Dashboard symbol info
Discussion in '2nd Gen Tundras (2007-2013)' started by teachr2, Aug 28, 2019.
  1. Aug 28, 2019 at 10:42 AM
    teachr2
    teachr2 [OP] New Member
    I have a new-to-me 2010. On my dashboard in the oil section there’s an ! I don’t know what this means. I bought it this summer and had my garage look it over and all was okay. I was told it was a great deal and a great truck. Four days ago I had the oil changed. All this time the exclamation mark has been on. What does it mean? What should be done? I want it off.
  2. Aug 28, 2019 at 10:59 AM
    avt007
    avt007 New Member
    Rob
    2010 Silver Tundra Double Cab
    My owners manual shows four different exclamation points. Which is it?
    teachr2[OP] and T-Rex266 like this.
  3. Aug 28, 2019 at 11:08 AM
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    If its the one on the 2nd row at the far right - check your tire pressure...or the tire pressure monitoring system might be bad...
    teachr2[OP] likes this.
  4. Aug 28, 2019 at 11:16 AM
    marinakorp
    Row 1
    Column
    1 - Master Warning light - page 598 on my manual
    2 - Power Steering Warning Light - 597
    5 - Brake system Warning Light - 595
    Row 2
    Column
    8 - Tire Pressure Monitoring Light - Page 598
    more information is needed to help diagnose...
    sine you said it was near the "oil" - I would think that it is the TPMS...
    Tire pressure warning
    light
    •When the light comes on:
    Low tire inflation pressure.
    Adjust the tire
    inflation pressure.
    after blinking for 1
    minute: Malfunction in
    the tire pressure warning
    system.
  5. Aug 28, 2019 at 12:01 PM
    teachr2
    Thank you both. It’s the tire pressure. Now I remember, the previous owner said that while checking tire pressure the man somehow did something to the tire stem. Thus now there’s a problem with the sensor. Any easy and cheap method of correcting this problem?
  6. Aug 29, 2019 at 8:49 AM
    avt007
    avt007 New Member
    Rob
    Search this forum, there's instructions on "calibrating" the system, it may turn off the light. If the sensor is damaged, you'll need a new one.
  7. Aug 29, 2019 at 8:55 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    The TPS warning is just that. It will not affect driveability. Maybe replace sensors when you get new tires.
  8. Aug 29, 2019 at 8:56 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    The TPMS system can be diagnosed for free at any Discount Tire or Americas Tire.
    If the light just showed up I would imagine they jacked with the tire pressure at the oil change shop.
    Sometimes the monkeys will max out the tire pressure that it indicates on the sidewall of the tire (sometimes 44, sometimes 51) and this will throw the TPMS light. The TPMS will indicate an issue if the tire pressure is higher or lower than spec by 25%.
