  1. Aug 24, 2019 at 9:59 AM
    #9211
    MMathias03
    MMathias03 New Member
    04 DC
  2. Aug 24, 2019 at 11:19 AM
    #9212
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup. Theres a few here and there at this beach but most stay around Zuma, best of the Malibu beaches.
  3. Aug 24, 2019 at 12:48 PM
    #9213
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Success
    got the Tundra back. Other 2 p/s lines replaced, rear axle breather R&R'd.
    Did a test run today little over an hour to & same back. Seem to have worked the air out of the p/s lines.
    NO! leaks from the rear diff! Functioning breather for the win.
    Anyone with new frames or 200+k miles on the clock - I encourage you to verify your breather(s) is(are) functional.
  4. Aug 24, 2019 at 1:22 PM
    #9214
    Professional Hand Model
    Fred
    Hand Protectors
    Good on ya. That breather is so insignificant yet so important. Cost me a few hundred dollars in repairs due to leaky diff fluid onto the rear brake shoes. Wasn’t until coming on this site and learning the importance that prompted installation of a new one.
    For some reason, the steering rack on my truck is no longer leaking at the bellows like yours. I wonder if the multiple suck and fills have helped revitalize the internal seals? Can this really happen?
    Regardless, good info per the additional lines.
  5. Aug 24, 2019 at 1:55 PM
    #9215
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Little parking lot tragedy. I was backing out and a lady started backing out right after. I saw and hit the brake, tried to hit drive but sandals suck. I heard crunch before I could get on the gas.
    Got out and looked, just a busted taillight. Checked the whole corner and not a bit of damage that wasnt there already. Can't say the same for her car, the trunk hit dead center and its pretty collapsed. I feel bad for her. Not gonna bother her for a light, she has enough on her hands.
  6. Aug 24, 2019 at 2:38 PM
    #9216
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Looking at tail lights, I'm gonna just get a pair so they match. I see tons of options under $100 but noticed one odd difference. Some have a harness and some look to just be a shell. Anybody know why?
  7. Aug 24, 2019 at 2:56 PM
    #9217
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    Replaced my leaking and noisy power steering pump with a new Toyota pump. Not too bad of a job. Replaced the OEM looking hydraulic fluid with Valvoline Max Life ATF.
    Side note, you can prime/bleed the pump by attaching the suction line (larger OD) to the pump first, and keep the pressure line disconnected. Fill up the reservoir, and the fluid will go through up and out the pressure line side. Once all bubbles are gone, you can attach pressure line, and essentially don't have any air in the system.
  8. Aug 24, 2019 at 2:58 PM
    #9218
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    At a guess, I'd say the ones with harnesses have LEDs and the shells are for standard lights.
    NUDRAT likes this.
  9. Aug 24, 2019 at 3:18 PM
    #9219
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Is there a DIY for the diff breather mod? Sitting at 201K and wondering if I should check on this. Replaced the fluid last summer and I’m pretty sure the rear isn’t leaking currently
    Whothefat likes this.
  10. Aug 24, 2019 at 5:09 PM
    #9220
    MMathias03
    04 DC
    Just did this mod after I was leaking diff. Fluid and had to replace the seals, bearings, etc.
    https://www.tundras.com/threads/diy-rear-differential-breather-mod.5253/
    SoCalPaul and NUDRAT like this.
  11. Aug 24, 2019 at 6:09 PM
    #9221
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    So many people get so stupid about something like this - good on you for being a gentleman about it.
    Acatlin96 and Darkness[QUOTED] like this.
  12. Aug 24, 2019 at 6:26 PM
    #9222
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Had a fun day. Got a new thing.
    It was a 5 hour drive away from me. Oddly enough, almost exactly 1 tank of fuel each way. Perfect to test out the MPG differences.
    On the way there I got 16.75 mpg corrected for tire size,
    In the way back I got a corrected 19MPG!!! What!?! How is that possible?!?
  13. Aug 24, 2019 at 8:11 PM
    #9223
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    uphill there, down hill back. :rofl:
    speedtre, Darkness and lsaami[QUOTED] like this.
  14. Aug 24, 2019 at 8:20 PM
    #9224
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Yeah I thought of that. Wasn’t much of a difference though. We’re talking MN to Wisconsin and back.
    NUDRAT[QUOTED] likes this.
  15. Aug 24, 2019 at 8:21 PM
    #9225
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Oh yeah. Forgot to mention. The best part is, I got it for a hundred bucks, clamps included.
    NUDRAT and FirstGenVol like this.
  16. Aug 24, 2019 at 11:11 PM
    #9226
    *breathes in heavily*
    WHERE IN THE FUCK HAVE YOU BEEN? DO YOU HAVE ANY IDEA WHAT TIME IT IS? YOU ARE IN A FUCKTON ON TROUBLE MISTER!
  17. Aug 25, 2019 at 2:36 AM
    #9227
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
  18. Aug 25, 2019 at 4:41 AM
    #9228
    We can't let you drink and post anymore. :rofl:
    bmf4069[QUOTED] and lsaami like this.
  19. Aug 25, 2019 at 4:44 AM
    #9229
    I'm not sure. I got 18.6 once and never did it again.
    That's a nice topper. $100 is a steal. Does it have slider windows all around?
    lsaami[QUOTED] likes this.
  20. Aug 25, 2019 at 6:26 AM
    #9230
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    But seriously - you sort of have created a Kammback.
    https://en.wikipedia.org/wiki/Kammback
    A capped truck should be more aerodynamic than an open bed w/ all the turbulence of the open bed.
    But you've added weight & window openings which likely negate any benefit.
    Could be you had a strong tail wind going east & same strong head wind heading west.
    Or - as simple as one fill up was more filled than the other. Different pump, different cutoff speed.
    Even angle of filler in the tank neck may change how soon the pump cuts off.
    Without repetitive results - just a fluke. But it's a goal point for you now.
    I was driving my Tundra like a sport truck yesterday. Forgot I had a section of stone wall in the bed until I heard one rock take a tumble on a turn near the end of my travels. LOL - love these trucks, but I got 11.65 mpg over 122 miles. Previous tank was 14 mpg around town just as a reference & that's running narrow street tires.
    Great find / awesome price!
    If it didn't come with the keys - go here:
    http://www.lostakey.net/
  21. Aug 25, 2019 at 7:12 AM
    #9231
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Yep, sliders. It’s a Leer Model. Windoors or or side doors would’ve been nice since it’s occasionally a work truck and I haul a lot of tools, but if I ever go on an offroading trip where I wouldn’t take the motor home, it would be pretty nice.
    Wind definitely played in a bit. It was barely noticeable. I was really paying attention because I knew this would be the closest test I’ll ever have. I drove the same speed down the same roads. The other thing is, it was all a solid run. No stops, no slowdowns, just straight 60-70mph for 5 hours straight. In that instance the weight would probably make less impact and the aerodynamics would make more right?
    Obviously it can’t account for 2 mpg, but it must’ve played a factor.
    Thanks for the key link. I do not have keys for it.
  22. Aug 25, 2019 at 7:38 AM
    #9232
    I got a new set off Amazon, just the shells. I think they were like $20 or so and work perfect.
    I dont know why it made that a link, it's not. And I can't edit it out. Stupid thing.
    Darkness[QUOTED] likes this.
  23. Aug 25, 2019 at 8:12 AM
    #9233
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Hahaha it does that when you mention certain things. I saw it make a link when I mentioned wally world. It's a little concerning huh?
    I ordered a set off Amazon, mostly because other sources wanted more money than I want to spend right now and can't promise quick shipping. I need my truck this weekend and don't really want to cruise around with the dreaded red tail light tape.
  24. Aug 25, 2019 at 8:15 AM
    #9234
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Coriolis effect!
    Just got one side sitting on its wheels and tore the suspension off the 2nd side. For some reason the drivers side is rusted more. Anyway rust is almost off and I'm going to start welding new stuff on that side. Downhill from here
  25. Aug 25, 2019 at 8:48 AM
    #9235
    Alright, I'll bite. You gonna expand on this? You're going to remove 3.5 qts and add 4.5 or you've found a way to remove an extra quart?
    Any chance you put out the fires while you were there?
    Filthyphil likes this.
  26. Aug 25, 2019 at 9:09 AM
    #9236
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    My reg cab as been averaging 10-12mpg. But I also drive a lot of short trips
  27. Aug 25, 2019 at 9:30 AM
    #9237
    because_wumbo-truck
    Jon
    Houston, Texas
    If I drive the speed limit on my 20 minute work commute (60-65mph) I get about 12 or 13mpg. If I go 50mph I can get 17mpg. That's according to my scangauge without adjusting the numbers to reflect that I have 295s. I got 19mpg with stock tires on a trip going about 60-65 the whole way once.
    But I'm also in coastal Texas where it's flat most of the time.
  28. Aug 25, 2019 at 9:32 AM
    #9238
    I don't put any faith in the computerized estimates. My Torque app says I average 18.5... No idea how these calculate but they are not accurate unfortunately.
    lsaami likes this.
  29. Aug 25, 2019 at 9:48 AM
    #9239
    empty_lord
    05 rollover special
    I’m sure once I start taking it distance the mileage will be better. Headers and injectors may make it even better too. (I will be running a 2018 highlander muffler..... and a electric cutout) so I will be tempted but not that much to mash the gas
  30. Aug 25, 2019 at 10:16 AM
    #9240
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Assuming you have 295/75/16s, and your spedometer is accurate, instead of 13 mpg, you’re getting 14.2 MPG. The 295s are 9.2% larger, so your mpg will read only 91..7% of what it actually is. My speedometer is actually a bit off even with stock sizing, so my correction factor is 1.08. Thus every MPG reading I get I have to multiply by 1.08 to get my true reading.
    I gave up on getting an accurate mpg reading with Torque. The data just comes in too slow. They have a calibration feature which I’ve messed with, but it’s just not able to be accurate.
