Discussion in 'General Tundra Discussion' started by Jrharvey02, Sep 14, 2019.
  1. Sep 14, 2019 at 10:40 AM
    Jrharvey02
    Jrharvey02 [OP] New Member
    Watt maker likes this.
  2. Sep 14, 2019 at 10:52 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    You can pickup stock leaf pack from someone who removed theres for pretty cheap. Yours looks to be modified by that last leaf though
    rebmo, Black Wolf and Jrharvey02[OP] like this.
  3. Sep 14, 2019 at 11:28 AM
    GiantsFanDan
    2007+ leafs will work. No difference between truck trims on the leaf springs. Just shocks are different on TRD based trucks.
    AKJ78, Rica25, 15whtrd and 1 other person like this.
  4. Sep 14, 2019 at 11:30 AM
    15whtrd
    15whtrd Mr. Blonde
    Should work no problem. Spring rates from my knowledge, are all the same for the leaves/years/trim.
  5. Sep 14, 2019 at 11:36 AM
    GiantsFanDan
    This is a stock leaf pack. You're missing one leaf so your current leaf pack has be modified.
  6. Sep 14, 2019 at 12:25 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah, looks to me like you are missing one.
    Rica25 likes this.
  7. Sep 14, 2019 at 1:21 PM
    15whtrd
    15whtrd Mr. Blonde
    Hell yeah! I wouldn’t want to replace just one leaf pack. Just as I wouldn’t replace only a left shock if they were both old but one was leaking.
  8. Sep 14, 2019 at 1:44 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    A little JB Weld and that should be fine:rolleyes:
    TXTundra2722 likes this.
  9. Sep 14, 2019 at 2:07 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Take it back. Unless you plan on a lot of headache and having to change the other side
  10. Sep 14, 2019 at 2:13 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    If you got both sides from and '18, install and run them. No reason they shouldnt be just fine.
    landphil, Bprose and 15whtrd like this.
  11. Sep 14, 2019 at 2:14 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Interesting for sure. I'd have to think you need to do the other side
  12. Sep 14, 2019 at 2:16 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Go for it. Let us know if the ride changes. Thought you had only gotten one side
  13. Sep 14, 2019 at 2:24 PM
    Nm6300'asl
    2022 DC SR5 4x4
    They will work just fine. If the original leaf pack had 5 springs and was oem, toyota changed speca to 4 for cost savings or it was due to the adoption of sae j2807 that happened in 13 or 14(?) And lowerd payload ratings across the board. The chassis is the same from an '07.
    ColoradoTJ, 831Tun and Jrharvey02[OP] like this.
  14. Sep 14, 2019 at 2:32 PM
    15whtrd
    15whtrd Mr. Blonde
    That goes towards the front. And confirmed my truck has only four layers instead of five like yours. But it should bolt right in. This will be the first I’ve heard of it not working. Seems like quite a few guys around here have bought newer springs and installed them on there 07 to 13
  15. Sep 14, 2019 at 2:33 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Cup up front. Don’t think it matters left or right
    Jrharvey02[OP] likes this.
  16. Sep 14, 2019 at 2:34 PM
    15whtrd
    15whtrd Mr. Blonde
    Also sorry I’m unsure if there is specific left and right. I would probably set the springs next to each other and see if they are identical. If one seems to have a little more arc to it, probably put that on the driver side to account for the gas tank?
    TRD15559 likes this.
  17. Sep 14, 2019 at 2:39 PM
    15whtrd
    15whtrd Mr. Blonde
    I always hate that stuff, but I’m pretty sure that means driver-side. I guess unless you’re looking at it with the hood open LOL
  18. Sep 14, 2019 at 2:40 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Only in England and places they drive on the wrong side of the road
  19. Sep 14, 2019 at 2:45 PM
    15whtrd
    15whtrd Mr. Blonde
    Well for reference my pro shocks have a left side and right side for the front. The left goes on the driver side.
  20. Sep 14, 2019 at 2:56 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Yes, left is drivers side
    Jrharvey02[OP] and 15whtrd like this.
  21. Sep 14, 2019 at 4:14 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    2012 CM with a 4 leaf pack (3+ overload).
  22. Sep 14, 2019 at 5:49 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    That is called a shackle. They are replaceable, they can be stock height or provide lift depending on what you buy.
    15whtrd likes this.
  23. Sep 14, 2019 at 6:14 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    10 deep breaths man....have a beer.
    You got this
    15whtrd, Jrharvey02[OP] and Pinay like this.
  24. Sep 14, 2019 at 6:20 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Lots of guys here just got some new coach builder shackles. Maybe someone in your area has their old set. If you can wait two weeks (going out of country) I’ll send you mine for free.
  25. Sep 14, 2019 at 6:23 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Do the new shackles come w the bushing in tact? If so you can probably cut that lower bolt off and just go buy a bolt
  26. Sep 14, 2019 at 6:36 PM
    Jrharvey02
  27. Sep 14, 2019 at 6:39 PM
    Pudge
    CT
    I think there is a Denver or CO specific thread or subforum on here you could post an SOS message in.
    Also maybe someone can put a link to this thread on a tundra Facebook page with people local to you
    I feel like there are a ton of people here with tundras in your area. I also feel like someone will come thru for you. I hope it works out, I'm 3000 miles away and wish I could help
    Pinay and Jrharvey02[OP] like this.
  28. Sep 14, 2019 at 6:50 PM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    I have some stocks. But i am no where near you. Good luck
  29. Sep 14, 2019 at 6:52 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Worst case, grab a sawzall and cut that thing out.
  30. Sep 14, 2019 at 6:59 PM
    Rubberdown
    Rubberdown Spilling my guts here.
    Dremel and a cut off wheel. Or ten cut off wheels. Cut the leaf, and then the bushing. I’d hit it from two sides with the cutting disc so it will easily come apart.
    Seriously, it’ll be easy. Don’t stress. Sleep on it, cut it out in the morning. Although I personally would soak it with PB blaster tonight, lay it on its side under your truck, put a couple concrete blocks under it to shim it, put my bottle jack under the truck with one side pressing on seized shackle bolt, other side against frame and use it as a press to push it out. (Or put it in a press but I don’t have one.)
