2017 Tundra 5.7 oil pressure normal?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Dukenukem, Dec 27, 2018.
  1. Dec 27, 2018 at 2:53 PM
    Dukenukem
    Dukenukem [OP] New Member
    DUKE
    2017 Tundra XP SR5
    Just bought a 2017 Tundra 5.7 with 7k on it. As the video shows, the oil pressure takes a few seconds after starting to register, then it jumps to about 3/4. As idling drops so does oil pressure. When accelerating pressure increases to about 3/4. Does this look normal?
    https://youtu.be/L_K66VAgP_g
  2. Dec 27, 2018 at 3:06 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    That's normal.
    kparrow likes this.
  3. Feb 3, 2019 at 10:34 AM
    ifishinxs
    ifishinxs New Member
    Bob
    Cedar city, Utah
    2015 Tundra limited
    None! I tow a boat weekly
    Just like mine.
    kparrow and rodm1 like this.
  4. Feb 3, 2019 at 10:44 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Normal, 08....identical behavior
  5. Apr 8, 2019 at 6:18 AM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    My oil pressure is running slightly lower, about 1/16 below the 1/2 mark at idle and normal driving , is this normal?
    kparrow likes this.
  6. Sep 23, 2019 at 11:31 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep
    kparrow likes this.
  7. Sep 23, 2019 at 11:39 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Normal
  8. Sep 23, 2019 at 12:00 PM
    jml403
    jml403 New Member
    Georgia
    2017 SR5 4x4 Crewmax
    I bet this post will cause at least 20 people to check their oil, and watch their oil pressure on the drive home, including me.
  9. Sep 23, 2019 at 6:45 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I try to glance at mine now and then. I had a Chevy once and about 20 miles down the road after an oil change the pan plug came out. Turned off immediately. Put in neutral and coasted off the hwy.
