4H driving problem
Discussion in '2nd Gen Tundras (2007-2013)' started by Dogmatic, Aug 25, 2019.
  1. Aug 25, 2019 at 9:38 AM
    Dogmatic
    Dogmatic [OP] 2013 TRD Rock Warrior 4X4
    Anyone ever experience problems driving in 4H?
    Did that the other day and when I turned the wheels it came to a stop, like the brakes were being applied.
    I read some stuff on line where people said you can't drive 4H on dry pavement. That sounds ridiculous.
  2. Aug 25, 2019 at 9:42 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    No 4wd on dry pavement unless you want to chance breaking something.
    The feeling you're getting is the driveline binding.
    equin, FirstGenVol and Black Wolf like this.
  3. Aug 25, 2019 at 9:49 AM
    MAK
    MAK Searching for Gnarnia
    San Diego
    2014 SilverSky DC TRD Limited
    FRAC, Console safe, Amazon special-console organizer, Rhino liner, Pace Edwards retractable tonneau cover, Drivers side swing case, AJT shift knob and matching key fob!, Interior trim De-chrome with Faux carbon wrap, color matched door handles and mirror covers, Maxpider 3D Floor mats, Custom Dog bed in DC area, BFG Radial TA KO tires, 18 x9 +20 Fuel Shok wheels, Toytec Boss 3:1(shackles), White Knuckle offroad sliders w/diamond plate step, Bumper skins, Blackout badges, Firestone airbags, RCI skid,
    This is normal for a 4WD.
    4WD is intended for off road driving. The front diff is a locking type.
    4WD is not the same as All Wheel Drive in which case the diffs allow for slippage to compensate for the different turning radius' of the inside wheel vs the outside wheel.
    Kerch71 and equin like this.
  4. Aug 25, 2019 at 9:49 AM
    Dogmatic
    So, only on gravel or mud? What about a hard fire road, seems like it might bind up too. Is this normal with all 4x4s?
    duece292 likes this.
  5. Aug 25, 2019 at 9:49 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    As Festerw has pointed out...........YOU'RE binding the front drive system Dog. Stop. Never run it in 4H OR 4L on dry pavement. Bad. Bad. Bad.
    EDIT: loose gravel and mud are a different story. If the "outside" from wheel/tire can "slip" than you're probably O.K.
  6. Aug 25, 2019 at 10:02 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    If you're on a hard road there's nearly no need for 4wd.
    I leave it in 2 until I feel it start to slip.
  7. Aug 25, 2019 at 10:05 AM
    Dogmatic
    Ok. I get it now.
    I just wanted to see if it would work. Hope I didn't eff anything up.
  8. Aug 25, 2019 at 11:58 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    This is weird reading this thread, I can switch mine into 4wd hi on the move and everything is smooth and seamless. Black top or not..
  9. Aug 25, 2019 at 11:58 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Turn the steering wheel...
    Kerch71, Ely010606 and Black Wolf like this.
  10. Aug 25, 2019 at 12:01 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    If your talking to me , I have. I drove it around the block.
    Hell ! I just remembered driving around a whole mountain side somewhere in Colorado cause I got detoured. 4wd hi the whole time with patches of wet road from the rain and snow. Smooth as silk no issues.
  11. Aug 25, 2019 at 1:34 PM
    avt007
    avt007 New Member
    Rob
    2010 Silver Tundra Double Cab
    Not to be picky, but there's some incorrect info here. The problem is not the front or rear differentials, they are standard open diffs. The issue is that in 4wd, there is no differential between the front and rear axles. In other words, on dry pavement, you're forcing them to turn at the same speed, which is fine in a straight line. But in a tight turn, they cover different distances and it binds up because the tires don't slip on pavement easily.
    MAK, Kerch71, Black Wolf and 2 others like this.
  12. Aug 25, 2019 at 1:38 PM
    Dogmatic
    Shouldn't the manual state this, so people don't destroy their drivetrains?
  13. Aug 25, 2019 at 1:41 PM
    avt007
    avt007 New Member
    Rob
    Yes, it absolutely should! Why Toyota doesn't say anything about this is beyond me. Here is a great video explaining exactly what a 2nd gen Tundra 4wd system looks like and how it works. It's a training video for mechanics so it's a bit long but it it really worthwhile watching. https://www.youtube.com/watch?v=47m7QAPrpsI
    vhstejskal, MAK and equin like this.
  14. Aug 25, 2019 at 1:49 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    It sort of does. Dry pavement doesn't meet the "permit tires to slide" part.
    Is a few miles on dry surface going to ruin everything? Probably not, but if someone stuck it in 4h and ran from November to February that would likely do it.
    Fotnot likes this.
  15. Aug 26, 2019 at 12:46 PM
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
    If you really want to convince yourself. Head outside, engage 4WD, drive down the road a bit, then try and flip a U-turn. Report back with your findings :thumbsup:
    matttowns509 and Kerch71 like this.
  16. Aug 26, 2019 at 1:07 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I'm not trying to convince myself, I really don't care.
  17. Aug 27, 2019 at 8:15 AM
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    4WD should be on bad roads...and not full lock to lock in turning...take turns a bit wide and pull through the turn. this is normal operation of 4X4
    equin likes this.
  18. Aug 27, 2019 at 9:03 AM
    Rubberdown
    Rubberdown Spilling my guts here.
    Guess you should read the manual to see if it says it in there or not. (It does). There's also a thing on your visor that says it. So much for personal responsibility.
    Black Wolf and landphil like this.
  19. Aug 27, 2019 at 4:24 PM
    avt007
    avt007 New Member
    Rob
    Before you go blaming people for not reading the manual, my 2010 owners manual says absolutely nothing about slippery conditions, or when or where to use 4wd. Nada, zero, zip. And like many others I only found out after trying a tight turn in 4wd. After years of owning AWD, it never occurred to me that it would be an issue. It is a huge oversight by Toyota not to have more information in the book.
  20. Aug 27, 2019 at 4:34 PM
    "Part time" 4WD 101
  21. Aug 27, 2019 at 4:48 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Agree 120%. This needs to be posted someplace permanently. Not sure where, but posted nonetheless. Offroading 101, well stated sir.:thumbsup:
  22. Aug 29, 2019 at 6:58 PM
    FXFormat
    FXFormat New Member
    If you're able to lock you steering wheel on dry pavement and have no binding, you've got some issues with your drivetrain then. Maybe your 4WD is not engaging, any part-time 4WD truck, if you engage it, and try to turn the steering wheel all the way to one side and drive, it'll bind and not be able to move smoothly.
    Black Wolf likes this.
  23. Aug 29, 2019 at 7:16 PM
    NE_WARRIOR
    NE_WARRIOR [HOONIGAN] Wannabe
    Union, ME
    08 DC SR5
    if you can turn on dry pavement in 4WD and not feel your tires chirping or jerking around then either your front diff isn't engaging or you have very bald tires
  24. Aug 29, 2019 at 7:23 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    When you say lock the wheel, do you mean completely crank the steering wheel to either the left or right ?
    The reason I ask is because I don't do that to begin with. But I have engaged 4wd in the snow and on wet roads and driven normally, but no tight turns.
    NE_WARRIOR likes this.
  25. Aug 29, 2019 at 7:31 PM
    NE_WARRIOR
    Union, ME
    08 DC SR5
    wet and snowy/icy conditions are the only time 4WD should be engaged on pavement. (unless you're hooking up to somebody to drag their ass down the street :thumbsup:)
  26. Aug 29, 2019 at 9:47 PM
    MAK
    San Diego
    OK
