TRD non-BBK brake calipers
Discussion in 'Performance and Tuning' started by Spvrtan, Oct 3, 2018.
  1. Oct 3, 2018 at 12:37 AM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    I found some part numbers though couldn't find more information to confirm the validity but it seems there is a TRD high peformance brake kit for our Tundras that is 6 pistons and fits on standard size rotors. @Roman, @SparksParts, can you chime in?
    Mountains49 likes this.
  2. Oct 3, 2018 at 6:31 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    What are the part numbers you have found? There is a big brake kit that has larger rotors, and there are TRD brake pads that work with the stock calipers. I have never heard of 6 piston calipers for use on stock rotors.
  3. Sep 18, 2019 at 11:32 AM
    Thorough76
    Thorough76 New Member
    17 tundra 1794
    I'm new the forum & wanted to know if part #
    PTR09-00150 (TRD BBK) compatible with a 17 tundra 1794?
  4. Sep 18, 2019 at 11:47 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Welcome...
    Yes, it will fit all Tundras from 2007 to current.
    Note: You will need at least a 20" wheels to clear the TRD BBK and some 20" OEM wheels will not clear.
