  1. Sep 15, 2019 at 5:12 PM
    #5311
    Tundy White
    Tundy White New Member
    Jesse
    Ontario, Canada
    13 DCOR
    Levelled and Debadged
    Rica25 and TheBeast[QUOTED] like this.
  2. Sep 15, 2019 at 5:20 PM
    #5312
    Stewartac
    Stewartac New Member
    Castle Rock Colorado
    2013 White Tundra
    You should probably figure out how water got in the reservoir. Seems like a lot for condensation. That's what made your fluid icky
    Mountun Goat[QUOTED] and Rica25 like this.
  3. Sep 15, 2019 at 5:20 PM
    #5313
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This stuff. I'm sure that what you put in will be fine, and if it isn't, we'll always think that it should've been.
  4. Sep 15, 2019 at 5:21 PM
    #5314
    Stewartac
    2013 White Tundra
    Added LED strips to the topper and one under the hoodIMG_20190915_181915.jpg IMG_20190915_181916.jpg
    TheBeast, Mountun Goat and Rica25 like this.
  5. Sep 15, 2019 at 6:12 PM
    #5315
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    That’s what I’m scratching my head over too.
    Rica25 likes this.
  6. Sep 15, 2019 at 6:21 PM
    #5316
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
    I finally got around to doing the rear fold down seats mod.
    Anyone else find it convenient and practical?
    TRD-tv, Trooper2 and Rica25 like this.
  7. Sep 15, 2019 at 6:23 PM
    #5317
    Rica25
    Ricardo
    Tulare
    For double cab?
  8. Sep 15, 2019 at 6:31 PM
    #5318
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    Yes a DC
    Silverghost and Rica25[QUOTED] like this.
  9. Sep 15, 2019 at 6:41 PM
    #5319
    Trooper2
    JR
    Houston, TX (Suburban South)
    Need to do this. Did you grind / cut down hooks or bend hoops down?
    Rica25 likes this.
  10. Sep 15, 2019 at 6:44 PM
    #5320
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    I just used a rubber mallet to bend the hooks.
    Rica25 likes this.
  11. Sep 15, 2019 at 7:04 PM
    #5321
    TheBeast
    TheBeast The Beach
    nice ! now that I have a topper, i found some projects :) which led strips did you use ? did you run a 12V wire from the battery to the rear ?
    Rica25 likes this.
  12. Sep 15, 2019 at 8:07 PM
    #5322
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    Also interested in the link. Those look they would replace the ugly AMP Research power step lights nicely. I was going to contact matt gecko for 1 long strip, but these look like they will work just fine, as long as the color is what I want.
  13. Sep 16, 2019 at 5:57 AM
    #5323
    Stewartac
    2013 White Tundra
    Wanted to share a couple pictures of the LED lights at night. Should be really nice if I ever have to work under the hood at night. The bed also received a digital volt meter and a dual USB receptacle for devices while camping. Next is a new battery for the truck with a larger reserve capacity
    erandmckay, MyFj08, TheBeast and 4 others like this.
  14. Sep 16, 2019 at 6:15 AM
    #5324
    Stewartac
    2013 White Tundra
    I have a auxiliary fuse panel installed with a breaker and I ran 12G wiring from the panel all the way back, I'll take a picture of the bed wiring routing when I get a chance, hidden and clean.
    I bought the LED strips here
    PryEU Daylight White 6000K LED Strip Lights 12V
    Waterproof for Auto Car Truck Boat Motorcycle Interior Lighting 12'' 30CM 3528 SMD UL Listed Pack of 4 https://www.amazon.com/dp/B00YXBEHQK/ref=cm_sw_r_cp_apa_i_PQ4FDb3A664DV
    Keep in mind the wiring for the strips is very small, like 22. I stripped about an inch of each wire and twisted the wires and then folded it in half twice to make it large enough for a connector crimp.
  15. Sep 16, 2019 at 6:16 AM
    #5325
    Stewartac
    2013 White Tundra
    Check the above posts as well as photos of at night.
    Sorry for posting a lot in a row I couldn't figure out the multiuote feature on mobile
    Trooper2 likes this.
  16. Sep 17, 2019 at 7:43 PM
    #5326
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Shrek came into town this past Sunday and hooked it up. Definitely cleaned up the power band and improved shifting.
    TRD-tv, Trooper2, Stainlesst and 3 others like this.
  17. Sep 18, 2019 at 6:00 PM
    #5327
    Tundra Fan
    Toby
    In progress
    NE_WARRIOR, yoshi82, kgb4187 and 6 others like this.
  18. Sep 18, 2019 at 6:35 PM
    #5328
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    Dustin came and did mine last year in grand junction it been bad ass only thing is it wont shift in tow haul mode so i just dont put it in...
    TheBeast and Mountun Goat like this.
  19. Sep 18, 2019 at 9:43 PM
    #5329
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    Just got this done:
    Mountun Goat, Rica25 and TheBeast like this.
  20. Sep 18, 2019 at 9:44 PM
    #5330
    computeruser6
    Dirk
    Escondido
    After?
    Rica25 likes this.
  21. Sep 18, 2019 at 9:47 PM
    #5331
    TheBeast
    TheBeast The Beach
    CARB special after the Feds latest decision ? :rofl:
  22. Sep 18, 2019 at 10:06 PM
    #5332
    computeruser6
    Dirk
    Escondido
    Whoa now, I'm not going crazy by getting a straight pipe here...
  23. Sep 19, 2019 at 8:00 AM
    #5333
    Tundra Fan
    Toby
    :cool:
  24. Sep 19, 2019 at 1:10 PM
    #5334
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    I don't have that problem. Have you tried pulling the neg battery terminal for a few to let it relearn? I didn't have to do that when I got tuned but maybe a try?
  25. Sep 19, 2019 at 2:41 PM
    #5335
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    Are those 35s or bigger?
  26. Sep 19, 2019 at 3:13 PM
    #5336
    TheBeast
    TheBeast The Beach
    they look like 33"s
    Pbear1454[QUOTED] likes this.
  27. Sep 19, 2019 at 5:12 PM
    #5337
    Tundra Fan
    Toby
    They are 33"s.
    Falken Wildpeak 285/70R17
    Front has Bilstein 5100's on the top setting, rear is stock, but I'm thinking about adding Toytec shackles on the lowest setting.
  28. Sep 19, 2019 at 8:07 PM
    #5338
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    I'm running the same tires and yours look bigger. Lol
    Tundra Fan[QUOTED] likes this.
  29. Sep 19, 2019 at 8:12 PM
    #5339
    Tundra Fan
    Toby
    :muscleflexing::benchpress:
    :D
  30. Sep 19, 2019 at 8:14 PM
    #5340
    NE_WARRIOR
    NE_WARRIOR [HOONIGAN] Wannabe
    Union, ME
    08 DC SR5
    Are they on a 17in rim?
