DIY: Rear Differential Breather Mod
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, May 25, 2016.
  1. Aug 22, 2019 at 11:54 AM
    #181
    coTony
    Tony
    Montrose, CO
    Isn't this the same breather that is removed from the rear end? Just use the one you take off
  2. Aug 22, 2019 at 11:57 AM
    #182
    RBDTx
    RBDTx New Member
    2019 Tundra TRD Pro White
    For more information go look at the 32 page thread on the same topic at TacomaWorld....
    JDL17CM4x4 and 15whtrd like this.
  3. Aug 23, 2019 at 6:51 AM
    #183
    coTony
    Tony
    Montrose, CO
    That link takes you to the site but not the thread
  4. Aug 23, 2019 at 8:24 AM
    #184
    RBDTx
    RBDTx New Member
  5. Aug 23, 2019 at 9:18 AM
    #185
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I would advise against using teflon tape on this fine of a thread. And even more so with it being a hot metal with oil. The threads are M10-1.0mm and the tape isn't going to do much of anything. After the pumpkin heats up, that tape will soften and the threads can move. Look at your factory breather, no tape. If you want a threadlock, use a single drop of 242 on it. But clean the surfaces of both parts well. Threadlocker doesn't adhere well to oil, grease and dirt.
    Skew12 likes this.
  6. Aug 23, 2019 at 11:15 AM
    #186
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
  7. Sep 14, 2019 at 7:14 AM
    #187
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Stupid question but is anyone worried about having a higher pressure drop between the diff and vent/breather due to the longer hose and filter (if using)? There was a theory in the discussion on the rear diff weep that one potential cause is the stock vent is too small and the diff leaks because it pressures up due to not being able to vent quickly enough. I'm not saying they're right, just thinking about this mod and wondering if it carries any risk of exacerbating that issue. Thanks and sorry for my ignorance.
    TTund16 likes this.
  8. Sep 14, 2019 at 9:18 AM
    #188
    Tundy White
    Tundy White New Member
    Jesse
    Ontario, Canada
    13 DCOR
    Levelled and Debadged
    I did mine up into the driver side rear taillight just over a year ago. Did it because I have a couple of creek crossings I make on a yearly basis for camping/hunting plus whatever puddles I get into while trailing around Ontario. Just changed my rear diff oil a few months ago... no water and turned out the oil was perfect and probably didn't need to be changed.... derp:facepalm:.
    Living in salt/bryne country and with the rear axle getting submerged at least a few times a year I have had 0 issues/problems. I agree that people are overthinking this... it's just a vent to relieve some pressure and if you are going to dunk the rear axle you don't want water getting in.... just my 2cents
  9. Sep 18, 2019 at 6:50 AM
    #189
    Fuzzytowel
    Fuzzytowel New Member
    Kiddnapped Tundra and Jeff_1974 like this.
  10. Sep 21, 2019 at 5:36 PM
    #190
    RBDTx
    RBDTx New Member
    For those who still wonder, consider the following, in addition to the pressure differential question raised by 223 (personally I do not see how the several foot difference could affect the pressures enough to make a practical difference):
    Why did Toyota include a one way “vent” on the rear if a “breather” is appropriate?
    If you do the mod but use the factory “vent” (as opposed to a two way “breather”), what have you added to the system by including a hose connection?
    Why do some Toyota differential “vents” or “breathers” allow air to pass one way only and others both ways.
  11. Sep 25, 2019 at 5:53 PM
    #191
    Fozzy360
    Fozzy360 New Member
    Hunter
    Virginia
    2010 Tundra Crewmax Limited
    Stock
    Next mod
  12. Jan 3, 2020 at 4:20 PM
    #192
    Jrharvey02
    Jrharvey02 New Member
    Anybody in the Denver area have their old rear diff breather valve? Mines busted and no dealer in the state has in stock...
  13. Jan 3, 2020 at 4:24 PM
    #193
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  14. Jan 3, 2020 at 9:00 PM
    #194
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    Simple question. Did the OEM vent that you pulled from the diff seen a lot more “loose” than the new breather (90930-03136)?
    Just from a visual inspection, I don’t see how the new “breather” (90930-03136) would allow much airflow when needed.
    The silver cap on mine is very tight.
  15. Mar 11, 2020 at 5:24 AM
    #195
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    It was asked earlier, but didn’t get a reply and I wanted to try again.
    What is the benefit of running a 2-way breather and filter over just a filter? I just can’t picture the benefit of a 2-way breather over an open line, assuming both have a filter.
  16. Mar 24, 2020 at 11:28 AM
    #196
    Paxrom
    Paxrom New Member
    2020 Tundra SR5
    Leds
    if the original vent is only venting (net positive pressure) how does water even get in? Also the problem with the two way breather mod is that sucking in moisture from ambient air that will eventually accumulate in the diff. There's a reason why oil temp need to reach operating temperature before you shut down the engine. Unless proven otherwise I'm going to assume all of these mods are completely a waste of time and potentially detrimental in the long run.
    TTund16 likes this.
  17. Mar 24, 2020 at 11:55 AM
    #197
    AZBoatHauler
    So.Arizona
    I'm not a physicist, but logic tells me the vent does not go from open to 100% sealed and closed instantaneously. Also, I think a submerged open vent with little to moderate pressure would still allow water infiltration. My thinking is these vents work like a dry snorkel... you can probably keep most of the water out but maybe not all of it. The other concern is rapidly cooling the diff fluid by submerging the rear axle in cool water potentially creating a vacuum. You would then be relying upon a submerged vent seal to be good enough to prevent sucking in water.
    I join you not advocating use of an open or two-way breather. I attached a standard type breather vent to the hose behind my taillight assembly.
    Bottom line, if extending the breather valves to a higher location was detrimental, why would Toyota do it for the front diff and t-case on 4x4 models?
    mech_engineer09 and abomb60 like this.
  18. Mar 24, 2020 at 12:27 PM
    #198
    Paxrom
    Paxrom New Member
    2020 Tundra SR5
    Leds
    That depends on the axel seal design. If the diff seal were design to run with a slight positive pressure then that's what it is. The transfercase and front diff mostlikely use traditional seal where atmospheric pressure is needed. So by running a two way mod that pressure is no longer there and again can also cause problems for the seals from preventing water intrusion from the outside. Extending the diff tube with the same one way valve is undoubtedly a waste of time regardless whether or not you believe in the positive pressure seals.
  19. Mar 24, 2020 at 12:37 PM
    #199
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Not a physicist either but how could the valve possibly be one way? Isn't the issue here about how air get's into the diff when it is suddenly cooled by a water crossing, puddle, etc and causing the air inside to cool creating a vacuum and air to flow from outside into the differential? Why would moving the source of this air from the top of the differential to a source higher up not improve this scenario?
  20. Mar 24, 2020 at 12:40 PM
    #200
    abomb60
    Massachusetts
    I'll be pulling mine off in the next few days (probably this weekend) when I run the diff breather extension so you're welcome to it if you want to cover shipping. Off a 2018 with about 13k on it.
    Jrharvey02[QUOTED] likes this.
  21. Mar 24, 2020 at 12:48 PM
    #201
    Paxrom
    Paxrom New Member
    2020 Tundra SR5
    Leds
    So the vent is a spring loaded rubber gasket design. The spring presses on the seal at a certain force measured by its spring constant. When the expanding gas exceed the spring force it vents. This spring pushing down on the rubber gasket also prevent cooler ambient air and water from entering. This is why the differential vacuum theory makes even less sense to reduce the diff positive pressure that is pushing against the bearing seal to keep water out. Under submersion this one way valve gain a net negative spring pressure (more force pushing on rubber gasket) and allows the diff to maintain its positive pressure. As for your mod when moving it up higher this doesn't change the dynamic so much as it is a waste of time as stated earlier.
  22. Mar 24, 2020 at 12:51 PM
    #202
    abomb60
    Massachusetts
    It absolutely is not a spring loaded rubber gasket design ... have one in my hand now for the extension mod and if you shake it the metal cap on the end rattles. Also from my amateur testing it allows air in and out and for the most part is an open breather design with the metal cap being nothing more than a cover to keep stuff out.
  23. Mar 24, 2020 at 12:52 PM
    #203
    AZBoatHauler
    So.Arizona
    According to Toyota, the breather is the same part number whether it is front or rear.
    Part Number: 9093003097
    Supersession(s): 90930-03097
    BREATHER (FOR FRONT AXLE); BREATHER (FOR FRONT DIFFERENTIAL); BREATHER (FOR REAR AXLE).
    Fits Tundra (2007 - 2012)
    https://parts.deserttoyota.com/p/To...igin=pla&partnerDevice=c&userLocation=9051700
  24. Mar 24, 2020 at 12:54 PM
    #204
    abomb60
    Massachusetts
    AZBoatHauler[QUOTED] likes this.
  25. Mar 24, 2020 at 12:58 PM
    #205
    Paxrom
    Paxrom New Member
    2020 Tundra SR5
    Leds
    Not sure if they have a different design between your model year but I have the 2020 model and it has a spring loaded design.
  26. Mar 24, 2020 at 1:00 PM
    #206
    abomb60
    Massachusetts
    Well like the lack of a separate transmission cooler maybe Toyota redesigned the part and now you'll suck in water through your axles. I'm sure ToyotaCare will take care of it for you!
    Also here is the part number of the version with the barb for a hose. Even Toyota calls it a "breather" and not a valve. By design a breather will allow exchange both ways while a valve only allows flow in a single direction.
    https://www.sparksparts.com/oem-parts/toyota-plug-breather-9093003136
    Failure2comply likes this.
  27. Mar 24, 2020 at 1:12 PM
    #207
    Paxrom
    Paxrom New Member
    2020 Tundra SR5
    Leds
    Muh android auto apple CarPlay > than transcooler. I dont even get my bed dirty o_O. Just kidding though yeah I plan on doing the tranny mod later.
    If your rear diff is running a "breather" its definitely a good idea to move it higher. Else just leave the thing alone.
    TTund16 likes this.
  28. Mar 24, 2020 at 1:14 PM
    #208
    abomb60
    Massachusetts
    I would like Carplay but it's cheaper and better to go aftermarket. Sorry bro but you have the same breather on your rear diff as my 2018 so if you're planning on leaving the mall parking lot you might want to get it out of the water :D
  29. Mar 24, 2020 at 1:19 PM
    #209
    Paxrom
    Paxrom New Member
    2020 Tundra SR5
    Leds
    Nope my diff valve is one way spring loaded, I checked with my tounge. I put 35s on my rough country lift for mall crawling thank you very much.:monocle:
  30. Mar 24, 2020 at 1:21 PM
    #210
    abomb60
    Massachusetts
    Well as long as you're happy I guess!
