12volts Plug & Play remote start groupbuy!
Discussion in 'Audio & Video' started by T-Rex266, Jul 31, 2019.
  1. Aug 23, 2019 at 9:21 AM
    #361
    paradox2311
    paradox2311 New Member
    Got mine!!!
  2. Aug 23, 2019 at 10:09 AM
    #362
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    2018-2019...seems straight forward. TPMS wire cut at 13:10.
    https://youtu.be/0VcbQdS0oX8
    I wouldn't use butt connectors but that's just me. All your doing is cutting the factory TPMS wire in half, soldering the remote start in between the two halves to act as an interrupt. Color code does matter so pay attention.
    TRDFerguson and YsoSeRiouS! like this.
  3. Aug 23, 2019 at 10:30 AM
    #363
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  4. Aug 23, 2019 at 10:32 AM
    #364
    csuviper
    Broomfield, CO
  5. Aug 23, 2019 at 10:34 AM
    #365
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    Has anyone gotten the long range 2 way remote? How do you like it?
  6. Aug 23, 2019 at 10:42 AM
    #366
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    CyberViking likes this.
  7. Aug 23, 2019 at 11:52 AM
    #367
    TheBeast
    TheBeast The Beach
    mine was in a padded USPS envelope...yours look like some food delivery...haha
    jewsNbrews likes this.
  8. Aug 23, 2019 at 12:01 PM
    #368
    csuviper
    Broomfield, CO
    Well it says its delivering today so i was hoping
  9. Aug 23, 2019 at 12:42 PM
    #369
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    Got mine today. No instructions. 2018 model with the splice. Guess I'll follow the video unless someone else wants to post pictures of the instructions.
  10. Aug 23, 2019 at 12:43 PM
    #370
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    Check your spam folder, you should have gotten email
    With instructions with tracking email
  11. Aug 23, 2019 at 1:28 PM
    #371
    chinadog
    chinadog New Member
    Knoxvegas
    No even seeing the shipping info. I purged a bunch of trash and junk over the weekend, probably was in there. I just sent James an email. Thanks guys.
  12. Aug 23, 2019 at 1:35 PM
    #372
    chinadog
    chinadog New Member
    Knoxvegas
    He's already responded!
  13. Aug 23, 2019 at 1:38 PM
    #373
    TheBeast
    TheBeast The Beach
    gotta say though, his video could be better :) at least find a buddy to hold the phone.
    MIM and jewsNbrews like this.
  14. Aug 23, 2019 at 2:07 PM
    #374
    YsoSeRiouS!
    NorCaL
    Yea I could have forward you the instructions if needed
  15. Aug 23, 2019 at 4:29 PM
    #375
    Magnetic15
    Magnetic15 Steel City Member
    Eric
    2015 Platinum Crewmax
    2019 TRD Pro Black LED Headlights, 2019 TRD pro grill. Color matched door handles. Diamondback Tonneau cover.
    Install done.
    Took me 3 Hours, start to finish. Well almost finish, had to find some tools, couldn't remember where my wire sheath and Tesa tape were hiding.
    For now I just shoved the module between the ECU and whatever else is up there. I will either velcro it or mold a piece of pvc sheet to mount it to.
    Install was very straight forward, instructions paired with the video made the install so smooth. Not happy with how I ran the TPMS harness, but it's up behind the air tubes and not touching the transmission tunnel.
    Programming, if you can call pushing a button programming, was silky smooth.
    For today I'm very happy. Definitely going to order the mycar module.
    Thanks @james@tech12volts
  16. Aug 23, 2019 at 4:32 PM
    #376
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Look at post #378
  17. Aug 23, 2019 at 8:04 PM
    #377
    CyberViking
    The Ozarks
    375... I think 378 is for the newer version that 12VoltSolutions sells(not the same as tech12volts) they use a 100% plug and play harness....tech12 does not for 2018/19.
    The video I posted is showing a 12VoltSolutions install on a 2018 BEFORE they moved to a 100% no splice install.
  18. Aug 23, 2019 at 8:55 PM
    AZTundra
    Paul
    Phoenix, AZ
    Did we ever get confirmation if the Key Sense wire needed to be connected for those with the factory alarm? I'm going to tackle my install tomorrow afternoon along with the MyCar unit. My email states "you will see a White with black stripe wire in the diagram also. This is the key sense wire and you do not need it all." I thought I recall some posts a while back that ran into a snag with this wire or am I just losing it?
  19. Aug 23, 2019 at 11:23 PM
    #379
    TheFreshMouse
    TheFreshMouse learning as i go...
    Mouse
    18 CM MGM
    Pinstripes
    received today just before a 3 day weekend! :yes:
    :benchpress:
    Magnetic15 and AZTundra like this.
  20. Aug 24, 2019 at 12:48 PM
    #380
    YsoSeRiouS!
    NorCaL
    Done! Took me forever like 2 hrs... FYI mine doesn’t relock after unlocking when it start. So like a member mention earlier just press lock 4 times and it will lock
    jewsNbrews and TheBeast like this.
  21. Aug 24, 2019 at 1:01 PM
    #381
    teamtlr
    teamtlr New Member
    Denver Colorado
    2020 Sequoia TRD Pro
    Thanks for the video link. I just finished up the install on my sr5 2019 cm. It took me two times to get the button sequence right so I just unplugged the big connector and started over with 10 button pushes and waited for the flash to repeat 9 times. I actually spliced the tpms wire before I started the sequence of buttons on the black box vs in his video where he did it afterwards. Couple odd things, the black box was a little warm so I hope it’s not a battery drain item I need to be concerned with. 2nd. The tpms orange light stays on until you put the truck in drive.3rd I went to lunch and tried the distance test and pushed the key fob button 3 times to get the truck to start and the horn and lights started going off like crazy from about 100ft away. I pushed the unlock button and it stopped but that never occurred before. I waited a longer half second between push button sequence and the truck started. Not really liking the 3 button sequence but it allowed me to keep the stock key so it’s a give and take.
  22. Aug 24, 2019 at 1:10 PM
    #382
    AZTundra
    Paul
    Phoenix, AZ
    Starting my install in about 2.5 hours after I can home from work. Anyone have any ideas for location of the mycar module?
  23. Aug 24, 2019 at 1:15 PM
    #383
    paradox2311
    Starting mine shortly myself. Hope all goes well
    AZTundra[QUOTED] likes this.
  24. Aug 24, 2019 at 1:24 PM
    #384
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I put it between the foam insulation from the vent and the tube. Seems to work well and hasn't moved since install.
  25. Aug 24, 2019 at 1:39 PM
    #385
    AZTundra
    Paul
    Phoenix, AZ
    Thanks! I'll give that location a shot. :cheers:
  26. Aug 24, 2019 at 1:55 PM
    #386
    TheBeast
    TheBeast The Beach
    is this only on 2018+ ?
  27. Aug 24, 2019 at 2:36 PM
    #387
    YsoSeRiouS!
    NorCaL
    Honestly don’t know
  28. Aug 24, 2019 at 2:50 PM
    #388
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Didn't James mention some of the units weren't programming correctly or something? If it's not relocking then there's something wrong. At least you have the workaround to just lock it.
    TheBeast and YsoSeRiouS![QUOTED] like this.
  29. Aug 24, 2019 at 2:53 PM
    #389
    YsoSeRiouS!
    NorCaL
    I just emailed him to ask
  30. Aug 24, 2019 at 3:26 PM
    #390
    Alaska
    Alaska New Member
    2017 Tundra TRD 4x4 ~Quicksand~
    Baja Designs Squadron WC fogs
    Well install was easy and straightforward. I programmed the console as described then hit the lock three times and nothing happened... I'll check connections again...
    Other than that the only thing I can think of is the factory alarm needs to be tapped with the key sense wire. Any thoughts?
