Backflip MX4 questions
Discussion in 'Tonneau Covers, Caps and Shells' started by ForceV4, Sep 5, 2019.
  1. Sep 5, 2019 at 10:51 PM
    ForceV4
    ForceV4 [OP] Pull my finger
    Sacramento
    2018 DC TRD 4x4
    I scored a Backflip MX4 that looks like new for $400 on Craigslist recently from the same gen & configuration as my truck. It fits and I dig it, but have 2 questions.
    First, is it normal to have a bit of side to side play? If the cover is shut, it stays put and everyone is happy. When I open and close it, it's possible to get the cover on heavily to one side or another. If I close it carefully, I can center it and it's fine.
    Secondly, I had to buy the kit to drop the deck railing. The first and last brackets don't leave any room for the hardware without the nut hitting the bed. I don't want to chew through the Line-X. What have you guys/gals done to remedy this?
    Thanks in advance.
  2. Sep 17, 2019 at 11:32 PM
    BajaTurd
    BajaTurd Burrito Champion
    Aj
    San Diego
    19 4x max
    Camburg uppers Kings Deavers
    Yes it moves side to side a bit when closing multiple panels, happened to my tacoma now same with tundra otherwise it’s really a tight fit. That’s my experience.
    Secondly never had to use drop brackets so not sure how that configuration works. Can you shorten the bolts? Pics would help!
    OR18TRD likes this.
  3. Sep 18, 2019 at 5:22 AM
    War Machine
    War Machine SSEM # 5 3MW
    I have the same cover. Definitely some play in it, though I open it rarely. Can’t speak to the deck rail issue as I don’t have them.
