SoCal sun too much for soft tonneau?
Discussion in 'Tonneau Covers, Caps and Shells' started by Big J, Jul 28, 2019.
  1. Jul 28, 2019 at 11:45 AM
    Big J
    Big J [OP] New Member
    2020 4x4 crewmax
    Was looking at tonneau covers and the dude at the sales place said out here in southern California the soft ones get killed by the sun. He recommended a hard tonneau as a result. Never heard this before, so wanted to ask if any of you in the area had this proble . :confused:
  2. Jul 28, 2019 at 11:50 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Direct sun or UV on any vinyl or fabric is going to degrade it, shorten its life and weather it at minimum. If garage kept or under cover it will last much longer.
    Fishman57, TheBeast and Big J[OP] like this.
  3. Jul 28, 2019 at 11:57 AM
    Big J
    2020 4x4 crewmax
  4. Jul 28, 2019 at 12:41 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    If in doubt about the sun being TOO much for your soft cover, you could try keeping it coated with Aerospace 303. It helps prevent sun-damage:thumbsup:
    plumber802 and Big J[QUOTED][OP] like this.
  5. Jul 28, 2019 at 1:52 PM
    Trooper2
    JR
    Probably be much happier with something like this in the long run. Most softies should last 3-5 years....
    Big J[QUOTED][OP] likes this.
  6. Jul 28, 2019 at 4:11 PM
    Big J
    2020 4x4 crewmax
    Thanks for the input guys. Anyone know of any cheaper hard covers?
  7. Sep 3, 2019 at 1:12 PM
    08crewmax
    08crewmax New Member
    CA
    ‘08 Pyrite Mica Crewmax Limited
    I have a Tyger that came with the truck when I purchased it. The cover is 11 years old and is still very nice. Pretty much water proof, just need to make sure you get it centered correctly when putting it on.
    B737 and Big J[OP] like this.
  8. Sep 13, 2019 at 2:52 AM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    This is what I do ^^^. The amount of sun we get here in northern Vermont can't be compared to SoCal sun though.
