12volts Plug & Play remote start groupbuy!
Discussion in 'Audio & Video' started by T-Rex266, Jul 31, 2019.
  1. Aug 26, 2019 at 10:04 PM
    #481
    paradox2311
    paradox2311 New Member
    Even though I didn't have a problem with my 2018 crewmax installing the remote start, this comment will keep me as a customer for a long time!
  2. Aug 26, 2019 at 10:20 PM
    #482
    Yzed608
    Yzed608 New Member
    Wisconsin
    Thanks, I'll take a look tomorrow!
  3. Aug 27, 2019 at 6:55 AM
    #483
    teamtlr
    teamtlr New Member
    Denver Colorado
    2020 Sequoia TRD Pro
    James is sending me a test module that is expected to have the fix for the lock issue on my 2019. As soon as I get it I will let you guys know.
  4. Aug 27, 2019 at 9:14 AM
    #484
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    18 and 19 only if your door is not locking back
    ok so apparently this only on certain 18 and 19s . Not all of them . here is the fix without shipping it back. if you do not want to splice in this wire I will need to get them back and reprogram but i need to test the new software first .
    If you want to fix it your self here is what you do :
    here is the fix without shipping back . the white wire in the small white plug with all extra wires in it can be hooked up to the door lock white wire in kick panel of the truck and it will fix this . pic of both attached
    18 tundra lock wire.jpg tundra lock wire (1).jpg 18 tundra lock wire.jpg tundra lock wire (1).jpg
  5. Aug 27, 2019 at 9:30 AM
    #485
    james@tech12volts
    james
    and no one has to do the spice wire above if they do not want to I will cover shipping to me and back out of my pocket. This is not my fault but I always take care of my customers no matter what it cost me . It is just how we do business .
  6. Aug 27, 2019 at 10:21 AM
    #486
    james@tech12volts
    james
    yes sir white wire out of that bundle needs to be connected to the white wire in the kick panel in the pic i posted
  7. Aug 27, 2019 at 2:41 PM
    #487
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    So, I got it all hooked up. Worked perfect the first time, and now it won’t do it? Do I need to program, again?
  8. Aug 27, 2019 at 3:38 PM
    #488
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    I’m just gonna hit the lock button 4 times to start and lock it, don’t need to be cutting anymore wires .
    YsoSeRiouS! likes this.
  9. Aug 27, 2019 at 3:40 PM
    #489
    Talked to James. Needs a software update. He’ll send me a new one.
    He replied to my email in 2 mins, then followed it with a phone call in attempt to troubleshoot it. Customer service 10/10
  10. Aug 27, 2019 at 3:52 PM
    #490
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Amen!
  11. Aug 27, 2019 at 6:04 PM
    #491
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    @james@tech12volts if I decided to send back my module do i need to send back all the wiring to or just the module
  12. Aug 27, 2019 at 6:08 PM
    #492
    For updated software? Just the module should be good
    TheBeast and YsoSeRiouS![QUOTED] like this.
  13. Aug 27, 2019 at 6:23 PM
    #493
    YsoSeRiouS!
    NorCaL
    I emailed him and he responded quickly, like you mentioned just module. It just sucks fortin software had to make him do the run around but I appreciate his customer service that there does indeed speak volumes in my book
  14. Aug 27, 2019 at 7:37 PM
    #494
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    So it's not really splicing right? Just tap into the white power lock wire?
    Also, if I wanted to send module back for Software update...do I have to undo all the cabling or can I just unplug the module?
  15. Aug 27, 2019 at 7:58 PM
    #495
    TheBeast
    TheBeast The Beach
    you probably want to drive your truck so yeah you have to put the oem wiring plugs
  16. Aug 27, 2019 at 7:58 PM
    #496
    He may send u a new one, then u send back old one. Makes ur truck still running
    TheBeast and paradizecityz like this.
  17. Aug 27, 2019 at 8:00 PM
    #497
    paradizecityz
    Richmond, TX
    LOL, looong day...not really thinking
    I hope he goes this route...that would be awesome :)
    TheBeast[QUOTED] likes this.
  18. Aug 27, 2019 at 8:02 PM
    #498
    TheBeast
    TheBeast The Beach
    yes there would be no downtime for you. Just swap modules an send him back the old one.
    paradizecityz likes this.
  19. Aug 28, 2019 at 9:47 AM
    #499
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    A splice will take 15 minutes. So if you're comfortable splicing into the TPMS wire then you should be comfortable doing this fix. If you do use a quick splice I would recommend the posi-taps, they're quite a bit better than the regular quick splices.
    AZTundra likes this.
  20. Aug 28, 2019 at 9:58 AM
    #500
    james@tech12volts
    james
    has anyone done the white wire splice? This was told to me by Fortin and I just want to make sure it works ?
    InfernoToyo likes this.
  21. Aug 28, 2019 at 10:01 AM
    #501
    james@tech12volts
    james
    And guys YOU WILL NEVER BE LEFT IN THE DARK BY US!!! If we sell you something we will not just say screw it and let something not work correctly . Some of the JBL amps had issues when using high level amps I researched for weeks how to fix it trying all kind of stuff as JBL was no help at all and we found the solution. That solution cost me 25 dollars per amp which was more than i made on each amp but i sent everyone what they needed for free and just took the loss. Not patting myself on the back as That is how you are suppose to treat customers
  22. Aug 28, 2019 at 10:24 AM
    #502
    YsoSeRiouS!
    NorCaL
    I like the fact that you treat customers they way you would be like to be treated and that’s why you will have a returning customer. For me that’s big kudos to you
  23. Aug 28, 2019 at 11:11 AM
    #503
    AZTundra
    Paul
    Phoenix, AZ
    Customer service is top notch! When I get ready to do my stereo upgrades I know where I'm going...
  24. Aug 28, 2019 at 2:24 PM
    #504
    james@tech12volts
    james
    I MAY HAVE A SOLUTION FOR THE 18 NOT LOCKING BACK THAT REQUIRES NO CUTTING IN YOUR TRUCK! If you are willing to try PM me asap or email me tech12volt@gmail.com
  25. Aug 28, 2019 at 3:55 PM
    #505
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    Hey guys, I talked to James and he walked me through his solution for the 2018s that wouldn't lock. It worked! I'll post in about an hour or two pictures and the solution. I have to run out, but be back shortly. Sorry to leave you hanging.
  26. Aug 28, 2019 at 4:01 PM
    #506
    YsoSeRiouS!
    NorCaL
    Nice now it give me a chance to go back in and solder my wires
  27. Aug 28, 2019 at 5:00 PM
    #507
    james@tech12volts
    james
    ok so here is the fix for 18 and 19 Tundras if your doors are not locking back after start. now be aware this module is programmed to lock the doors back after you stop the remote start . so after you turn the truck off if you are not driving it it will lock the doors . You will see what i am talking about . Just do not close the door with the keys in the truck while testing it .
    take the white wire on the harness we sent you that had all the wires you are not using. The orange wire we connected to the harness for you is in this same white harness . connect that white wire to the black wire in the harness pictured above that we sent you . Its the 2nd black wire from the end and its on the opposite side as where we connected the orange disarm for you . does not matter how you connect the two wires as long as they are connected and the black wire is still connected together also. you can positaps. solder or do like i did in the picture and strip the wire back and tape . your truck will now lock the doors back after remote started
  28. Aug 28, 2019 at 5:08 PM
    #508
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    Wow. The keyboard!
    And thanks for posting this fix!
    Magnetic15 likes this.
  29. Aug 28, 2019 at 5:54 PM
    #509
    chinadog
    chinadog New Member
    Knoxvegas
    OK, he beat me to it. Here's what I've got. James, correct anything if need be. EDIT: The third photo has been updated to point to the correct wire. You can see the splice (better view in the forth picture), but that's the correct wire. When you're looking for it, make sure the connector is facing the same way as in the picture, then it's the second black wire from the right.
  30. Aug 28, 2019 at 6:12 PM
    #510
    YsoSeRiouS!
    NorCaL
    That’s second to last picture you have an arrow pointing on the wrong side right because you tapped the right side of the picture but you have an arrow on the left side. Sorry I just wanna make sure before I try it
