Toytec BOSS coilover set or 6112 Bilstein or Falcon?
Discussion in 'Suspension' started by Rica25, Jul 26, 2019.
  1. Aug 20, 2019 at 8:28 PM
    #91
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    Wheelers offroad has them
  2. Aug 20, 2019 at 8:29 PM
    #92
    Rica25
    Ricardo
    Tulare
    We have ordered two sets in last 3 weeks
  3. Aug 20, 2019 at 8:31 PM
    #93
    Texas Bandit
    Texas Bandit New Member
    Amí
    Edinburg Texas
    2007 White 5.7 Tundra DC Limited 4x4
    295/70R18 Nitto Ridge Grappler Method Race Wheel NV Bronze Rigid Industries Radiance Pods Morimoto Xtorch 36” Light Bar SDHQ Pillar Light Mounts
    What other setups have you had?
  4. Aug 20, 2019 at 8:43 PM
    #94
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    Did you do the diff drop as well. 4 wheel parts was also doing a skid plate adapter kit. Anyone know what that is?
    Rica25[QUOTED][OP] likes this.
  5. Aug 20, 2019 at 8:56 PM
    #95
    Rica25
    Ricardo
    Tulare
    Every truck is different I was recommended not to do it unless there was vibration
  6. Aug 21, 2019 at 8:17 PM
    #96
    Rica25
    Ricardo
    Tulare
    Got here today
  7. Aug 22, 2019 at 6:35 PM
    #97
    Midmo_tundra
    Midmo_tundra New Member
    Missouri
    I’ve had 3” spacer Kit, OME Kit, 7” BDS, and my 6112s and it’s the best I’ve owned. I’ve rode in a toytec ultimate Kit, and a 6” Pro comp with coilovers and the 6112s still rode better IMO. I haven’t rode in one with the new Toytec stuff, so I can’t comment. But I spent less than $1,000 on my 6112/5160 setup and I’d say for the price it’s hard to beat
  8. Aug 22, 2019 at 7:10 PM
    #98
    Rica25
    Ricardo
    Tulare
    Received the black Bilstein brackets for the piggy back 5160s they are nice little holders not bad in price
  9. Aug 25, 2019 at 10:38 PM
    #99
    Rica25
    Ricardo
    Tulare
    So now that I wanna set this up what height should I set it on.......i have right now the 5100s all around and one shim 1/2 inch on each side with +2 shackles from Coachbuilder......I want smooth ride so undecided what to do and alone ho many shims can I add before it will damage?
  10. Aug 25, 2019 at 11:12 PM
    #100
    AZBoatHauler
    So.Arizona
  11. Aug 26, 2019 at 3:51 AM
    #101
    Midmo_tundra
    Missouri
    I set mine on the top setting with shims for ~3” lift and I think they ride great. Typically the lower settings ride better. So it depends on how much height you need. I’d either do the top setting (2.5”) or the 2nd from the top setting (~1.8” I think?). I think you’ll be happy either way coming from the 5100s with stock coil springs
    That’s what I have, been great and no issues in 3+ years now
  12. Aug 26, 2019 at 5:52 AM
    #102
    Rica25
    Ricardo
    Tulare
  13. Jul 19, 2020 at 2:27 PM
    #103
    18" TRD Off Road Wheels
    The quality control is confidence inspiring. This gosh darn forum!!! :spending: Not yet, but when I do I think these will be my choice.
    I am curious why they opted to go with a 2.25" rather than a 2.5" shock. I can honestly say I've not seen another. Plenty of 2.0" and 2.5" but I can't readily think of another 2.25" to compare. I could be wrong, cuz I'm a noob on shocks and such.
  14. Jul 19, 2020 at 3:07 PM
    #104
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    6112 / 5160 here and love it with 34” tires on 17” rims and no sway bars. Ride is great. Off-road is smooth and comfy with 20-22 psi.
    Allegedly 6112 uses 650 lb springs, toytec alluma’s are 700lb. (This is all hearsay as I have no shock dyno in my garage)
    Darren at boss off-road was great to work with and can get what you want so won’t steer you wrong.
    https://boss-offroad.com/i-30498926...tundra-new-orders-ship-week-of-july-27th.html
    Use code: Tundras
    fyi I am at 1.9 + 1 shim on each side and have no diff drop installed.
