Gears on TRD Pro
Discussion in 'General Tundra Discussion' started by DM 2018 Tundra, Sep 23, 2019.
  1. Sep 23, 2019 at 2:07 PM
    DM 2018 Tundra
    DM 2018 Tundra [OP] New Member
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    My buddy picked up a TRD pro. He will use it to pull his camper and boat with. After looking at it he has a 410 gears and mine has 430. Dumb question I know but why? Is the TRD pro made to pull more weight correct? Why is the gears different? Higher the number means lower gear? Thanks we was just wanting to know.
  2. Sep 23, 2019 at 3:10 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Unless something changed, all 4x4 Tundras have 4.30. Seeing that a TRD Pro is obviously 4x4, it should have 4.30.
    The Pro isn’t made to pull more weight, it is designed to have a more off-road worthy suspension (Toyota’s version of a Raptor)
    snivilous, Rica25, jewsNbrews and 3 others like this.
  3. Sep 23, 2019 at 3:12 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Ok thanks. His paper work said 410. Guess he needs to call his salesman.
    Rica25, jewsNbrews and 15whtrd like this.
  4. Sep 23, 2019 at 3:12 PM
    Rica25
    Ricardo
    Tulare
    NBA? All 5.7 litres have 4.30 gears
    15whtrd likes this.
  5. Sep 23, 2019 at 3:16 PM
    DM 2018 Tundra
    2018 Limted Tundra
    86557D0B-18CE-4BDB-BEC2-F3E3BD3BA03F.jpg Here is another TRD on the lot also has 410.
    Rica25 likes this.
  6. Sep 23, 2019 at 3:16 PM
    DM 2018 Tundra
    2018 Limted Tundra
    I thought remembering reading on here was 430. But 19 guess have 410
    Rica25 likes this.
  7. Sep 23, 2019 at 3:18 PM
    15whtrd
    15whtrd Mr. Blonde
    If your buddy is going to be towing with it he may want to address the rear springs for the extra weight. Not that it can haul any less but it will give it some rear end squat since it doesn’t have the typical rate of a standard stock pick up truck. He could do airbags, timbrens or even an add a leaf or upgraded leaf springs.
    Rica25 likes this.
  8. Sep 23, 2019 at 3:18 PM
    15whtrd
    15whtrd Mr. Blonde
    If that’s true, that’s weak AF
    TRD15559 and Rica25 like this.
  9. Sep 23, 2019 at 3:24 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Thanks. I have Timbren on mine and he just ordered some last night. He is kinda pissy now cause he thought he had 430. Lol. I also looked at getting a TRD pro a white one but if the gears are different probably not. But with a 410 he should be fine beside the 430? Thanks again for the help
    Rica25 likes this.
  10. Sep 23, 2019 at 3:26 PM
    DM 2018 Tundra
    2018 Limted Tundra
    From his paper work the trailer weight is 9800 mine is a limited and it’s 8900. He also was told that it had Denver??? Springs in the rear to tow/haul more weight
    Rica25 likes this.
  11. Sep 23, 2019 at 3:29 PM
    DM 2018 Tundra
    2018 Limted Tundra
    My dealership is trying to get me trade mine in on a TRD pro due to the salesman lied and now they fired him. Not because of me!!! They fired him 3month before i came back in with some issues.
    Rica25 likes this.
  12. Sep 23, 2019 at 3:32 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I remember seeing something about tundras with the towing package get 4.30 and without 4.10. Maybe that has changed.
    15whtrd and Rica25 like this.
  13. Sep 23, 2019 at 3:57 PM
    Rica25
    Ricardo
    Tulare
    I would ask them to run the VIN and make sure of the proper ratio
    15whtrd likes this.
  14. Sep 23, 2019 at 5:03 PM
    DM 2018 Tundra
    2018 Limted Tundra
    The vin on paper work matches the truck vin.
    Rica25 likes this.
  15. Sep 23, 2019 at 5:17 PM
    Rica25
    Ricardo
    Tulare
    15692841155096954003149063780832.jpg 15692841589084922956789864811662.jpgthis is building one on the Toyota website has the 4.3 on the Tundra Pro
    15whtrd likes this.
  16. Sep 23, 2019 at 5:24 PM
    Rica25
    Ricardo
    Tulare
    410 is not an option as soon as it's the 5.7 its 4.30 the 4.6 liter has 4.10
    15whtrd likes this.
  17. Sep 23, 2019 at 5:40 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Dude thanks!!!! I am going to send it to him. I am also going to look and see the picture I sent earlier was a 5.7. Thanks
  18. Sep 23, 2019 at 5:45 PM
    DM 2018 Tundra
    2018 Limted Tundra
    I pulled up the last picture I sent and it says 5.7FBD12948-9ECE-4D8C-AB6A-60BADE230BFE.jpg
    Rica25 likes this.
  19. Sep 23, 2019 at 5:46 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Went to the website and looked. All of the TRD pro has 410. Thanks for the help again.
    Rica25 likes this.
  20. Sep 23, 2019 at 5:54 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    4.30 is less than 5% lower geared than 4.10, he wouldn't notice a difference in that gearing anyways.
    Rica25 likes this.
  21. Sep 23, 2019 at 5:56 PM
    timsp8
    NY
    You can’t go by what the dealer website says. Some intern typed that in. Ask for a copy of the window sticker. Or type the vin in on Toyota’s official website.
    Rica25 likes this.
  22. Sep 23, 2019 at 6:02 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Ok
    Ok I get him to do that. He is going 1st thing in the morning. He has the window sticker is that what your talking about??
    Rica25 likes this.
