Empty brake system
Discussion in '1st Gen Tundras (2000-2006)' started by marovn, Aug 21, 2019.
  1. Aug 21, 2019 at 9:21 PM
    marovn
    marovn [OP] New Member
    nick
    I screwed up and emptied my brake fluid from the master cyl through the front caliper fitting (both sides). Any advice on the best approach would be greatly appreciated. Also, is a reverse bleeder an option?
  2. Aug 21, 2019 at 9:33 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    you need to bleed your whole brake system
    Black Wolf and 15whtrd like this.
  3. Aug 22, 2019 at 12:57 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Yup. This.
    First you'll need to bleed the master cylinder. The each caliper starting with the passenger side as it's furthest away. I use the Motive bleeder pump which is well worth the $50 in my opinion. If you're saying u never bled a master cylinder before, watch a couple youtubes and report back with any final questions.
  4. Aug 22, 2019 at 1:18 AM
    Aerindel
    Aerindel New Member
    Montana
    Simply bleed your brake system. Its kind of annoying but it's not hard.
    hammeron likes this.
  5. Aug 22, 2019 at 7:07 AM
    marovn
    nick
    So if I do a good job of bleeding the whole system the ABS part of the system will be ok without any special tools?
  6. Aug 22, 2019 at 2:34 PM
    Aerindel
    Aerindel New Member
    Montana
    Yes.
    Although it may take more than one round of bleeding as air can get hung up in places. I usually bleed, drive for a few days, bleed again.
    Don't forget there is also a bleed valve on the load proportioning valve in the rear.
