 at 4:50 AM
    #9932
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
  3. Sep 23, 2019 at 4:58 AM
    #9933
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Well I broke down and paid Car Toys to fix my.radio and back up.cam.situation...
    Turns out when I ran the amp.bypass harness to the rear seat, I snagged a wire on the passenger front kick panel, it grounded and shorted out the radios amp. So I bought a floor model radio and had em.install it and get the cam working properly. I can't.believe my luck. The old radio still works, it'll just require an amp to power the speakers. I'll hold onto it for if/when I find a 2nd vehicle.
    Pinay, tacoguybill, bmf4069 and 2 others like this.
  4. Sep 23, 2019 at 5:32 AM
    #9934
    Casper421
    In the woods
    06 DC
    I’ll get you some measurements later today.
  5. Sep 23, 2019 at 5:59 AM
    #9935
    :rofl::rofl::rofl::rofl:
  6. Sep 23, 2019 at 6:09 AM
    #9936
    speedtre
    speedtre New Member
    Inland Northwest
    Looks pretty good, but the brights seem like they may be a bit too focused and not throwing a wide enough pattern....does it seem that way driving it?
  7. Sep 23, 2019 at 6:12 AM
    #9937
    Yes a bit, but I rarely get to use my bright lights around here so I've not had a chance to use them much. The jury is still out on these. I like the color better but I don't know that these are any brighter than the halogens I had in place. Since I accidentally ordered the Katana headlights too, I'll test those next. Hand Model raved about them so we'll see if he was right.
    tacoguybill and speedtre[QUOTED] like this.
  8. Sep 23, 2019 at 6:14 AM
    #9938
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    295/75/16 on SCS Ray 10 16 x 8 -12 offset. I have ordered some superbumps from wheelers and once I have those on I'll flex test it again and see what is left to remove. So far, some from bumper material and the pinch weld have been trimmed. Might have to cut into the rear portion on the fender flare and quarter panel to fully clear at max travel.
    because_wumbo-truck likes this.
  9. Sep 23, 2019 at 6:16 AM
    #9939
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    o_O:bananadance:
  10. Sep 23, 2019 at 6:35 AM
    #9940
    speedtre
    speedtre New Member
    Inland Northwest
    Yea, he loves those. If your results echo his and the high beam pattern is wider, that will probably be enough to make me take the jump...
    00TundraZ likes this.
  11. Sep 23, 2019 at 7:11 AM
    #9941
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Not much smaller than my 315 70 17. I had to do a bit of cutting into my fireawll. Hopefully you don't have to do that because it's not extremely fun. I also rub my rear flares. I still need to fix that. That's a good looking setup you have anyway.
    TX-TRD1stGEN likes this.
  12. Sep 23, 2019 at 8:26 AM
    #9942
    Casper421
    In the woods
    06 DC
    Have any pics of where and how you cut your firewall?
  13. Sep 23, 2019 at 9:08 AM
    #9943
    KarmaKannon
    Utah
    Some junk
    I just snapped this one. I think it kinda shows what I did. Mostly I just cut, hammered, bent, and then filled some sections with 18g sheet. I tacked what I could and used construction adhesive to seal it. This is about a year ago and it seems to be lasting alright. I don't really have clearance issues on the back side since I pushed my hub 1" forward and 3.5" out.
  14. Sep 23, 2019 at 11:17 AM
    #9944
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    ...certainly a very uptight fellow, not that I haven't had the same feeling on occasion. One of the keys to adding on the years successfully is to try and find humor in day to day moments as you can, because there are way too many depressing events, otherwise. As an alumni of the fictitious Don Rickles School of Charm and Diplomacy and adherent to Jonathan Winters philosophy of always meeting life with a big shtick, I must admit to seeing things in a view different than my peers, and the youngsters that are everywhere. No need to be anal all the time works for me...my advice, roll with it. With respect.:rain:
    Darkness, Filthyphil, bmf4069 and 2 others like this.
  15. Sep 23, 2019 at 12:11 PM
    #9945
    Casper421
    In the woods
    06 DC
    I think we’re finally rubbing off on you; I only had to look up one word from that post. :anonymous:
  16. Sep 23, 2019 at 12:21 PM
    #9946
    Was it Anal? Don't google that one.
  17. Sep 23, 2019 at 12:59 PM
    #9947
    marbleville
    Yep, last name too.
    State of Confusion
    I'll let you in on a secret - I had to look up the correct spelling of shtick. And I typically have Google open when I write, so as to use the correct word form, etc., and it is not unheard of for me to have to look up the meaning of words as I read.:pccoffee:
    Darkness and Casper421[QUOTED] like this.
  18. Sep 23, 2019 at 1:46 PM
    #9948
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    The firewall isn't going to be an issue for me because of my narrower tires. I am really hoping the super bumps fix the issue. Other than the rubbing the Icon setup did awesome down in the desert. Much smoother than the Bilsteins and I could tell the difference in traction because of the additional travel. Thanks, I love my truck!
    KarmaKannon[QUOTED] likes this.
  19. Sep 23, 2019 at 3:19 PM
    #9949
    Wow. That was the laugh I needed to get me through 3 hours of cal II after 10 hours of work. Thanks guys! :goingcrazy:
    marbleville and Casper421 like this.
  20. Sep 23, 2019 at 9:53 PM
    #9950
    ColumbiaGorge
    ColumbiaGorge New Member
    Joe
    Columbia Gorge
    24 Limited
    Bought the AJT fob for no reason other than pocket flare.
  21. Sep 23, 2019 at 10:04 PM
    #9951
    empty_lord
    05 rollover special
    I need to get one of these when I
    Finally get a aftermarket fob
    That decides to work
  22. Sep 24, 2019 at 7:21 AM
    #9952
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Spent the evening reading about our braking system, prepping to do my booster and drums.
    bmf4069 and tacoguybill like this.
  23. Sep 24, 2019 at 7:27 AM
    #9953
    I tried to order one of these but they don't make them for the 02's!! :annoyed:
  24. Sep 24, 2019 at 8:12 AM
    #9954
    empty_lord
    05 rollover special
    body shop jammed it. Should be done within the next week
    [​IMG] [​IMG] [​IMG]
    Mr. Pink, Pinay, bmf4069 and 6 others like this.
  25. Sep 24, 2019 at 8:17 AM
    #9955
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    definitely eager for the Katana review!
    speedtre likes this.
  26. Sep 24, 2019 at 8:30 AM
    #9956
    empty_lord
    05 rollover special
    Do I do second gen emblems in black or do I do 1st gen emblems and paint them black..
    Thinking tundra on the doors too (to break up the grey since I don’t have side mouldings)
  27. Sep 24, 2019 at 8:38 AM
    #9957
    I like the 2nd gen emblems a lot better personally. More modern. I've seen one other 1st gen use updated emblems and it looked good.
  28. Sep 24, 2019 at 9:13 AM
    #9958
    empty_lord
    05 rollover special
    It’s the route I’m leaning
  29. Sep 24, 2019 at 9:45 AM
    #9959
    MrDirtjumper
    Josh
    Slam Angelo, Texas
  30. Sep 24, 2019 at 9:54 AM
    #9960
    antwon412
    antwon412 New Member
    2006 CC SR5
    Anyone have a lead in a shop in Northern CA around Yuba city that can give a good price on the timing belt job? Cheapest I’ve been quoted so far is $950
