Who has the highest mileage with a 3rd Gen?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pupule Mike, Dec 15, 2018.
  1. Sep 18, 2019 at 4:23 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    Dang! Not sure how you've pulled that off. I've got 70k on my '16 and I've turned the rotors once and changed once and getting ready to do full front/rear pads/rotors again. Shaking a lot under braking again.
    georgiey22 likes this.
  2. Sep 18, 2019 at 4:31 AM
    War Machine
    War Machine SSEM # 5 3MW
    2017 just broke 40k a couple of weeks ago.
  3. Sep 18, 2019 at 6:17 AM
    mrkastni
    mrkastni New Member
    Michael
    South Dakota
    2018 Limited CM Blazing Blue
    31k on my 2018. I have owned it now 10 months.
    Migraine and GasGuzzler like this.
  4. Sep 18, 2019 at 6:32 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    2017 64k
  5. Sep 18, 2019 at 6:32 AM
    DireWolf
    DireWolf The Dark Lord - Tundra Owner
    North East Florida
    2016 Dark Gray Tundra SR5 (MGM)
    none
    I bought it used it is a 2016 and I have 87K
    georgiey22 and Migraine like this.
  6. Sep 18, 2019 at 6:35 AM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    2015 Just rolled over 70k
    Hondoman likes this.
  7. Sep 18, 2019 at 6:45 AM
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    Bought new in sept of '17, about to roll 64k
  8. Sep 18, 2019 at 6:45 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    2017 with 60K.
    Had a CV boot blowout back before summer , covered under warranty.
    georgiey22 and jordan0317 like this.
  9. Sep 18, 2019 at 8:53 AM
    GasGuzzler
    GasGuzzler New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    After 3 years it would have been fine. It's the 5 year mark you really have to worry about. I had the Grand Cherokee SRT prior ot my Tundra. I loved that thing and miss it. I know that the transmission was going to have problems if I went too much longer. 2015 with 69K. I have had the tundra since Dec 20, 2018 & already have 21K. IMG_0326.jpg IMG_0072.jpg
  10. Sep 18, 2019 at 9:23 AM
    Trdpro Chadwick
    Trdpro Chadwick New Member
    Parkersburg, W(by god)V
    15 TRD Pro Inferno CM
    35/12.5/18
    2015 28k miles
  11. Sep 18, 2019 at 9:44 AM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    look at the settings in your stereo. You can set it for drivers for only on first push. Everything else with a quick second push of the button.
  12. Sep 18, 2019 at 12:54 PM
    Cabinetman
    Cabinetman New Member
    Kevin
    The option I need is to unlock both doors on the driver's side with the first push (or touch in my case with keyless entry). I typically have a bag with me that I throw into the floor board behind the rear seat.
    classiccat likes this.
  13. Sep 18, 2019 at 1:10 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    21k on my 2017... I have the dreaded cam tower leaks on both sides... not bad, but it’s there. Still going back and forth in my mind about what to do... Engines with low miles shouldn’t leak oil... yet I hate to open up a motor that has such low miles... especially one I had hoped to keep for a long time...
  14. Sep 18, 2019 at 4:16 PM
    mpd13078
    mpd13078 New Member
    Alabama
    2017 Platinum Crewmax 4WD 5.7L
    Stock
    2014 -> 37,224 miles
    2nd owner.
  15. Sep 18, 2019 at 5:27 PM
    gdisarray
    There was a post around here in a thread about rolling down all four Windows at a time where they talked about a middle you could buy that would roll down two simultaneously. I'll see if I can find it.
  16. Sep 18, 2019 at 6:11 PM
    Samson
    Samson New Member
    2022 SR5 Tundra,2018 SR5 Tundra, 2003 SR5 Tundra
    Its not really "high milage" but i rolled over to 66K on my 2018 today.
    georgiey22 and (deleted member) like this.
  17. Sep 18, 2019 at 7:08 PM
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    2015 with 63K. Had to update the radio
  18. Sep 18, 2019 at 7:17 PM
    biebs96
    PA
    I don’t stand a chance. 22k on my 17
    porkitt likes this.
  19. Sep 18, 2019 at 7:36 PM
    sundance
    sundance New Member
    Get it fixed. Its under warranty. Go to the best dealer you can find. Ask how much experience their best tech has.
    MatthewPTguy[QUOTED] likes this.
  20. Sep 18, 2019 at 7:37 PM
    #50
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    43,000 miles on my 2018. I've had this one almost 2 months bought used, but when I bought it the mileage was within 5,000 miles of what was on my 1st 2018 (bought new) when it was wrecked, so continuing within a reasonable margin of error mileage wise in a truck that is virtually identical to my other one except for the 4wd vs 2wd.
  21. Sep 19, 2019 at 7:32 AM
    #51
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    I very quickly looked at the new RAM before my good senses kicked in and I put in my order for a Tundra. They sure are pretty. 12 inch monitor is a great addition. Gives you something to play with on the side of the road while you wait for the tow truck.
    I can't wait for my new Tundra! Well, I have to wait. They're talking mid-October for the one I want... Canada only gets about 13k of the 330k Tundras made every year. You Yanks hoover up the rest. Greedy bastards... lol.
  22. Sep 19, 2019 at 7:36 AM
    #52
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    2014 with 64k. I hope to see 200+k IF I don't trade her in for a new one before then.
    Right now I am super happy with my rig... years to come who knows
  23. Sep 19, 2019 at 7:41 AM
    #53
    sundance
    sundance New Member
    More Tacomas than Tundras. I think they make around 180,000 Tundras a year.
    2019 Rams are pieces of junk. Look pretty but they're way too many problem with them. Selling them for dirt cheap right now.
    Ted4311 likes this.
  24. Sep 19, 2019 at 10:01 AM
    #54
    BigdaddyII
    South Louisiana
    2019 Ram 1500
    Add to this that they now lock when either put into gear or begin moving, and unlock when put back in park. This can be disabled as well. I have it set to unlock all the doors with 1 push because, as quoted below, most times I need more than just the driver door open but I have disabled the constant lock/ unlock feature because I trust myself not to fall out of my truck while Im driving down the road.
  25. Sep 19, 2019 at 3:00 PM
    #55
    gdisarray
    1. I have mine set to lock when put into drive.
    2. On remote 1 push driver's door, two everything else. (It is not safe for all to unlock. If the little lady takes the truck and is in a parking lot she doesn't want the other doors to unlock when getting in. Someone could be chasing her, or crouching on the other side)
    3. See #2 for doors automatically unlocking when put into park. Safety issue. So many scenarios.
  26. Sep 19, 2019 at 3:21 PM
    #56
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I just rotated my tires in my driveway and took a good look at the front pads. 75% of the pads still there. I'm just now to 55,000 miles.
  27. Sep 19, 2019 at 3:37 PM
    #57
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    We have a 2008 Sequoia with 216k on it
    Not a 3rd gen I know
    TK1979 and georgiey22 like this.
  28. Sep 20, 2019 at 9:40 PM
    #58
    Texas Girl
    Texas Girl 2015 Tundra CrewMax
    Cindi
    2015 Tundra 5.7 CrewMax TSS Off Road
    Be glad you didn't buy a RAM. I have one now. Loved the truck when I bought it bran new in 2012. I hate it now!! I have the dreaded "hemi tick". No one seems to be able to tell me what is wrong with it. They say it could be broken exhaust manifold bolts...well I had that 3 months ago. That was $900 to fix that. Tick went away for a month or two. Now it's back. Everyone is telling me it could be lifters failing, or something deeper in the engine. No way to know unless they go into the engine to find out what all is wrong. Bottom line......I'm getting rid of it.
    There are 3 guys that work for us, and all 3 of them have Toyota trucks. Two of them have Tundra's. One has a V-8 and his truck has 180k on it. He said he bought it with 100k on it and he's never had any issues. The other guy has the V-6. He's got 183k on his. He said the only thing he has ever had to do to it, was put an alternator on it at 70k miles. Says its run perfect. The 3rd guy has a toyota tacoma. It's a 2004. It's a 4 cylinder and he's got 230k on his and its still running great! So.....I'm going to be trading my 2012 RAM for a Tundra. Looking to get a 5.7 V-8. I'm so hoping that it does as good for me as the guys trucks who work for us.
    classiccat, WFD473, T-Rex266 and 2 others like this.
  29. Sep 20, 2019 at 9:45 PM
    #59
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    @Texas Girl welcome from Ventura California..and your making the right decision..
    Texas Girl likes this.
  30. Sep 20, 2019 at 9:46 PM
    #60
    saybng
    Gary
    Ventura CA
