Do I have a problem with my Tundra?
Discussion in '2.5 Gen Tundras (2014-2021)' started by gdiep, Nov 29, 2016.
  1. Nov 30, 2016 at 5:40 AM
    cdkenne
    cdkenne Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    Yup. It really sucks on smaller cars when it gets stuck on top and there's no way to get to it without removing the exhaust pipe/muffler/cat that its stuck to. Customer usually won't pay for all of that so they just have to live with it.
  2. Nov 30, 2016 at 5:41 AM
    cdkenne
    Corey
    KS
    Those are such a pain in the ass. Some shops have above ground lifts and can easily take the cab off. I've heard its a lot easier that way but our lifts are in ground.
  3. Nov 30, 2016 at 5:57 AM
    gdiep
    gdiep [OP] I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Is there a way to do a visual check for the cam tower leak?
  4. Nov 30, 2016 at 6:11 AM
    cdkenne
    Corey
    KS
    Look through the back of the wheel wells, behind the front tires. At the top of the cylinder heads are the cam towers. They normally leak at the farthest outside corner which is the lowest part. They commonly leak directly on top of the exhaust manifolds.Screenshot_2016-11-30-08-08-48.jpg
  5. Nov 30, 2016 at 6:16 AM
    gdiep
    Syracuse, New York
    Thanks. I'll take a look tonight when I get home from work.
    cdkenne[QUOTED] likes this.
  6. Nov 30, 2016 at 6:55 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Why didn't I think of that?!
  7. Nov 30, 2016 at 9:39 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    friggin plastic bags, I have driven all over the west and they are everywhere, rant over. Did they put undercoating on your truck? check the passenger cat for overspray. I have had this happen to me in the past
  8. Nov 30, 2016 at 10:36 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Here are a couple more pictures, for reference. See that grey bead of silicone? That's where they were leaking.
    Cat3ILS and dcsleeper408 like this.
  9. Nov 30, 2016 at 10:48 AM
    R-C
    R-C http://101financial.com
    Las Vega$
    2017 TRD Pro
    Ive had the same experience with my truck, however it has only been after ive been driving like a maniac :burnrubber: with the tow/haul button.
    -Following
    AnonVet, TheBeast and Y0TA PR0 like this.
  10. Nov 30, 2016 at 1:43 PM
    gdiep
    Syracuse, New York
    Thanks for the extra pictures. I'm assuming that these were taken from the wheel wells? I'm trying to orient myself so I know where to look.
  11. Dec 1, 2016 at 7:33 AM
    gdiep
    Syracuse, New York
    Okay guys, looks like I have a leak. This is on the passengers side. I took it to the dealer today and they have the Tundra. They are ordering valve cover seal and said if they get it tomorrow, they can fix it and return car to me by end of the day tomorrow. I will be discussing with them my disappointment in this leak, but I want to ask if there is any advice about what to look for to make sure this repair is fixed properly.
    Thanks for everyone that helped me figure this out so quickly.
    Dan Diego likes this.
  12. Dec 1, 2016 at 7:56 AM
    cdkenne
    Corey
    KS
    I would start by making sure they reseal the cam towers instead of replacing the valve cover gasket.
    darkknight2014 and Cat3ILS like this.
  13. Dec 1, 2016 at 8:10 AM
    gdiep
    Syracuse, New York
    Please explain.
  14. Dec 1, 2016 at 8:16 AM
    cdkenne
    Corey
    KS
    The valve covers aren't leaking. The cam towers/cradles are leaking. They are that sliver of aluminum between the cylinder head and valve cover gasket. They leak between the cylinder head and the cam tower. It is likely the technician either isn't savvy to the actual problem or doesn't want to do the work under warranty. When we reseal the cam towers we order a full rebuild kit. The job involves tearing the engine down to everything BUT taking the heads off. This includes removing the front engine cover, valve covers, timing chains, and then the cam tower(s). It is a big job but doesn't pay very well under warranty.
    I wouldn't assume they are trying to screw you over. It could be an honest mistake. I would just like to insure it is repaired properly.
    Edit: Also, you should expect the truck to be in the shop a couple days at least. The job can be completed in a day but I like to let the FIPG (seal packing) set up overnight to insure it cures and seals properly.
  15. Dec 1, 2016 at 8:39 AM
    gdiep
    Syracuse, New York
    Thanks. I just spoke to the service manager. He said that it looks like the valve cover right now, but they will check further once they get the valve cover off and If needed, they will go further. I don't think they are trying to screw me, but I am not very confident in their diagnostic abilities right now. So I appreciate the advice here.
    4x4_Angel likes this.
  16. Dec 1, 2016 at 8:43 AM
    cdkenne
    Corey
    KS
    It can be hard to track down if you are not familiar with the problem. It will definitely appear to be a valve cover gasket leak. It has all of the symptoms of it. If you want, you can bring it to KS and @trdlife would love to reseal it. :boink:
    ColoradoTJ and dcsleeper408 like this.
  17. Dec 1, 2016 at 8:49 AM
    gdiep
    Syracuse, New York
    Would be awesome if I could. Thanks for the help. I'll keep everyone posted.
  18. Dec 1, 2016 at 8:53 AM
    gdiep
    Syracuse, New York
    Sometimes work takes me to Kansas City MO. That's the closest I get to where you are. If I find myself out your way, I'll buy you dinner and some beers.
    TheBeast and cdkenne[QUOTED] like this.
  19. Dec 1, 2016 at 8:55 AM
    cdkenne
    Corey
    KS
    I can't argue with that
    ColoradoTJ likes this.
  20. Dec 1, 2016 at 10:16 AM
    #50
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What the dealer that I took my truck to for the Cam Tower leak did was to first steam clean the oil from the area and then put a dye in the oil. They then asked me to drive it some more. When I returned (a week later), they used an ultraviolet light to determine the exact location of the leak. Maybe tactfully suggest something similar, or exactly that. I think that @cdkenne is very much steering you in the right direction.
  21. Dec 1, 2016 at 10:22 AM
    #51
    gdiep
    Syracuse, New York
    I spoke to the service manager and I explained the cam tower thing. I was very professional and we both agreed that "neither of us want the vehicle to come back with the problem unresolved". I also spoke to the General Manager of the dealership and advised him of my expectations. They both assured me that they will have it looked over thoroughly when they take the valve cover off. If the vehicle comes back and leaks again, they will have already been for-warned.
  22. Dec 1, 2016 at 11:32 AM
    #52
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    I hope you get a loaner while they fix it this time and possibly another time...
  23. Dec 1, 2016 at 11:41 AM
    #53
    gdiep
    Syracuse, New York
    Yep. In a 2016 Dblcab tundra.
  24. Dec 8, 2016 at 7:58 AM
    #54
    cdkenne
    Corey
    KS
    Update?
  25. Dec 8, 2016 at 8:51 AM
    #55
    gdiep
    Syracuse, New York
    I got the truck back yesterday. According to the tech, they found that the gasket on the passengers side valve cover was deformed. They replaced the gasket and cleaned up around the area. I drove it yesterday and did not notice any more "burning smell" and from what I can see from the wheel well, the area is clean at this point. I am keeping a close eye on it to see if it leaks, which would indicate that it isn't the valve cover gasket. Thanks and will let you know the verdict after a few more days of driving.
    T-Rex266, r4z0r51o, TheBeast and 3 others like this.
  26. Dec 8, 2016 at 12:36 PM
    #56
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    I'm glad you got it taken care of. I followed your thread from day 1 but stayed quiet since I can't offer any helps. There are so many little things that can go wrong with Toyota these days and sometimes it makes me want to joint the DARK side.
    Brought my '15 GX460 in for 20,000 oil change (@17800 miles) and dealer called saying my Transfer Case is leaking and it will take about 10 hours to fix. Not very happy with the news since it is less than 2 years old and few miles on it. What makes me unhappy even more is the $133 bill for an oil change and car washed....BUT that is my fault for being lazy.
  27. Dec 13, 2016 at 6:00 AM
    #57
    gdiep
    Syracuse, New York
    Update: I suspect that it is leaking again. It's going back to the dealer today.
  28. Dec 13, 2016 at 7:11 AM
    #58
    Sixpack
    Sixpack New Member
    Central Florida
    That bites...
  29. Dec 13, 2016 at 8:32 AM
    #59
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Kind of a pisser.
  30. Dec 13, 2016 at 12:43 PM
    #60
    TheBeast
    TheBeast The Beach
