1st Gen sway bar link options
Discussion in '1st Gen Tundras (2000-2006)' started by 03tundra4x4, Mar 14, 2019.
  1. Mar 14, 2019 at 5:29 PM
    03tundra4x4
    03tundra4x4 [OP] New Member
    Jordan
    Bristol, TN
    lifted 03 tundra access cab
    2 in front spacer with bilstein 5100s, wheelers 3 pack springs in the rear and 16x8 -10 level 8 mk6 on lt285/75/16 falken wildpeak at3
    New to the forum, so if I'm posting this incorrectly then my bad. :confused::D
    I have been trying to find any all options for some good sway bar quick disconnects. I have found another tundra member on here with a diy that I like but would like to see other options and/or opinions. I'm very curious if something like what's pictured below would work. Seems like a very viable options if the mounting would be close to the 1st Gen tundra. Screenshot_20190314-201938.jpg
  2. Mar 15, 2019 at 4:28 AM
    Professional Hand Model
    Fred
    Hand Protectors
  3. Mar 15, 2019 at 5:09 AM
    03tundra4x4
    Jordan
    Bristol, TN
  4. Mar 15, 2019 at 6:41 AM
    I'm a newb. What would be the reason or needing to quickly disconnect the sway bar?
  5. Mar 15, 2019 at 6:44 AM
    03tundra4x4
    Jordan
    Bristol, TN
    With the sway bar disconnected it will allow for better articulation. Better wheel to ground contact is the ultimate goal/reason for the disconnects.
  6. Mar 15, 2019 at 7:12 AM
    What 03 tundra said. More in depth it makes it so on uneven terrain if your left front wheel goes up, the sway bar will push up on the right side too. So with it disconnected none of the weight transfer happens and they can articulate completely independent.
    03tundra4x4[OP] likes this.
  7. Mar 15, 2019 at 7:19 AM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    You can probably get something like that to work. As far as the end link I made my sway bar swivels up far enough out of the way so in full Flex I have no issue. The heim joint at the bottom will also swivel down giving you a few inches more room. Although I do have an aftermarket sway bar. It came with my 6 inch lift. Try disconnecting your end links and seeing how much movement up and down you have on the sway bar. This will give you a good idea of how much room you have.
  8. Mar 15, 2019 at 7:56 AM
    03tundra4x4
    Jordan
    Bristol, TN
    Ok good to know!! I also think that some Jeep aftermarket sway bar links may work for the 1st Gen tundras, like pictured below.Screenshot_20190314-210300.jpg Screenshot_20190315-105421.jpg
  9. Jun 10, 2019 at 1:23 PM
    Mstudt
    Mstudt New Member
    2001 Toyota 4runner
    I'm new to this forum, but not new to Toyota's. I've been making sway bar links for 4runner's, Tacoma's,, and GX's for the past 4+ years. Below are some of the links I've made, and would love to be able to help out members on this forum. I'll try to get on here daily to check on this, and get one of my own threads going with some more information.
    Mike (Mstudt)
  10. Jun 11, 2019 at 6:58 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    I just did my sway bar end links, but if I had known about your stuff I would have went through you. Looks like great stuff!
    I would be curious to see some pricing if you would post that in this thread for the 1st gen tundras.
    Thanks!
  11. Jun 11, 2019 at 7:07 AM
    Mstudt
    Mstudt New Member
    2001 Toyota 4runner
    Pricing should be $180 shipped for non-disco front links with yellow zinc tubes, and disco's would be $200 shipped with yellow zinc tubes. Adding powder coat would be $20 extra, and heim boots would be $20 as well. Keep in mind that's my pricing for 4runner's and Tacoma's though. Assuming the same size parts are used that would be pricing for Tundra's as well. But, if I'm able to jump up a size in heim joints, and tubes. That pricing "might" go up a little, but most likely not much.
    00TundraZ[QUOTED] likes this.
  12. Sep 20, 2019 at 7:28 AM
    Mstudt
    Mstudt New Member
    2001 Toyota 4runner
    Just though I'd put these here, and they can be found here.
