Hub rings
Discussion in 'Wheels & Tires' started by Spolar, May 23, 2017.
  1. May 24, 2017 at 7:13 AM
    NickyF25
    NickyF25 New Member
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    I went with the SR8's. Liked that there are hub centric and look great.
  2. May 24, 2017 at 10:24 AM
    TheBeast
    TheBeast The Beach
    we should list all the Tundra wheels that are 110mm: so far I got RW wheels :)..are the SCS 110mm ? I don't see the specs on their site.
  3. May 24, 2017 at 10:37 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  4. May 24, 2017 at 10:45 AM
    csuviper
    Broomfield, CO
  5. May 24, 2017 at 11:25 AM
    NickyF25
    NickyF25 New Member
    SE Pa
    I seem to recall the spec label on my SR8 boxes said 110.1, but I dropped them off yesterday at the shop doing the install so I can't double check right now.
    TheBeast[QUOTED] likes this.
  6. May 24, 2017 at 11:31 AM
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    Submarine sammich
  7. May 24, 2017 at 11:42 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    the only thing that I have ever seen from Toyota is the RW wheel spec from TRD USA, which is 110mm
    As far as I am concerned the hub bore is 110, unless someone can show us something else from Toyota that shows otherwise.
  8. May 24, 2017 at 12:37 PM
    csuviper
    Broomfield, CO
    The Rock Warrior Wheels fit on the 2014+ Tundras so it has to be 110mm.
    osidepunker likes this.
  9. Sep 10, 2019 at 10:52 PM
    NoaSeb
    NoaSeb New Member
    2013 pyrite mica TRD
    Pro comp 32 wheels
    2013 TRD. Bought 18 in Pro Comp 32 Bandidos on BFG KO2s. Had a terrible steering wheel shake with multiple balancing. 4WP has no clue about what they sell and they’re work.
    Bought aluminum hub centric rings (114.3-110) from USwheeladapters.com per a lot of forum suggestions. It totally got rid of the steering wheel wobble. The thought makes sense and it shows for myself. I don’t really post anything anywhere. But considering I struggled with this for a long time. I think sharing my experience can support making that purchase. Good luck.
