Headlight lens restore products
Discussion in 'Lighting' started by Randy1794, Aug 27, 2019.
  1. Aug 27, 2019 at 8:07 AM
    Randy1794
    Randy1794 [OP] New Member
    Randy
    Wentzville, MO
    2014 Tundra 1794
    Guys, maybe its me getting older or my lights getting dimmer, but I am having a hard time seeing at night or the road very well when its wet out. I noticed that my headlight lenses were becoming discolored and hazy and was curious has anyone used with success any kind of product to restore them? I would like to try this before going out and replacing the bulbs.
    Thanks
  2. Aug 27, 2019 at 8:11 AM
    Post pics of them for better ideas and replies.
  3. Aug 27, 2019 at 8:15 AM
    Azblue
    The Dirty T ( ^_^)_且
    Don't bother with headlight kits. Just use a DA and some very light polish and follow up with whatever sealant or wax you usually use.
  4. Aug 27, 2019 at 8:15 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    TacomaLC and bvia like this.
  5. Aug 27, 2019 at 8:22 AM
    TacomaLC
    TacomaLC New Member
    Chip
    T-town
    2020 Tundra Voodoo 2020 SequoiaTRD 2000 Tundra LTD (RIP)
    I’d recommend the Sylvania. I’ve tried several: Griots (messy ineffective sealant), Sylvania (effective sealant), McGuire’s (no sealant), 3M (no sealant- best kit to polish). Used them on my 2000 Tundra. I found Sylvania lasted the longest without re-hazing. All polished the lenses to a crystal clarity, but for longevity there needs to be an acrylic type of sealant. 3M makes a good kit for a power drill but the best sealant came with the Sylvania kit.
    Best kit for polishing ease/quality: 3M
    Best acrylic sealant: Sylvania
    Without the sealant they hazed over within 6 months when always parked out door.
    bvia likes this.
  6. Aug 27, 2019 at 8:38 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Polishing compound and a towel.
    If it's really bad and pitted, get the 3m kit, it takes a lot of material off the lense.
  7. Aug 27, 2019 at 8:40 AM
    Any links for a DA and what products you recommend? Thanks
  8. Aug 27, 2019 at 8:46 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    What about off with Deet 40?
    Pudge likes this.
  9. Aug 27, 2019 at 8:53 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Hand sanding and polishing using Micro-Mesh for surface restoration and Micro-gloss for final polishing
    Amazon- Micro Mesh 9 Sanding Sheet Introductory Woodworkers Kit with a 2 inch by 3 inch Foam Sanding Block $16.00*
    Amazon - Micro-Gloss Windshield Polish & Scratch Remover $9.95*
    Sylvania headlight kit for plastic primer and UV clearcoat $19.99
    and finally
    Weathertech lampguards. LG0052 $49.95
    This combination has worked fro me on several vehicles inc. my '05 Mazda3s and my '13 Tundra dc.
    hth,
    B
    * These products were developed and are used in the aircraft industry for polishing airplane windows.
    TacomaLC likes this.
  10. Aug 27, 2019 at 8:57 AM
    Azblue
    I think everyone should have a DA and light polish around for those little but annoying scratches we all get.
    Not exactly pro level stuff, but the Harbor Freight DA is usually regarded as fairly decent and is very affordable. For basic use I always keep a bottle of Maguire's 205 on hand.
  11. Aug 27, 2019 at 9:06 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    DEET from bug spray really does work well to clear up foggy lenses.
    Also polishing with a DA or even by hand will help too.
    The problem is that no matter what you do the fogged yellow look will always come back, and usually worse than previous unless you seal them up.
    I would buff them with rubbing compound then a light polish. Then clean them really well to get all the oils and gunk off. Then spray them with a. Automotive 2k clear. A couple coats would be good. Once it cures then put the lights back on and be sure to use some kind of UV protection on them every couple months, you could use car wax, or a sealant, even 303. The key is that you have to put on some kind of clear coat, 2k is great stuff. You could use a lacquer of some kind. But the sealants that come in the kits jusy wont cut it long term
  12. Aug 27, 2019 at 9:16 AM
    Danimal86
    Daniel
    Sacramento, CA
    I have heard of using bug spray before. Never tried it myself though.
  13. Aug 27, 2019 at 10:24 AM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
    I used the Sylvania on my commuter car and it works good. The sealant is the key.
    TacomaLC[QUOTED] likes this.
  14. Aug 27, 2019 at 10:24 AM
    Deet will cause it to break down even more.
  15. Aug 27, 2019 at 10:25 AM
    It eats the plastic even more
  16. Aug 28, 2019 at 10:32 AM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    I had great results with good old fashion wet sanding, 2k clear coat. Has some orange peel but can be westsanded and polished for crystal clear like new lights.
    Pudge likes this.
  17. Aug 28, 2019 at 10:41 AM
    Octane957
    Octane957 New Member
    The company I work for sells headlight restoration kits among other products. We tested about 20 different brands before deciding on what to stock. Overall, the 3M kit is about the best we have used. 3M's part number is 39008. Hope this helps.
  18. Aug 28, 2019 at 10:41 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Meguiars Heavy Duty restoration kit worked well for me. :thumbsup: Like $22 on Amazon or a few dollars more at Walmart or autoparts.
  19. Aug 28, 2019 at 11:01 AM
    mcchase
    mcchase New Member
    chase
    I used the 3M kit to polish lenses and then coated with Meguiars headlight clear coat on my 2010. Still looking great 6 months out.
  20. Aug 28, 2019 at 11:44 AM
    Pudge
    CT
    This is the permanent solution and likely looks the best.
  21. Aug 28, 2019 at 11:53 AM
    War Machine
    War Machine SSEM # 5 3MW
  22. Aug 28, 2019 at 2:23 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Does someone want to clue the old guy in on what a "DA" is? I can think of several thing that match the acronym, but none are relevant here.
    driverdog likes this.
  23. Aug 28, 2019 at 2:24 PM
    Pudge
    CT
    Dual Action polisher
    Azblue and Randy Morton[QUOTED] like this.
  24. Aug 28, 2019 at 2:27 PM
    Randy Morton
    Randy
    Thanks! Now it's off to find a good one.
    driverdog and Pudge[QUOTED] like this.
  25. Aug 28, 2019 at 2:38 PM
    Pudge
    CT
    I love my griots garage 6" aka GG6. Plenty of power and very affordable. Porter Cable makes a good one as well for a good price. Stay away from the cheapo Amazon or harbor freight polishers. Keep an eye open for labor day sales at autogeek and detailedimage. They both offer package deals with pads and stuff.
