Best UCA for the money not break the bank
Discussion in 'Suspension' started by Rica25, Aug 26, 2019.
  1. Aug 26, 2019 at 9:49 PM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    What are the best UCAs with out spending to much money
  2. Aug 26, 2019 at 9:55 PM
  3. Aug 26, 2019 at 9:56 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  4. Aug 26, 2019 at 9:58 PM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    SPC as well,had them on my taco with no issues
    Rica25[OP] likes this.
  5. Aug 26, 2019 at 9:59 PM
    saybng
    Gary
    Ventura CA
    I think there $480 right now on Amazon..
  6. Aug 26, 2019 at 10:06 PM
    Bingeaux
    Bingeaux New Member
    2018 MGM Tundra TRD Sport CM
    Jba if you like red and high angle balljoints.
    Tundyfundy, saybng and Rica25[OP] like this.
  7. Aug 26, 2019 at 10:38 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
  8. Aug 27, 2019 at 6:53 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
  9. Aug 27, 2019 at 7:30 AM
    Rica25
    Ricardo
    Tulare
    Dobie really need these ifbjustvinstallung 6112s and 5160 ?
  10. Aug 27, 2019 at 7:35 AM
    Rica25[OP] and Kwikfish like this.
  11. Aug 27, 2019 at 7:43 AM
    saybng
    Gary
    Ventura CA
    It would help alot with your alignment numbers..and you might aswell doing at the same time...
    Rica25[QUOTED][OP] likes this.
  12. Aug 27, 2019 at 8:24 AM
    Rubberdown
    Rubberdown Spilling my guts here.
    Arent MCM's like $640? Was thinking of going this route.
  13. Aug 27, 2019 at 8:31 AM
    SoCalPaul
    Paul
    The last time I checked, they were cheaper. It looks like you can get SPCs for less now.
  14. Aug 27, 2019 at 8:40 AM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Rica25[OP] and saybng like this.
  15. Aug 27, 2019 at 9:15 AM
    GravityGear
    Aurora, CO
    Can't legitimately put an Eibach sticker on your truck if you don't own any Eibach gear. SPC has like zero street cred. I'd buy the Eibach so I can put the sticker and not get laughed at.
  16. Aug 27, 2019 at 9:43 AM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    That matters not to me.....
    Tundyfundy and Rica25[OP] like this.
  17. Aug 27, 2019 at 10:37 AM
    SoCalPaul
    Paul
  18. Aug 27, 2019 at 10:39 AM
    SoCalPaul
    Paul
    If you keep the lift to 2" or less, you probably don't need the UCA's.
  19. Aug 27, 2019 at 11:53 AM
    Rica25
    Ricardo
    Tulare
    2.5 I was just wondering because my 5100s are set at 2.5 and aligned good just didnt know if the truck would ride any better with them
  20. Aug 27, 2019 at 12:41 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    I’m running a set of JBA HD UCA.
    They have been great so far. Think they were $530 ish3F2BC38D-3E4E-4157-9FF3-1FAB64FEFF61.jpg
  21. Aug 27, 2019 at 12:49 PM
    saybng
    Gary
    Ventura CA
    Nice!!
    Rica25[OP] and MAGDADDY[QUOTED] like this.
  22. Aug 27, 2019 at 3:54 PM
    This looks like the best price and killer deal? I'm having front end vibes with the ReadyLift 3/2. I'm going to post my alignment sheet tonight.
  23. Aug 29, 2019 at 8:21 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Love my JBA
    MAGDADDY and Rica25[OP] like this.
  24. Aug 30, 2019 at 11:24 AM
    Tundyfundy
    Bay Area, CA
    Which means he’s gonna need UCA’s considering the money pit this forum is. :spending:
  25. Sep 7, 2019 at 2:16 PM
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    I just put the freedom offroad ucas on my truck. Install went easy. Didnt have to do any grinding as others seem to have needed. They are solidly built and use stock type bushings and ball joint. I didnt want uniballs for the maintenance aspect. I dont wheel the truck. I'm on a 3/1 and I no longer have UCA to coil contact at full droop. I'll post alignment results later this week.
