Shaking on braking at higher speeds
Discussion in '2nd Gen Tundras (2007-2013)' started by TurboGoKart, Sep 7, 2019.
  1. Sep 7, 2019 at 6:07 PM
    TurboGoKart
    TurboGoKart [OP] New Member
    So my new to me DC does this dumb thing; at highway speeds if I hit the brakes hard at all, it shakes/shimmies pretty bad. Definitely feels like it’s coming from the rear but it’s enough to make the steering wheel shake some.
    Doesn’t do it at lower speeds, drives smooth, accelerates smooth. Feels like it would when you have warped rotors but the dealer I got it from has paperwork that they replaced all 4 corners. I’ll tale a look at the rotors when I get home, maybe they only did pads.
    Any ideas?
    Rica25 likes this.
  2. Sep 7, 2019 at 6:12 PM
    Rica25
    Ricardo
    Tulare
    Sounds like rotors specially if only vibration when braking
  3. Sep 7, 2019 at 6:31 PM
    TurboGoKart
    That was my initial thought too.
    Just checked the rear rotors and they’re definitely new, can still see the cross hatch on them lol. New pads too. It’s strange. I’ve never had a set of rotors come warped from the factory, but anything’s possible I suppose.
    Rica25 likes this.
  4. Sep 7, 2019 at 6:32 PM
    Rica25
    Ricardo
    Tulare
    How many miles since you bought the truck
  5. Sep 7, 2019 at 6:48 PM
    TurboGoKart
    2-300. Dunno if it’s done it since I owned it, I just noticed it tonight when I had to brake harder at highway speed.
    The TPMS light gives me fits too, randomly blinking, sometimes staying on, sometimes going off. Pressures are good, figured I’d address that when I get new wheels/tires when I lift it haha.
    Rica25[QUOTED] likes this.
  6. Sep 7, 2019 at 6:50 PM
    Rica25
    Ricardo
    Tulare
    I would take back to the dealer specially if you bought at Toyota dealer
  7. Sep 7, 2019 at 6:51 PM
    Rica25
    Ricardo
    Tulare
    Would also ask for what was done when they did the inspection
  8. Sep 7, 2019 at 6:56 PM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    Warped rotors.
    Rica25 likes this.
  9. Sep 7, 2019 at 7:00 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Also check for wheel balance or warped wheels..
    Kerch71 and Rica25 like this.
  10. Sep 7, 2019 at 7:08 PM
    TurboGoKart
    Was a Chevy dealer lolz. Think I have some paperwork they gave me with what they did. The previous owner worked for Toyota. Not that that means much, but it seems it was well taken care of.
  11. Sep 7, 2019 at 7:09 PM
    TurboGoKart
    I thought about that too, but it drives so smooth I kinda ruled it out. Would not hurt to have Discount Tire verify wheel balance though.
    Rica25 likes this.
  12. Sep 7, 2019 at 7:09 PM
    TurboGoKart
    Can still see cross hatch on the rotors though. But that was my initial thought as well.
    Rica25 likes this.
  13. Sep 7, 2019 at 7:15 PM
    CourtJester
    Alabama
    They can get heated up and warp before the cross hatch is gone.
    I went through deals gap in my old F150 several years ago about a month after I bought it. I did take it harder than I should have with a bike on a trailer, but the rotors were warped with 2500 miles on a brand new truck.
    If it shutters when you hit the breaks; it’s what the breaks are catching or how the breaks are catching. More likely what they are catching.
    Warper rotors.
    TurboGoKart[OP] and Rica25 like this.
  14. Sep 7, 2019 at 8:05 PM
    TurboGoKart
    Good info! I wonder if it’s more cost efficient to have them turned since they’re so new or just say eff it and grab a new pair. Lol.
    Rica25 likes this.
  15. Sep 7, 2019 at 8:09 PM
    FXFormat
    FXFormat New Member
    During hard braking if you feel it in the steering wheel, front rotors are warped, if you feel it in the pedal, rear rotors are warped...feel it in both, you car's jacked up.
    Rica25 likes this.
  16. Sep 7, 2019 at 8:10 PM
    TurboGoKart
    Rica25 likes this.
  17. Sep 7, 2019 at 8:18 PM
    CourtJester
    Alabama
    Just my opinion; Replace them.
    I work in steel. Metal holds a standard within its molecular structure. If it’s warped, it has a weakness that allows a deformation when hot that allows it to expand or holds it tighter. If it’s weak or strong now, it will be weak or strong at its base after it’s turned down.
    It’s within the steel.
    Rica25, Kerch71, AKJ78 and 1 other person like this.
  18. Sep 7, 2019 at 9:41 PM
    15whtrd
    15whtrd Mr. Blonde
    I suggest trying the break-in procedure all over again. It was probably never performed. I like to do something like, three fast stops from 35 to 10 mph. Then from say, 45 or 50 down to 20 about as hard as I can 3-5 times Then bring it home and park it. Let the brakes completely cool off before driving again. What you are doing, is leaving some pad material on the rotors so that they will stop evenly. It’s worth a shot to try.
    saybng, Rica25, Pinay and 2 others like this.
  19. Sep 8, 2019 at 10:14 AM
    TurboGoKart
    Think I found the source. Looks like the slide pins weren’t greased up properly or the caliper is sticking. This was the driver’s side pads. Also found out the e-brake was never adjusted. Are these auto adjust in the rear? Or do you need to set them first? No e-brake pressure.
    saybng and 15whtrd like this.
  20. Sep 8, 2019 at 10:23 AM
    15whtrd
    15whtrd Mr. Blonde
    Front pads?
  21. Sep 8, 2019 at 10:31 AM
    TurboGoKart
    Rears, sorry.
    Rica25 and 15whtrd[QUOTED] like this.
  22. Sep 8, 2019 at 10:35 AM
    TurboGoKart
    Looked at the service manual for e-brake adjustment. Easy peasy.
    1. Put rotor on, e-brake not engaged at the pedal.
    2. Install lug nuts to keep rotor centered.
    3. Move the adjuster wheel (thru hole in rotor, with a screwdriver) UP (looking at the rear of the wheel, that’s clockwise).
    4. Lock the shoes out, and move the adjuster back DOWN 8 notches).
    5. Install remaining brakes/wheel.
    6. Check pedal operation, should engage at 6-9 clicks. If not, adjust cable under truck where the one e-brake cable goes into 2. Re-test; shooting for that 6-9 click engagement.
    Rica25, ryanwgregg and 15whtrd like this.
  23. Sep 8, 2019 at 11:47 AM
    kgb4187
    kgb4187 New Member
    Not always. My steering wheel shook pretty bad when slowing down from high speeds. Noticed the rear rotor looked pretty messed up so I put new pads and rotors on the back and it went away.
    TurboGoKart[OP] likes this.
  24. Sep 8, 2019 at 12:15 PM
    TurboGoKart
    Yeah. USUALLY that’s the rule of thumb; if your steering wheel shakes it’s the fronts. But when it feels like it’s coming from your ass, and THEN the steering wheel shakes, it’s usually the rear end. Lol.
    Rica25 and kgb4187 like this.
  25. Sep 9, 2019 at 6:41 PM
    TurboGoKart
    UPDATE: After seeing the drivers side brake pads above, I opted to clean the slide pins on both calipers really well and regrease them. Replaced the pads on both sides (even though they were newww), and set the e-brake shoes the correct way.
    No more shaking!! At least for now. Downside is, I found out that the e-brake cable needs to be adjusted where they both connect to the pedal cable. Didn’t bother with that right now because my ToyTec lift should be here in a week or two and I’ll have to extend them anyways.
    saybng likes this.
  26. Sep 9, 2019 at 7:56 PM
    I'm having the same issue. What did you use to grease the pins?
  27. Sep 9, 2019 at 8:05 PM
    TurboGoKart
    Standard brake component grease. Can be found at any auto store. I cleaned the slide pins with brake clean, and took a wire wheel on a drill to them to knock down any standing rust. Also cleaned out the holes in the caliper bracket where they go, lightly sanded those out, and cleaned it with brake clean again. That’s typically what I do on every brake job, just keeps things lasting for longer and operating correctly.
    Rica25 likes this.
  28. Sep 9, 2019 at 8:05 PM
    TurboGoKart
    High temp wheel bearing grease will work well too, but the brake component grease tends to stick around a bit longer.
    Rica25 likes this.
  29. Sep 9, 2019 at 8:12 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Rica25 likes this.
