2019 tundra sport lift and mods
Discussion in 'Suspension' started by WigglyLights, Sep 22, 2019.
  1. Sep 22, 2019 at 9:17 AM
    WigglyLights
    WigglyLights [OP] New Member
    Jimmy
    2019 tundra sport
    Just bought my 2019 tundra sport cm. I am want to put a 35" mud terrain on stock wheels what is the best cost efficient lift to achieve this. Ive read alot and getting alot of mixed answers and issues with some sensors. I would like to hear what some of you have done. I pull a boat quite often as well. Dont do a ton of off roading just riding on deer lease. Also what are some good performance mods for some power gains.
    Thanks in advance
    FlipMonkey21 likes this.
  2. Sep 22, 2019 at 9:29 AM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    Not too knowledgeable when it comes to lifts...but if you want to sell your front strut assemblies when you lift, I'll be interested! Yours are the red ones?
  3. Sep 22, 2019 at 10:53 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    35s aren’t going to fit on stock sport wheels. The offset on the wheels is too high and the tire will hit the UCA. You’ll need aftermarket wheels or will need spacers if you are adamant about runnings 35s.
    That being said, you will need at least 4” min of lift if you want 35s and aren’t willing to do some cutting.
    All of this depends on your ultimate goals for the truck and albeit your budget.
    These trucks can be finicky with the sensors after a lift. Unfortunately you won’t know until you lift it. Keeping at least 1” of rake seems to be the go to method. Although it isn’t perfect.
    Exhaust is all you really need for power gains. You can swap your stock filter for a reusable high flow which never hurts.
  4. Sep 22, 2019 at 11:04 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I vote Total Chaos UCA and LCA, Icon 2 1/2" lift with coilovers and remote reservoirs, and 37" tires. Let's spend some $$$! Seriously, though, there are so many good options out there. Icon, Bilstein, Toytec. I run 37s on TC/Icon setup and I love the stability, handling, and stance. But quite pricey.
  5. Sep 22, 2019 at 11:58 AM
    WigglyLights
    Jimmy
    2019 tundra sport
    Thank yall i think after further research now im gonna just do 33" tires whats the best leveling kit. I like the 3" front and 1" back kits anyone have real world experience with these
  6. Sep 22, 2019 at 12:01 PM
    Danman34
    Danman34 New Member
    Danny
    I have a 2/1 lift with Bilstein 6112/5160s and 33s. If you Have the coin, spring for a good set of lifting coilovers/shocks the first time in lieu of the spacers. The ride far surpasses stock and not even comparable to a spacer lift which makes the ride more harsh and will wear the suspension components out in short time.
  7. Sep 22, 2019 at 2:59 PM
    WigglyLights
    Jimmy
    2019 tundra sport
    Danman34 all you did was change shocks are is there more to it then that
  8. Sep 22, 2019 at 3:27 PM
    Danman34
    Danman34 New Member
    Danny
    The front assembly is designed to lift the truck up to 2.5”. I used an adjustable shackle in the rear to raise the back an inch. All there is to it. I ordered the assembly preassembled at 2” and installed front and rear in my driveway in 4.5 hours.
  9. Sep 22, 2019 at 3:42 PM
    WigglyLights
    Jimmy
    2019 tundra sport
    This kit here
  10. Sep 22, 2019 at 3:43 PM
    Danman34
    Danman34 New Member
    Danny
    Yes. Same front, but I have the dual reservoir 5160s for the rear.
  11. Sep 22, 2019 at 3:44 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Dan that thing is sick!!!!!
  12. Sep 22, 2019 at 3:55 PM
    Danman34
    Danman34 New Member
    Danny
    Thanks man! ​
  13. Sep 22, 2019 at 4:31 PM
    FlipMonkey21
    FlipMonkey21 New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    Here check out this YouTube of my truck getting some work done by 88Rotors here in SoCal. This will give you some ideas with lifting your Tundra.
    https://youtu.be/XF9kXHHecfo
    Omohundro likes this.
  14. Sep 22, 2019 at 5:01 PM
    MattAttack03
    MattAttack03 New Member
    2019 Tundra TRD Sport
    6” Pro Comp Lift 20x12 Fuel Couplers 35” Toyo Open Country
    2019 TRD Sport
    6” Pro Comp Lift
    Fuel Coupler 22x12
    Rockgate and Blueknights75 like this.
