  1. Sep 4, 2019 at 6:58 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Has anyone experienced the fog lights are always on when the headlights/parking lights are on? I may need to re-address the wiring...any thoughts?!
  2. Sep 4, 2019 at 7:26 AM
    W///
    W/// New Member
    Greenville, SC
    2016 Barcelona Red Platinum
    Looks really good. Any updates on how you like the tires after a few days? I'm assuming you're on stock suspension correct?
  3. Sep 4, 2019 at 7:31 AM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    Not today, but a couple of days ago.
    Installed Full interior LED bulbs and some on the exterior.
  4. Sep 4, 2019 at 7:40 AM
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    Yes, stock suspension.
    Still experimenting, but so far so good. I've only put about 20 miles on them since I got them. Hard to say yet. They seem solid. Discount Tire had them at 35/40 and I though they seemed a little soft, so I started a thread on recommended tire pressure and also emailed Nitto for their recommendation. They recommended 40/47. Last night I put them to 40/44 and they seemed better. Still may adjust them, based on all the info.
    Other thread: https://www.tundras.com/threads/nitto-terra-grapplers-g2-tire-pressure-recommendation.52298/
  5. Sep 4, 2019 at 7:42 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    I have the Coachbuilder 1" shims in the front and the +3 shackles in the back. No rubbing at all. In October when I took it home from the dealership I immediately took all the mud flaps off, not that they where rubbing with the Ridge Grapplers I had them put on, but because it makes the truck look closer to the ground.
  6. Sep 4, 2019 at 7:59 AM
    LyonKing
    LyonKing No way Bells is bigger than Waimea bro...
    2019 White TRD Pro
    Nitto Ridge Grappler 295/70/18 KMC XD135 GRENADE OR Light Bar - Rigid Flush mount reverse lights - Rigid Diamond Back HD Tonneau Cover AMP Research Powerstep OEM Wireless Charger Husky Liners X-act Contour mats Interior LED Swap Center Console Organizers 6 3/4" Antenna Pioneer 7" HU - AVH-W4400NEX Graco Nautilus 3-in-1 Car Seat
    Got around to using Carista OBD2 and turning off the seatbelt alerts and some other random settings. Not worth the annual subscription but the one time changes are free with a 30 day trial. Pretty slick.
  7. Sep 4, 2019 at 1:33 PM
    Pariverpirate
    Pariverpirate New Member
    Rich
    2015 Tundra TRD Off Road
    Non yet
    New Bed liner today and gave her a good washing. Ready for our camping trip tomorrow.
    mgm16trdpro and NewImprovedRon like this.
  8. Sep 4, 2019 at 1:35 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  9. Sep 4, 2019 at 2:30 PM
    CementTurdOffRoad
    CementTurdOffRoad New Member
    Andrew
    Maryland
    '19 Cement Limited Off Road
    9:4:19 - 1.jpg 9:4:19 - 3.jpg 9:4:19 - 2.jpg
    Gunmetal Ray 10's, 275/70R18 Ridge Grapplers, and Color matched bumper covers. (Also a bath). Now I need a lift. Suggestions if I were to keep this wheel/tire setup?
    northof49, GAknight, OR18TRD and 15 others like this.
  10. Sep 4, 2019 at 2:45 PM
    HulkSmurf14
    2014 Tundra Limited
    Drained the rear, front, and transfer case and refilled...also swapped out a noisy belt tensioner for new with a new belt...
    NAFlash likes this.
  11. Sep 4, 2019 at 2:48 PM
    Blueknights75
    Ron
    Clayton, NC
    Billy 6112 at 1.9” setting...beautiful truck!
  12. Sep 4, 2019 at 2:49 PM
    AZBoatHauler
    So.Arizona
    Which oil did you choose for your t-case?
  13. Sep 4, 2019 at 2:53 PM
    CementTurdOffRoad
    Andrew
    Maryland
    Thanks! Thats the front runner unless someone can convince me otherwise.
    Blueknights75[QUOTED] likes this.
  14. Sep 4, 2019 at 4:40 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Remove exhaust, clean, sand, alcohol wipe, (4) coats of high heat primer, (4) coats of high heat ceramic coating, (4) coats clear and (4) coats semi gloss on exhaust tips
    GODZILLA, GAknight, OR18TRD and 5 others like this.
  15. Sep 4, 2019 at 4:48 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    (3) coats high heat primer, (6) coats high heat ceramic coating
  16. Sep 4, 2019 at 4:59 PM
    Viliamu808
    Viliamu808 New Member
    New key fob and climate control knobs from AJT DESIGN..
  17. Sep 4, 2019 at 5:38 PM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    ...you have a paint booth under your house?
    nice...
  18. Sep 4, 2019 at 5:57 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Beautiful wheel, didn't know they came in red stitch.
  19. Sep 4, 2019 at 6:17 PM
    swaggyveet
    swaggyveet New Member
    2020 Tundra TRD PRO Army Green
    295/70R18 Nitto Ridge Grapplers, Ceramic Tint
    Also got 15% ceramic tint in the front 2 windows, 35% in the rear 2 windows, and 15% on the rear windshield. I love the outcome and it makes a huge difference.
  20. Sep 4, 2019 at 6:24 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    3 day project: blacked out TRD dual exhaust high heat ceramic coating with “TRD” custom badge
    GAknight, escuzi_me, OR18TRD and 14 others like this.
  21. Sep 4, 2019 at 6:26 PM
    Drew C
    Drew C New Member
    New knob and 5160s
    mgm16trdpro, JoshuaA and NAFlash like this.
  22. Sep 4, 2019 at 7:11 PM
    northof49
    northof49 New Member
    Barrie, Ontario
    2019 SR5
    MBRP 3" cat back stainless exhaust
    Picked it up ! Brand freakin new. First new truck in 18 years, feels like I’m driving around in someone else’s truck. Drove straight to my tire guy and ditched the factory junk for Falkens.CF7F176C-2225-43AA-9C73-C02023B9A3C9.jpg
    MaxYota, GAknight, OR18TRD and 13 others like this.
  23. Sep 4, 2019 at 7:11 PM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Didn’t get a chance to get a night shot of this light C7AEEAD2-BA2D-48F5-98CF-0A4DA74EA29E.jpgI ended up reselling it and bought this CF91DD31-5BC3-4491-A4D3-7AA8E5759AD0.jpg75A7E341-5E54-4814-B2DC-A5DCF6CD3EED.jpg can’t wait to get this mounted.
  24. Sep 4, 2019 at 7:51 PM
    HulkSmurf14
    2014 Tundra Limited
    I did some checking and it's what all the toyota specific indy shops around me use...it was sworn to be good as long as you change every 50k...Just your regular WS...
  25. Sep 4, 2019 at 7:57 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    That sumbitch looks damn good. Congrats.
    northof49[QUOTED] likes this.
  26. Sep 4, 2019 at 8:19 PM
    Tundra503
    Tundra503 God Bless America
    Andrew
    2016 SR5 DC
    Installed RCI engine skid. Easy install, outrageously stout.
  27. Sep 4, 2019 at 8:21 PM
    Tundra503
    Andrew
    2016 SR5 DC
    This is the reason I bought the RCI, put a hurtin' on the oem junk. ( sorry about the cat, daughters' cat is a mouse hunting machine,lol)
    OR18TRD, mgm16trdpro, Pinay and 4 others like this.
  28. Sep 5, 2019 at 1:55 AM
    dak13
    dak13 Butt Stuff
    2015 Tundra SR5
    Finally, my backseat isn’t a tool box anymore.
    OR18TRD, mgm16trdpro, JoshuaA and 9 others like this.
  29. Sep 5, 2019 at 4:31 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Love the “ power commander” what setting you at... mines is Sport plus, 2*
  30. Sep 5, 2019 at 5:02 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Thanks, ever since installing my Klien Air horns, I’ve been detailing the under carriage that’s the reason I decided to do the “blacked out” TRD dual exhaust project
    Watt maker likes this.
