Bike racks/carriers?
Discussion in 'Outdoors' started by ToyotaTundraMike, Apr 14, 2017.
  1. May 31, 2019 at 8:22 AM
    #61
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    Was able to finish up the rack today. Ordered some aluminum spacers from ebay and bought some square tubing from home depot. Need to do a little touch and paint but I like the way it came out. I found the Yakima frontloader rack on Facebook marketplace for 100 and the only mod I did to it was cut the slot a little bigger to fit the rail nice and snug. 20190531_110814.jpg 20190531_110823.jpg 20190531_111153.jpg 20190531_111328.jpg 20190531_112024.jpg
    #61
    tbutler and Voyagermike like this.
  2. Jun 13, 2019 at 11:07 AM
    #62
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    Custom mount I just finished. I wanted to keep the cover on and the bikes facing forward.
    Just need a couple of lashing straps to secure the 2x6 on top of the cover and a coat of paint.
  3. Jun 13, 2019 at 11:31 AM
    #63
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    nice! how did you secure the spacers to the stake pockets? I have the a similar setup but i used pop rivets to secure the tracks on the side bed rails
    #63
  4. Jun 13, 2019 at 11:38 AM
    #64
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    Thanks. I just bought some 4" long 3/8 bolts that went through the spacer, plate, and screwed into the anchor clasp. Just replace the ring bolt.
  5. Aug 27, 2019 at 10:05 AM
    #65
    W///
    W/// New Member
    Greenville, SC
    2016 Barcelona Red Platinum
    Absolutely love this setup. I was thinking the other day about something like this, but uses the bed rail system. Thoughts on something like this?
    #65
  6. Aug 27, 2019 at 10:49 AM
    #66
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
  7. Aug 27, 2019 at 10:58 AM
    #67
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    The FrontRunner gets your racks up a little higher which is nice for big coolers and whatnot.
    I’m not too terribly keen on the bolts the FrontRunner use to secure inside the rail though.
    I can do 2 full size MTBikes facing forward on OneUp racks, and one full size facing rear (With front wheel removed) on a Yakima Forklift, along with a 16 Yakima Skybox. Love the setup! I can carry the family of 4, the dog, 3 MTBikes, and all my gear in the back for 4-6 nights camping.
  8. Aug 27, 2019 at 11:45 AM
    #68
    W///
    W/// New Member
    Greenville, SC
    Wow this is exactly whta I had in mind. I've read your build thread before but never really noticed this. This is a super nice setup!
    If you don't mind, I might send you a message to ask you a few more questions about your setup.
  9. Aug 27, 2019 at 11:48 AM
    #69
    Boosted4runner
    WA
    Yep - anytime.
    Not sure I updated the bike stuff in the build thread. I should do that. :thumbsup:
  10. Aug 27, 2019 at 8:22 PM
    #70
    McMason
    McMason New Member
    Scott
    Boise, Idaho
    2019 TRDOR CM Cement
    Just finished mounting my Kuat Trio on the @KB Voodoo crossbars. I'm not in love with the idea of a fork mount rack, but it's definitely more secure, and it really helps with clearance and ease of lifting.
    I LOVE the crossbars. I have bought a lot of stuff from folks that call themselves fabricators over the years. Most of the time I'm not too impressed (C4 would be an exception). These are super clean, simple, and so thoughtfully engineered. No awkward positioning required for installation, no unnecessary add-ons, no complicated clip assemblies. Just simple, strong parts that fit together well and don't require any modification to mount whatever you want on them. Stoked :thumbsup:
    It's so nice to have things positioned over the bed instead of on a roof or hanging off the back. Kuat and 1Up make some nice tray racks, but I don't see myself going back to a hitch mount any time soon.
  11. Aug 28, 2019 at 5:36 AM
    #71
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    Wallygator, kbark, Canuckian and 2 others like this.
  12. Aug 28, 2019 at 7:17 AM
    #72
    Boosted4runner
    WA
    Looks great!!
    Some info on 1Ups and my setup.
    I’ve done right around 100mph for a decent amount of time with my setup and the 1Up’s did just fine. I’ve found if you roll the rear rack more over the back tire than over the front it’s more secure. I then hop on my Tundra rear tire and bear hug both tire racks to get them really tight.
    The seconds taking the wheel off aren’t that much of a big deal, but making sure your axle is in position perfectly was a pain for me - especially for the 2 inside bikes. I was bent over awkwardly trying to position, where with both wheels on you can just roll the bike either way.
    I can make it through the Dutch Bros drive-ins, I’m exactly 8’11” at the highest point of the bike.
  13. Aug 28, 2019 at 7:21 AM
    #73
    Boosted4runner
    WA
    Are your bike mounts $100 for a pair or $205 for a pair? (Per bike)
    (For others, understand you need a set of $220 1Up racks as well)
    I also noticed you didn’t use 1Up’s special key’d bolts for the mounting (theft prevention).
    Were those not an option?
  14. Aug 28, 2019 at 8:54 AM
    #74
    KB Voodoo
    Chad
    1UP sent the rack to us to try on our bed racks. I guess they didn't include the locks.
    On the other side of our rack, we have our Outboard Bike Mounts and Rear Tire Tray along with a RockyMount Driveshaft HM fork mount.
    That is our go-to setup, it's the best way to carry a bike, hands down.
  15. Aug 28, 2019 at 12:23 PM
    #75
    Boosted4runner
    WA
    I previously ran the RockyMount Driveshaft fork mount and it was solid (still have it), but not the best for me.
    I personally wasn’t crazy about removing wheel/tire.
    I do short trips sometimes 3-4 days in a row on some local trails and it got old really quick just for a 10-15 min drive each way. I didn’t mind when you’re driving 3hrs to a destination or on vacation.
    I don’t want to toss the bike in the bed and have it bouncing all around either.
    1Up was perfect solution.
    Mine are mounted behind my cab though, maybe mounting on the sides of the rack take on more wind or something.
  16. Aug 28, 2019 at 12:34 PM
    #76
    Boosted4runner
    WA
    Also while we’re on rack topics, do you have any pictures of Tundras with these bed bars?
  17. Aug 28, 2019 at 12:39 PM
    #77
    KB Voodoo
    Chad
    I don't think we do. We don't sell many set of Load Bars, most people go for the full rack.
  18. Jan 4, 2020 at 5:54 AM
    #78
    bootleg_flyer
    bootleg_flyer New Member
    Have a 1Up but greatly prefer the security and functionality of the Kuat ... can anyone confirm tailgate clearance with the Kuat NV (NV flat/level with tailgate down)? Thanks!
  19. Jan 4, 2020 at 7:42 AM
    #79
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I had a Kuat NV 2.0 and the tailgate would touch the plastic of the wheel tray.
    It was barely touching so I used a sander to reshape the wheel tray to give more room.
  20. Jan 4, 2020 at 7:46 AM
    #80
    bootleg_flyer
    That's what I was afraid of. Thanks!
  21. Jun 2, 2020 at 6:26 AM
    #81
    trd.james
    trd.james New Member
    James
    2020 TRD PRO | Westcott Lift | 35" KO2's
    I'm considering mounting my bike on crossbars over the bed or as an alternative just throwing it on a 1up hitch mount. I have a need to pull a camper sometimes, which is why I am considering the crossbar set-up, but will be hauling just my bike around without a camper 10x more than with the camper.
    So I'm curious to those who have used both, is the crossbar set-up more aggrivating to use in real life? Part of me feels like the cheaper hitch mount might make more sense 90% of the time but that crossbar mount will be super helpful when towing. I don't really want both...
  22. Jun 2, 2020 at 6:50 AM
    #82
    Jota21
    Jota21 New Member
    i bought a cheapie maxxhaul 4-bike hitch on Amazon for $50ish. Perfectly adequate, although a slightly sloppy fit which doesn't instill confidence seeing the bicycles flop from side to side. a $10 hitch tightener makes it all rock solid.
    trd.james likes this.
  23. Jun 2, 2020 at 7:47 AM
    #83
    McMason
    McMason New Member
    Scott
    Boise, Idaho
    When I used to ride road bikes a lot (5-6x a week), I preferred the tray style hitch mount. That was on the 4Runner though, which is a shorter vehicle (obviously). Here is why I prefer the bed rail/fork mount now:
    1. Doesn't make the truck any longer - I can still park it anywhere.
    2. I don't have to worry about anyone running in to the hitch mount rack (happened to me before, ruining rack).
    3. The bike feels much more secure both while driving, and secure from theft while parked.
    4. I don't have to worry about where to store a rack when I don't want it on the truck.
    5. I can use the rails for a RTT or cargo box if I want.
    6. Can carry bikes while towing.
    7. Could easily fit 3 bikes on the rails if I wanted.
    The only con really is that I have to take off the front wheel to put a bike on. That would be more of a PITA if I was still carrying a bike almost every day, but I'm older and fatter now and live in a place where I can ride right from the house, too. I drive with bikes less frequently, so it's well worth the brief inconvenience of removing a wheel. Now that I think about it, Yakima does make a single mount that allows you to keep the front wheel on. Not sure about 1up. Good luck!
  24. Jun 2, 2020 at 10:06 AM
    #84
    Boosted4runner
    WA
    All of this, but 1Up you don’t have to remove front tire :D
    With a 3.5” lift on 35’s it’s a tad more challenging to lift up onto bed racks, doing it daily might suck. But once a week is nothing.
    I have a hitch mount as well and prefer bed racks.
  25. Jun 2, 2020 at 10:21 AM
    #85
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    #85
    McMason likes this.
  26. Jun 2, 2020 at 10:28 AM
    #86
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    I have an older 4 bike Kuat but I'm planning on adding some 1UP roof mount racks (I have a Diamondback HD and some Yakima bars in the bed.)
    Most of the time, I'm not transporting more than 2 bikes and being able to just leave a couple of racks on the tonneau is a lot better than the hitch rack. With the hitch rack you either leave it on and loose your backup camera and what is left of your visibility or you have to take it off/put it on all the time. And lets face it, a Tundra is long enough with enough blind spots without adding an extra 5 feet of rack blocking the view. Even tilted up you've lost your rearward view and your camera (although only 1.5-2 feet out from the bumper.)
  27. Jun 2, 2020 at 11:33 AM
    #87
    trd.james
    James
    Great answer! Thank you for the detail, exactly what I was looking for.
    McMason[QUOTED] likes this.
  28. Jun 2, 2020 at 11:35 AM
    #88
    trd.james
    James
    Thanks @Boosted4runner ! Glad to know you prefer the bed mounts. In my case, I don't need to remove the front tire. I'll use something like the Yakima Frontloader or a roof rack 1up on the cross bars, so I don't have to remove the tire. If the tire removal is the only con, then I guess crossbars is the obvious answer.
    I hear you on the height of the truck, but I don't think it's too high for me to lift.
  29. Jun 2, 2020 at 11:38 AM
    #89
    trd.james
    James
    I didn't even think about the back up camera. That pretty much solidifies my decision. Thanks!
    Boosted4runner and jpod[QUOTED] like this.
  30. Jun 2, 2020 at 12:14 PM
    #90
    Boosted4runner
    WA
    1up - highly recommended!
