Bigger brakes?
Discussion in 'General Tundra Discussion' started by Urbandalefirefighter, Sep 11, 2019.
  1. Sep 11, 2019 at 12:59 PM
    Urbandalefirefighter [OP] New Member
    Jackson Salter
    2011 Tundra Crewmax 4.6L 4x4
    Since purchasing my 2011 about 5 months ago, my only complaint besides some bed rust has been the less than adequate braking. I’m running 33s on 20s which shouldn’t make much difference. Has anyone put bigger breaks on their tundra? And what are your thoughts?
  2. Sep 11, 2019 at 1:02 PM
    GravityGear
    Aurora, CO
    When you say "less than adequate" what are you experiencing? Fade? Soft pedal? ABS pulsing?
  3. Sep 11, 2019 at 1:06 PM
    Jackson Salter
    They feel soft. Have to push quite a bit harder on the pedal than I feel that I should have to. No grinding, squeaking, or uneven breaking though.
  4. Sep 11, 2019 at 1:08 PM
    GravityGear
    Aurora, CO
    I would try bleeding out the old fluid first. There's a lot of components and things going on in a brake system. Start with the basic stuff before you drop 4k on brake parts.
    Tundyfundy, Mcoop and Kerch71 like this.
  5. Sep 13, 2019 at 2:23 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    TRD brake pads,
  6. Sep 13, 2019 at 2:58 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Tundras come with one the largest factory available brakes on a truck. If your brakes feel soft, you either have air in the lines , your fluid has moisture in it, your pads are shot, or your rotors are not properly glazed with the pad material to provide proper bite.
    Time for an overhaul.
    ColoradoTJ and Rex Kramer like this.
  7. Sep 13, 2019 at 4:51 AM
    Rubberdown
    Rubberdown Spilling my guts here.
    Yeah. Turn your rotors, new trd pads, bleed everything with fresh fluid, and then see where you are. They work pretty darn good generally.
    Tundyfundy and Rex Kramer like this.
  8. Sep 13, 2019 at 6:08 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    TRD Big Brake kit will put you through the windshield
