Cooper AT3 4S, Bad Experience-Check your tires
Discussion in 'Wheels & Tires' started by kparrow, Sep 7, 2019.
  1. Sep 7, 2019 at 4:17 PM
    kparrow
    kparrow [OP] New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Fair warning to all about the Cooper AT3 4S. I took them off the truck today because I could no longer trust them. In 18,000 miles I had 3 punctures, 2 of which were unrepairable.
    The last straw was today, started leaking out of nowhere in the middle of the tread in a single tread block. It was worn smooth while the others were not and it had a slight bubble to it. Got back to Discount Tire where I bought them and they got it off, told me it had internally ripped 2.5” straight down the middle through the belt package. Could have blown out on me with tires that were only a year old! GET THEM OFF MY TRUCK!!!!!
    Discount Tire is AWESOME!!!! I can not recommend them enough. Always always always buy the road hazard certificates guys and gals. $26ish bucks a tire replaced my first $220 tire for $26ish bucks and today it got me another $240 tire for the same $26 bucks. They prorated me $113 back per tire for the other 3.
    Went with a tire they stock at all times and don’t have to order, Goodyear Ultraterrain AT in an E rated LT275/70/r18. Time will tell but I’m happy!!!! I walked out the door for $600 and change.
    Beyond impressed with the service and help from Discount Tire and again.....ALWAYS buy those certificates everyone, they’ll save your ass!
    EDIT: I’ve not given up on Cooper and would be willing to try the XLT, I just don’t think I’d give the 4S another shot, just my opinion. The P Rating wasn’t enough, again only my opinion, and I’d rather have an E rated LT. Also if it helps the two managers at Discount said they were all wearing a bit weird in addition to the center rib tear so something wasn’t right with them I don’t think. Not given up on Cooper, just not for me at the moment. I’ve always had Cooper tires on my cars and have always loved them.
    Here’s some pics of the new kicks, what y’all think?
    BF52E1E5-62E5-4151-A780-A0099879CE84.jpg B0E58CC1-AB0A-4A2C-BE18-D8DBDC6350DB.jpg
    MTRock, Chucho, MAGDADDY and 12 others like this.
  2. Sep 7, 2019 at 4:27 PM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    You didn’t off-road with those other tires did you? Cooper has a pretty solid reputation so hopefully you just got a bad set. I understand though once you have an experience with one, it’s hard to trust them again.
    I’m interested in the ultra terrains, they look good. Not to burst your bubble but i did read a post on here recently about one of those ultra terrains chunking on a regular gravel road, so it can happen to them all!!! Good luck!!
    Truck looks sharp!
    Black Wolf and kparrow[OP] like this.
  3. Sep 7, 2019 at 5:01 PM
    kparrow
    Kevin
    Nampa, ID
    Took em off road twice and on nothing crazy. The guys at the tire place said they should have been fine. The biggest thing is they stock these. I wanted to try the AT3 XLT’s but they don’t stock those either. I live an hour and a half from Discount Tire so ordering and driving back and forth is a drag an not worth it. Have the certificates on them so honestly don’t mind having issues, but if they can get rectified without having to order the tire that is what I need. I don’t anticipate issues with the LT now though. Haven’t sworn off Cooper, just wont be getting the 4S version of the AT3 again for the truck
    Black Wolf likes this.
  4. Sep 7, 2019 at 7:56 PM
    Pawpaw01
    Pawpaw01 New Member
    Bruce
    2016 TRD Off Rd /BadAss Edition
    DOUBLE Roll Bar/w- Off Road LED Lighting . Front matching light Led Setup bar
    That’s what I’m rolling and there stupid good tires! F54608B1-A92F-4C2F-A4DD-C36F0F5090CD.jpgPulled me through 2 feet of snow, when all the other 4 Bys were stuck ! She handled like a BEAST! 7623A662-5DC0-4F93-9D4E-DE65ABC02A78.jpg
    equin, OR18TRD, MS22 and 2 others like this.
  5. Sep 7, 2019 at 7:58 PM
    Pawpaw01
    Pawpaw01 New Member
    Bruce
    So well , I put them on my new run about , 19 Ford Ranger!2534EC76-95DF-406F-9B95-5681BBE95052.jpg
    Toothpick, MS22 and kparrow[OP] like this.
  6. Sep 7, 2019 at 7:58 PM
    kparrow
    Kevin
    Nampa, ID
    Most excellent! Looking forward to testing em out during winter
  7. Sep 7, 2019 at 7:59 PM
    Pawpaw01
    Pawpaw01 New Member
    Bruce
    georgiey22, MS22 and kparrow[OP] like this.
  8. Sep 7, 2019 at 8:29 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I get that you had issues and it sounds like you ended up feeling unsafe on the tires but, I don’t think it’s logical to blame the tire for getting a puncture.
    You run over a nail it punctures the tire. Why blame the tire?
    Glad your store took care of you and yes, I always recommend my customers buy tires that we keep in stock.
    K02’s, Nittos, Goodyear’s, etc.
    We stock some coopers but only our DTC Exclusive ATP’s and HTP’s.
    Trooper2 and kparrow[OP] like this.
  9. Sep 7, 2019 at 8:35 PM
    Ford sucks...
    68 RS/SS, MTRock, Y0TA PR0 and 3 others like this.
  10. Sep 7, 2019 at 8:40 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    :puke:
  11. Sep 7, 2019 at 8:43 PM
    kparrow
    Kevin
    Nampa, ID
    That’s what I thought when I had the 1st one no big deal it was a screw, it happens. The second time it was a 7” piece of rebar, what tire wouldn’t loose that war. The 3rd time was just too much of a coincidence for me and having failed with no apparent external damage was the final straw for me. I had only had them a year and too many issues for me, and I certainly did not trust them. Didn’t seem to be very durable. Rotated religiously and checked pressure monthly. The XLT’s may be a different story but the p rated on the truck didn’t seem to be up to the challenge.
    It’s only my opinion, but I would steer clear of the 4S on a heavy vehicle. I’m still willing to give Cooper a shot, just needs to be an LT tire. Because I was locked into Discount Tire and couldn’t afford to wait for a tire order, swapped brands. Tire Rama is local in town and they are primarily a Cooper dealer, but I’m not a fan of them as a company. I LOVE Discount Tire and plan to stay loyal to them. Great service ALWAYS! They rock!
    BTBAKER likes this.
  12. Sep 7, 2019 at 9:19 PM
    BigRedFireEngine
    BigRedFireEngine New Member
    Toronto, Canada
    2016 Crewmax 1794 Edition in.... red.
    Extang Solid Fold 2.0 Trifold Tonneau, Go Rhino RB10 running boards, Kenwood DDX9905s
    OP, sorry to hear about your issues with the 4S, but I’m loving mine. Traction in rain and snow have been great. Also a pretty quiet tire. That said, I don’t think they could handle any serious off-roading. I’d move to the XLT for that.
    kparrow[OP] likes this.
  13. Sep 7, 2019 at 9:21 PM
    No need for a PSA...no tire is perfect...First complaint here about the 4S doesn't warrant it.....
  14. Sep 7, 2019 at 9:25 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    Please see signature!
    I just have regular Cooper AT3s on my Tacoma...
    Should I be worried?
  15. Sep 7, 2019 at 9:26 PM
    kparrow
    Kevin
    Nampa, ID
    Nah no need to worry
  16. Sep 7, 2019 at 9:28 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    Okay good, because I love those tires! Currently in the process of convincing my dad to put them on his 2018 GMC Yukon when he needs new tires...
  17. Sep 7, 2019 at 9:29 PM
    kparrow
    Kevin
    Nampa, ID
    I’ll modify the title, you’re right. I just had a bad experience. Want others to be aware of what could happen with the 4S.
  18. Sep 7, 2019 at 9:30 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    September 6th, 2019:
    Doylestown, Pennsylvania
  19. Sep 7, 2019 at 9:30 PM
    kparrow
    Kevin
    Nampa, ID
    The normal AT3 is on its way out I though no?
  20. Sep 7, 2019 at 9:30 PM
    Of course not!
  21. Sep 7, 2019 at 9:31 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    I just had mine installed in March, and at least two different tire places in my areas seem to stock them.
  22. Sep 7, 2019 at 9:31 PM
    There are three versions made by Cooper.
    kparrow[QUOTED][OP] likes this.
  23. Sep 7, 2019 at 9:33 PM
    kparrow
    Kevin
    Nampa, ID
    Gotcha. I know there is the original AT3, then the new ones are the AT3 4S, the AT3 LT, and the AT3 XLT right?
  24. Sep 7, 2019 at 9:34 PM
    You own a great set of tires Charlie....lots of fake news out there. Stick with us. Can't go wrong here:thumbsup:
  25. Sep 7, 2019 at 9:36 PM
    Correct. I'm seriously considering the XLT's, although the Maxx's and STT Pro's are on my radar since I've owned both.
  26. Sep 7, 2019 at 9:37 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    So I had them installed by my trusted independent mechanic because his price was the cheapest at the time. Unfortunately, because he has a small independent shop, he can't offer a road hazard warranty. Luckily, a nearby Mavis Discount Tire gave agave me a warranty on all of my tires for $72, when the tires already had 12K miles on them!
  27. Sep 7, 2019 at 9:41 PM
    Keep enjoying life Charlie! Can't imagine what it's like having ass burger, using your words. Keep posting Toyota pics you come across. We are following....:thumbsup:
    mtntop and kparrow[OP] like this.
  28. Sep 7, 2019 at 9:46 PM
    kparrow
    Kevin
    Nampa, ID
    Rock on Charlie! Keep the pics coming. I follow your thread, love seeing what ya come across!
  29. Sep 7, 2019 at 9:47 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    Thanks! I just added a beautiful blue 2000-2001 TRD that I spotted in the spectator lot at a car show today!
  30. Sep 7, 2019 at 9:48 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    CLICK HERE
