Downsizing tires
Discussion in 'Wheels & Tires' started by Wautaush68, Sep 11, 2019.
  1. Sep 11, 2019 at 8:26 AM
    Wautaush68
    Wautaush68 [OP] New Member
    2015 tundra crewmax 2wd
    Can I downsize tires on my 2015 tundra crewmax from 255/70/18
  2. Sep 11, 2019 at 8:31 AM
    cnoyes72
    cnoyes72 New Member
    CT
    2018 Tundra SR5 DoubleCab 4x4
    Driver-side assist handle, extang trifect 2.0 tonneau cover
    With the same 18inch rim? Why would you want to do that?
  3. Sep 11, 2019 at 9:15 AM
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    You have a 32" tire (32.1" to be exact). What are you trying to accomplish? Thinner? Shorter height?
  4. Sep 11, 2019 at 11:36 AM
    Wautaush68
    Trying to lower entry height me n most my passengers have trouble climbing up
  5. Sep 11, 2019 at 11:39 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Running boards?
    cnoyes72 and Medic343 like this.
  6. Sep 11, 2019 at 11:42 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Downsizing tires may only get you an inch or so. Much cheaper and probably better than changing stock tire sizes to get side steps/running boards...
  7. Sep 11, 2019 at 11:48 AM
    JimboSlice413
    Bakersfield
    My little ones and my dogs have no problem getting in with these on. Drop some money on boards instead of tires, you'll be much happier.
    Also, if you want a little more clearance for a camping trip you can pull them off pretty easily. Can't do that with smaller tires
    Bakelite and Medic343 like this.
  8. Sep 11, 2019 at 12:34 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    jlocust likes this.
  9. Sep 11, 2019 at 1:17 PM
    JimboSlice413
    Bakersfield
  10. Sep 11, 2019 at 1:17 PM
    Wautaush68
    Thanx jimbo but I already have those. Maybe I should have mentioned I'm 69yrs ol with 2 bad hips. I do carry a portable stool for my passengers.
  11. Sep 11, 2019 at 1:18 PM
    Rex Kramer
    Georgia
    Just the rear, the front in stock.
    The tires dropped the whole truck.
  12. Sep 11, 2019 at 1:20 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    255s are kinda skinny on a truck with heavy curb weight, that said I had 255s on my Tacoma and I loved them. They were great in the snow.
    Since you're 2wd, you should be able to lower your truck a couple inches pretty easily and inexpensively. I'd look into that then tires. Lowered tundras look so bad ass in my opinion.
    15whtrd and Rex Kramer like this.
  13. Sep 11, 2019 at 1:23 PM
    Wautaush68
    Rex it's not lowered. Only use as transportation. Don't really know the height of 255/70/18 I'm running now. Just gathering info on some options...New tires in the near future. Thanx guys I'm LISTENING
    15whtrd likes this.
  14. Sep 11, 2019 at 1:28 PM
    JimboSlice413
    Bakersfield
    Gotcha, that's challenging for sure. Rex's truck looks pretty nice. Maybe lowering the back to level and putting on 31's would do the trick
  15. Sep 11, 2019 at 1:29 PM
    McMason
    McMason New Member
    Scott
    Boise, Idaho
    2019 TRDOR CM Cement
    I don't know that a tire change would be your best value option. Keep in mind you'd have to go with a tire that's 2 full inches shorter to gain one inch of access. Aside from getting some comically small wheels, maybe cabin adjustable air bags?
    Wautaush68[OP] likes this.
  16. Sep 11, 2019 at 1:31 PM
    Rex Kramer
    Georgia
    You shouldn't 'need' to lower your trucks rear suspension, especially if you have a longer wheel base. I lowered mine for improved handling, and to level the trucks stance. My 82 year old mom appreciates the reduced height, and the steps.
    The tires on your truck right now are 32", switching to 31" will lower the truck a bit all the way around.
  17. Sep 11, 2019 at 1:48 PM
    Wautaush68
    And what the tire size numbers for a 31"
    Rex Kramer likes this.
  18. Sep 11, 2019 at 1:58 PM
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    Play around with the config:
  19. Sep 11, 2019 at 2:05 PM
    Rex Kramer
    Georgia
  20. Sep 11, 2019 at 3:52 PM
    SunTundra413
    SunTundra413 New Member
    Ned
    Massachusetts
    2019 Black TRD Sport DC 4X4
    ARE Cap
    Michelin has a few offerings in smaller sizes like 235/55R18 and 235/65R18. These would be in the neighborhood of 28.4" tall according to the Michelin website. That should make a noticeable difference coming from a 32" tall tire.
    I'm considering getting snow tires in this size for the winter.
  21. Sep 11, 2019 at 4:39 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    I put Lamborghini doors on that Es-ca-lade,
    Low pro so look like I'm riding on blades
  22. Sep 11, 2019 at 7:37 PM
    Wautaush68
    New member wautaush1968 thank y'all. The tire size calculator was enlightening. Will start with 31" tire. Although I am curious about the cost of lowering it
  23. Sep 12, 2019 at 2:42 AM
    Rex Kramer
    Georgia
  24. Sep 12, 2019 at 5:10 AM
    jlocust
    jlocust New Member
    Portland, OR
    2023 Lunar Rock TRD Offroad
    Rex Kramer[QUOTED] likes this.
  25. Sep 12, 2019 at 5:15 AM
    Rex Kramer
    Georgia
    Indeed it is, and the smaller tires make the 4.30 gear perform like it has a 4.55 gear.
