Not sure where to ask so...
Discussion in 'Suspension' started by tacoguybill, Sep 21, 2019.
  1. Sep 21, 2019 at 6:08 AM
    tacoguybill
    tacoguybill [OP] The Burrito Bandido
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    Ok so I noticed some vibrations the other day (nothing crazy) and then noticed that the front right tire has unusual wear on the outer edge of the tire but only on that one tire, so I’m not sure if I should just rotate, or take it in for an alignment and let the dealership see if there are any suspension components that could be causing this, any input would be appreciated
  2. Sep 21, 2019 at 7:28 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    My guess is the alignment is off which is likely if you take it off road and/or are lifted at all. Taking it in for an alignment is probably a good idea. Maybe something is worn like a tie rod and you don't even notice it. An alignment shop should be able to tell you if something is loose also.
  3. Sep 21, 2019 at 7:39 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    My vibration causing uneven tire wear was a unbalanced wheel. May have lost a wheel weight. Start simple first imo
