New to me-2006 DC/TRD/Limited with 36,000 miles
Discussion in '1st Gen Tundras (2000-2006)' started by Oregon 2006 Tundra, Sep 20, 2019.
  1. Sep 20, 2019 at 10:44 AM
    Oregon 2006 Tundra
    Oregon 2006 Tundra [OP] New Member
    2006 Tundra TRD Limited Double Cab
    Spray-in Bedliner
    Greetings!
    My late father purchased this Tundra new and has driven it very little in the past 13 years. Mostly hunting trips and when it snowed.
    Question is, while it has been started and ran on a regular basis, should I be concerned with any maintenance issues like the timing belt? Is it an interference engine?
    Drives like a dream and I expect to hold onto it until it dies or I do.
    Thanks.
    georgiey22, SrgJigPog and Black Wolf like this.
  2. Sep 20, 2019 at 10:55 AM
    90k miles for the timing belt. If you're unsure of maintenance a full fluid change is cheap insurance and not to hard to do. It is an interference engine, but it may or may not screw things up if the belt snaps. We've seen both happen.
    Also, we need pics!
    because_wumbo-truck likes this.
  3. Sep 20, 2019 at 11:07 AM
    AZBoatHauler
    So.Arizona
    I believe the change interval is 90k or 10 years. I'd go ahead and have the service done. To answer your other question, chances are you will destroy the motor if the timing belt fails while the engine is running.
  4. Sep 20, 2019 at 11:11 AM
    tacomawv
    tacomawv New Member
    Richard
    I would change the belt and the fluids. Also look at the brake lines and surpitine belt. Rubber stuff goes bad with age.
  5. Sep 20, 2019 at 12:00 PM
    Welcome. What a great truck to inherit. Everyone already gave great advice. Even though the belt is only required every 90K, it also says to replace it every 9 or 10 years. So you're overdue from that standpoint. I'd go ahead and do the water pump too.
    As suggested above, change all the fluids too. If it's 4x4, don't forget the front diff and transfer case. If you are capable at all, changing the fluids is incredibly easy.
    Once you get all that done that truck will easily outlast you.
  6. Sep 20, 2019 at 12:01 PM
    flyfisher
    flyfisher Member
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Picture?
  7. Sep 20, 2019 at 1:24 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW and :worthless:
    flyfisher likes this.
  8. Sep 20, 2019 at 8:34 PM
    Oregon 2006 Tundra
    Spray-in Bedliner
    Thanks for the information. I didn't even think about the mechanicals timing out. looking for a better pic of the truck but here is one of dad's service. 1st Force Recon Colonel and all-around good guy. This was a shot of our last hunt together last August for antelope here in Oregon. Truck got us to the top of the mountain and back. And we bagged an antelope.IMG_20190914_101050616.jpg IMG_20180814_073028072.jpg
    georgiey22, MS22, aperezsh and 19 others like this.
  9. Sep 21, 2019 at 2:33 AM
    biebs96
    PA
    After the full maintenance as everyone suggested you’ll love it.
    My dad has the same truck, color and all. It’s got somewhere close to 300k on it.
    TokerJoker likes this.
  10. Sep 21, 2019 at 7:36 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Love that color. I've had antelope jerky and it's pretty good actually. As for antelope burger I'll pass. That's very cool to have your dad's truck!
  11. Sep 21, 2019 at 7:48 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Great story with MEMORIES !!!
    Sounds like u inherited a great LOW miles Tundra !!!
    Welcome from Maryland :hattip:
  12. Sep 21, 2019 at 8:17 AM
    Welcome from Colorado. Nice pics...Sorry about your dad. Semper Fi to his memory. Formerly from Drain, Orygun:thumbsup:
  13. Sep 21, 2019 at 9:09 AM
    Are you planning on doing your own wrenching?
  14. Sep 21, 2019 at 4:26 PM
    Oregon 2006 Tundra
    Spray-in Bedliner
    Fluids and regular maintenance are within my abilities. Timing belts, not so much. Currently driving a CLS-63 with the big motor and all I can do on that is take it in when the CEL comes on. Not even a dipstick to check the oil. Looking forward to wrenching again. Also looking forward to better gas mileage on the Tundra!!
    Thanks again for info on the truck and the thoughts about my father.
  15. Sep 21, 2019 at 11:17 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Congrats on the "new" truck OP. Its awesome.
  16. Sep 21, 2019 at 11:26 PM
    kgb4187
    kgb4187 New Member
    I can see the tires aren't the original, but you might want to check out the production date and inspect them to make sure there's no dry rot.
    Watt maker likes this.
  17. Sep 23, 2019 at 6:18 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    Welcome, and what an awesome, basically NOS truck to get from dad. Like others have said, get the timing belt/water pump service done, and swap the running gear fluids. The transmission is probably fine (they are sealed units) with so few miles. I also agree with tires...probably time for new ones from a safety standpoint. Also make sure there is no rust starting underneath since it's seen snow.
    And speaking of safety, there are a few recalls you should have checked at the dealer. One or two is for the airbag system, and the other is for the lower ball joints. If it's been done, you're good for a while. If not, you may be able to get new lower ball joints for free. Have the dealer run the VIN to see if it's been done.
  18. Sep 23, 2019 at 7:04 AM
    Welcome from NY.
    Sorry to hear about your dad.
  19. Sep 24, 2019 at 3:17 PM
    allibubba
    allibubba New Member
    PDX
    2003 Access Cab & 2006 Double Cab
    Level kit 33's
    +1 on the recalls, just had my airbags inspected and replaced as part of a recall.
    Also welcome from PDX!
