Timing belt sticker shock
Discussion in '1st Gen Tundras (2000-2006)' started by SoCalPaul, Sep 16, 2019.
  1. Sep 16, 2019 at 6:36 PM
    SoCalPaul
    SoCalPaul [OP] New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    So I stopped by 2 shops to get quotes for the timing belt service. I have the Aisin kit, Gates hoses and a new radiator. 1 shop quoted $500 labor. 2nd shop quoted $1100 but said that would include the crank seal and cam shaft seals.
    Does this sound reasonable?
    Thx.
  2. Sep 16, 2019 at 6:42 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The 1100 sounds about right if your seals are leaking.. to replace the cam seals on the vvti engine you have to remove the camshafts. Which means pulling the valve covers and the. The cams.
  3. Sep 16, 2019 at 6:52 PM
    SoCalPaul
    Paul
    Pretty sure the cam seals aren't currently leaking, but the 2nd shop recommends doing them.
    I'm supplying the majority of the parts.
  4. Sep 16, 2019 at 6:54 PM
    empty_lord
    05 rollover special
    If the cam seals don’t appear to be leaking you can not do them, it saves a lot in labor. But if they do start leaking you’ll have to pull the timing belt apart again. So it’s a matter of if you want to do it now as preventative maintenance or later when it leaks (they usually don’t leak too bad and a lot of people ignore them till it’s due for a belt again)
    Sunnier likes this.
  5. Sep 16, 2019 at 6:57 PM
    SoCalPaul
    Paul
    Yes, they said in their experience the cam seals often leak about 10-20k miles after the timing belt replacement.
    OR18TRD likes this.
  6. Sep 16, 2019 at 7:12 PM
    SoCalPaul
    Paul
    112k
  7. Sep 16, 2019 at 7:16 PM
    empty_lord
    05 rollover special
    its your call. i did mine when i did my belt. but mine were leaking. they werent leaking bad... but i dont like looking at oil on my engine. lol
    15Yota and OR18TRD like this.
  8. Sep 16, 2019 at 7:21 PM
    SoCalPaul
    Paul
    I only want do this once. I mostly do my own labor so I was somewhat shocked at the quote. That's about what I would expect from a dealer.
    Unpredictable1 likes this.
  9. Sep 16, 2019 at 7:22 PM
    empty_lord
    05 rollover special
    its been a good bit since ive done one at work. but i believe with labor the cam seals and belt with parts is 1500-1600 at the dealer
    OR18TRD likes this.
  10. Sep 16, 2019 at 7:46 PM
    SoCalPaul
    Paul
    10+
  11. Sep 16, 2019 at 7:51 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Do the water pump while at it.
    Rex Kramer, artsr2002 and Sunnier like this.
  12. Sep 16, 2019 at 8:07 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    The 500 sounds reasonable to me. I didn't do cam seals and I changed it around about 170k. They weren't leaking. My best friend is a Master Tech at Toyota and I "helped" him do it in the driveway. He said he hasn't seen alot that leak, but he always recommends it to customers for obvious reasons. We didn't do mine though.
    Also did the water pump and serpentine belt.
  13. Sep 16, 2019 at 8:12 PM
    empty_lord
    05 rollover special
    the VVTI ones leak moreso than non vvti, but even then its not super common. mine had almost 200k when done. so leaking is kinda expected.
    HappyGilmore[QUOTED] likes this.
  14. Sep 16, 2019 at 8:13 PM
    empty_lord
    05 rollover special
    yea they wonder why we cant sell timing belts with cam seals when their leaking.. and i just look at them dumbfounded... maybe its the $140 an hour labor and the extreme markup on parts... hmmm
    Darkness likes this.
  15. Sep 16, 2019 at 8:21 PM
    SoCalPaul
    Paul
    How much does he want
  16. Sep 16, 2019 at 8:37 PM
    HappyGilmore
    Trent
    Lakewood CA
    PM sent.
    OR18TRD likes this.
  17. Sep 17, 2019 at 7:06 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I recently had a trusted shop with ALOT of Toyota truck experience do the following:
    Clean Intake
    Aisin TB/WP kit
    cam seals
    crankshaft seal
    valve cover gaskets
    Spark Plugs
    Serpintine belt, pulley and tensioner
    Thermostat
    8 spark plugs
    Oil/Filter Change
    2x drain and fill of Transmission
    They charged me $950 and I was pretty happy with that. I brought all the parts and they totaled about $430 on Rock Auto if I remember correctly...
    HappyGilmore and FirstGenVol like this.
  18. Sep 17, 2019 at 7:15 AM
    Man, that is a steal. I'm in shock honestly. That has to be labor only with your supplying the parts. Right?
    @SoCalPaul I paid around $900 for timing belt and water pump at the dealership. $500 for just labor seems fair. Have you considered doing it yourself? I've "heard" people say this is one of the easier engines to do a timing belt on and I know from your previous posts that you're pretty capable.
    speedtre[QUOTED] likes this.
  19. Sep 17, 2019 at 7:17 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Yea, I edited my post to point that out....I was still very pleased with that price for that amount of work. His price included the toyota coolant and ATF because I did not bring those.
  20. Sep 17, 2019 at 7:21 AM
    This is probably a silly question for the more knowledgeable here, but how does one know if they are leaking? Can you see these seals with the valve covers off?
  21. Sep 17, 2019 at 7:23 AM
    speedtre
    speedtre New Member
    Inland Northwest
    214354d1470409250-cam-crank-seals-4-7-vv_af4ec5bf96ba9c13ea10c1c5c7270d996ed442d6.jpg
    bmf4069 likes this.
  22. Sep 17, 2019 at 7:54 AM
    empty_lord
    05 rollover special
    The front of the motor usually get covered in oil. You cannot see them with the covers off, but if you pull the upper timing covers you can see down and tell if they are
  23. Sep 17, 2019 at 11:58 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    No way I'd do the cam seals on a VVI engine unless they were dumping oil. Mine were bone dry at 167k on my 2006. Cam seals on non VVI are pretty straight forward, pop off the old seal from the front of the engine and push a new one in. But on the VVI engines you need to fully disassemble the cams and timing gearing that meshes the intake and exhaust together. I'm sure lots of experienced techs get it right, but there's always the risk of a newbie tech getting it wrong.
  24. Sep 17, 2019 at 3:48 PM
    Aerindel
    Aerindel New Member
    Montana
    My 19 year old neighbor did mine....can't be that hard :)
    TX-TRD1stGEN likes this.
  25. Sep 17, 2019 at 4:09 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    I replaced mine twice (with the full Aisin kit), each 90k miles on my 2006 AC SR5 (sold it to my daughter with 225,000 on it). No leakage on the cam seals.
    The second time I went through just about everything under the hood (new battery, replaced brake fluid, new serpentine belt, new alternator brushes, new upper and lower radiator hoses, replaced power steering fluid, new spark plugs, checked valve clearances, new valve cover gaskets, new air filter, new thermostat).
    It took me most of a weekend, I think I finished around noon on Sunday. Since I had done it once before, second time went much easier (even though I did much more work on it).
    When I closed the hood, I had a real good feeling that I wouldn't have to do anything but basic maintenance for some time. My daughter has had the Tundra for about 1 1/2 years and is planning on the next timing belt change (she is close to 270k miles). She has an excellent mechanic to turn to but I will advise as necessary.
  26. Sep 17, 2019 at 5:02 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Mine was about $1150 and included a rental car for the day at Toyota, that was about 5 years ago. They claimed to do the cam seals as well but I'm suspicious of that, all I cared about was the belt and pump.
  27. Sep 17, 2019 at 9:35 PM
    empty_lord
    05 rollover special
    set timing mark to point at the middle of the idler pulley bolt and theres no risk of valve/piston contact.
    that being said i've had to replace a few engines from botched t-belt jobs. no cam seal jobs botched that ive dealt with
  28. Sep 17, 2019 at 9:51 PM
    SoCalPaul
    Paul
    My plan was to do it myself, but my asthma has been acting up and I’m concerned that I might get to a point and get stuck. My water pump is leaking and I just want to get it fixed so I feel comfortable taking a couple of trips.
  29. Sep 19, 2019 at 11:53 AM
    PlanoJames
    PlanoJames New Member
    james
    06 Spectra Blue Mica,DC,SR5,4.7L
    ARE Tonneu cover,Nerf bars,Bilsteen 5100s, Power Stop Truck & Tow Front Brake Kit,Weathertech Frt floor liners
    Just had mine done a couple days ago. Going be doing a lot of traveling in the coming months so I figured I'd play it safe and get done now at 98,880 miles.
    Anti-freeze
    Crank seal
    Thermostat + gasket
    Aisin TB/WP kit
    Spark plugs
    Parts $635
    Labor $802
    +tax $1490 total
    Truck's running great,no leaks,no problems,so pretty happy with it so far. One thing I'm kind of miffed about is they charged $406.98 for the TB kit.
    That seems pretty high since it can be found on Amazon for $168.00 and eBay for $200-250 from a bunch of sellers. But my shop has done me solid for many years so I'm not really complaining about it that much.
    speedtre likes this.
