King shocks or Fox shock or Toytec Alumas what would you choose?
Discussion in 'Suspension' started by Rica25, Aug 11, 2019.
  1. Aug 11, 2019 at 11:12 PM
    #61
    Looking forward to the meat....
    TheBeast and Rica25[OP] like this.
  2. Aug 11, 2019 at 11:46 PM
    #62
    Texas Bandit
    Texas Bandit New Member
    Amí
    Edinburg Texas
    2007 White 5.7 Tundra DC Limited 4x4
    295/70R18 Nitto Ridge Grappler Method Race Wheel NV Bronze Rigid Industries Radiance Pods Morimoto Xtorch 36” Light Bar SDHQ Pillar Light Mounts
    What’s CO?
  3. Aug 11, 2019 at 11:47 PM
    #63
    Coil Overs
    OR18TRD likes this.
  4. Aug 11, 2019 at 11:48 PM
    #64
    Texas Bandit
    Amí
    Edinburg Texas
    Lol makes sense now.. thanks
    Rica25[OP] and ColoradoTJ like this.
  5. Aug 11, 2019 at 11:57 PM
    #65
    Mine are black and blue. I kinda like the look.
  6. Aug 12, 2019 at 6:10 AM
    #66
    DecalsByDesign
    DecalsByDesign Vinyl Connoisseur
    Eagle, CO
    2019 Quicksand Limited Double Cab
    Toytec Performance Aluma 2.5 Kit Nitto G2 295/70-18 Method MR306 18x9 +18 Kenwood DDX6906s Carven TR Muffler w/ Y-Pipe
    The Aluma series is brand new, that is why not a lot of people have them. I’ve seen nothing but problems from Icon. @Toytec Lifts where do you stand in this. Kings and fox may be better, but most likely overkill for your situation.
    Rica25[QUOTED][OP] likes this.
  7. Aug 12, 2019 at 6:14 AM
    #67
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Going go long travel ? What springs you going to?
    Rica25[OP] likes this.
  8. Aug 12, 2019 at 9:25 AM
    #68
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    @ColoradoTJ , this might be a silly ? What would you recommend for the rears if I go kings up front, I know I would love to get the kings in the rear aswell, but $$..trails at most here and hauling alot. I read some guys use 2 brands aswell..TIA Chris.
  9. Aug 12, 2019 at 2:24 PM
    #69
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    No i have the Radflo 2.5 not Alumas
  10. Aug 12, 2019 at 2:25 PM
    #70
    csuviper
    Broomfield, CO
    FOX has such ridiculous lead times because of making shocks for factory truck sales.
    snivilous, Rica25[OP] and TheBeast like this.
  11. Aug 12, 2019 at 2:51 PM
    #71
    BrownieT
    BrownieT New Member
    2018 Tundra TRD 4x4
    OP No they are not needed but alignment numbers like them better. Undecided on uca,s. I have a set of RW wheels already. Deciding on rubber. Perhaps ko2’s
  12. Aug 12, 2019 at 3:22 PM
    #72
    I'd also like to see the "Lots of documented failures of toytecs in general". Hardly any at all here other than the Eibach supplied coil issue.....and a lot of members, lot's of members, run with ToyTec.
  13. Aug 12, 2019 at 4:12 PM
    #73
    Vizsla
    Vizsla pretend2send
    What makes you say that? King OEM are readily available, no need to wait. Just had King build my LT shocks, their lead time was the shortest, half of the expected lead time for Fox. Got them a week earlier than quoted as well.
  14. Aug 12, 2019 at 4:15 PM
    #74
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Yup, check with Shawn Lucero at Rogueoffroad in Vegas, he has kings in stock even the 3.0’s
    TheBeast, Rica25[OP] and Vizsla like this.
  15. Aug 12, 2019 at 4:27 PM
    #75
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    My Icons have held up much better in the Ohio winters than my Fox's. I would go Kings /Icons. Icon does good black friday deals too.
    Kerch71, TheBeast and Rica25[OP] like this.
  16. Aug 12, 2019 at 4:41 PM
    #76
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    I have the same 6112 / 5160 setup. Hard to beat that shock set up for a G
  17. Aug 12, 2019 at 5:26 PM
    #77
    NE_WARRIOR
    NE_WARRIOR [HOONIGAN] Wannabe
    Union, ME
    08 DC SR5
    Just to revisit your venom build. you went through the three suspension options that I was looking at and ended up with the radflos as your favorite. how did they do on farm roads and high speed dampening because that's mostly what I'm looking to improve with my truck
  18. Aug 12, 2019 at 5:44 PM
    #78
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I live at the beach and Icons hold up great to the salt air as well
  19. Aug 13, 2019 at 9:25 AM
    #79
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Google provides lots of links, https://www.google.com/search?q=toy...rome..69i57.3455j0j7&sourceid=chrome&ie=UTF-8
    Most of the photos of failures I've seen are from Facebook. A week or two ago I saw a picture of a toytec shock that had nothing tweaked on it and the shaft buckled when someone merged onto the interstate, and then the toytec reps gave him all sorts of hell about how he had messed with the preload and stuff which the guy said he hadn't.
    All shocks have failures, but seems like I see way more from Toytec and Bilstein (though Bilstein's are pretty cheap, so maybe it comes with the territory). Maybe it's not a Tundra issue, I don't frequent Tundra discussions but it seems to pop up often in other toyota pages.
    The one time I ordered Kings they said 12 weeks and it ended up being 16 lol (though they weren't an OEM application)
  20. Aug 13, 2019 at 1:16 PM
    #80
    csuviper
    Broomfield, CO
    I meant FOX. Sorry. FOX has long lead times and is typically back ordered many places.
    Black Wolf and Rica25[OP] like this.
  21. Aug 28, 2019 at 11:32 AM
    #81
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    Getting it done
  22. Aug 28, 2019 at 11:34 AM
    #82
    Rica25
    Ricardo
    Tulare
    Set at 2.5
    Toyokuhl, equin, GiantsFanDan and 2 others like this.
  23. Aug 28, 2019 at 11:49 AM
    #83
    Texas Bandit
    Amí
    Edinburg Texas
    Your powder coated them nice!!!
  24. Aug 28, 2019 at 6:03 PM
    #84
    Rica25
    Ricardo
    Tulare
    What are some good alignments numbers ? What is it that I should see when looking at the specs?
  25. Aug 28, 2019 at 6:18 PM
    #85
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I would be hesitant to buy Toytec after reading about them basically telling people to go pound sand after having issues. Not what potential customers want to read about.
  26. Aug 28, 2019 at 6:39 PM
    #86
    Rica25
    Ricardo
    Tulare
    Adding the 6112s lifted the truck alot more than the 5100s at the highest setting I was real surprised
    RLHULK likes this.
  27. Aug 28, 2019 at 6:53 PM
    #87
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I think he is 2wd. We get more lift out of same coils.
  28. Sep 4, 2019 at 11:12 AM
    #88
    Texas Bandit
    Amí
    Edinburg Texas
    So how’s the ride?
  29. Sep 4, 2019 at 11:34 AM
    #89
    Rica25
    Ricardo
    Tulare
    It's good so far dont see difference on DD from the 5100s just looks more bad ass......we will find out off road soon......I also set at highest setting so I'm sure the ride could be better if it was at lower setting
  30. Sep 6, 2019 at 5:16 PM
    #90
    saybng
    Gary
    Ventura CA
