ORDERS TAKEN FOR A LIMITED TIME
Discussion in 'DecalsByDesign' started by DecalsByDesign, Mar 14, 2019.
  1. Apr 4, 2019 at 2:31 PM
    #61
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    Got mine too! Thanks again! Great guy threw in some extra pieces for my first attempt at wrapping some center console trim pieces. Now that’s customer service @DecalsByDesign much appreciated once again
    DecalsByDesign[OP] likes this.
  2. Apr 4, 2019 at 2:31 PM
    #62
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    How will those wheel decals hold up? I drive on the beach a lot. Deep sand...Definitely interested
  3. Apr 4, 2019 at 2:33 PM
    #63
    owb2gp
    owb2gp New Member
    ID
  4. Apr 4, 2019 at 2:58 PM
    #64
    brocktonbull
    brocktonbull New Member
    2015 tundra
    Put them on Tuesday. Be careful of the 4x4 lettering because the strips are completely separate from the numbers. Also while removing, hit it with a hair dryer, it helps come off easier. Was curios so I took the truck to the car wash the next day to see if they would peel off. Never moved. I did blow dry them for about 5 min after I finished cause it was chilly that day but no problem/ movement whatsoever
  5. Apr 4, 2019 at 3:20 PM
    #65
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Really I just taped one side where I thought it looked good. Measured and hit those measurements on the other side. They are pretty spot on but I wouldn’t sweat it to much. Nobody can see both sides at the same time.
  6. Apr 4, 2019 at 3:25 PM
    #66
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    I just got one side where I thought it looked good and used the vertical body line behind the taillight to position the other one the same while just eyeballing the distance between the top of the vinyl and the top of the bed. As @BTBAKER said, don't sweat it if they don't match up down to the millimeter. Nobody, yourself included, will ever know.
    PapaGrizz[QUOTED] and BTBAKER like this.
  7. Apr 4, 2019 at 7:52 PM
    #67
    PapaGrizz
    PapaGrizz MGM CRÜE
    Derek
    Spokane Valley, WA
    2016 MGM Tundra TRD Off Road Crewmax
  8. Apr 4, 2019 at 8:37 PM
    #68
    DecalsByDesign
    DecalsByDesign [OP] Vinyl Connoisseur
    Eagle, CO
    2019 Quicksand Limited Double Cab
    Toytec Performance Aluma 2.5 Kit Nitto G2 295/70-18 Method MR306 18x9 +18 Kenwood DDX6906s Carven TR Muffler w/ Y-Pipe
    Glad to here! No problem.
    Sand is never pleasant with anything but mine held up for 2 years with inferior vinyl and install. The new layout I have is much more precise. Not available currently unfortunately.
    Thats good to hear, I love quality updated. Everything looks good the second you put it on. What does it look like later though. Post heating is the key to longevity! good work man.
    Spitfire[QUOTED] likes this.
  9. Sep 14, 2019 at 12:13 PM
    #69
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
  10. Sep 14, 2019 at 1:24 PM
    #70
    DecalsByDesign
    Eagle, CO
