Tundra is bad on the highway
Discussion in '2.5 Gen Tundras (2014-2021)' started by jsurf58, Aug 20, 2019.
  1. Aug 21, 2019 at 2:26 PM
    #61
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    There is a newish MPG thread, I'm sure it was meant for that.
  2. Aug 21, 2019 at 3:45 PM
    #62
    AZBoatHauler
    So.Arizona
    What year Denali? My wife drives a 2015 and my Tundra is a smoother ride but can't keep up with the 6.2.
  3. Aug 21, 2019 at 4:05 PM
    #63
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Did you come from a car?
    Jerry311SD and Rex Kramer like this.
  4. Aug 21, 2019 at 4:44 PM
    #64
    Jas4tundra
    Jas4tundra New Member
    Jasmeet
    2019 Tundra limited white
    Stock
    Not sure , mine rides like a truck should. Put some weight in the bed will feel planted on the road.
  5. Aug 21, 2019 at 4:45 PM
    #65
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Sand bags
  6. Aug 21, 2019 at 4:47 PM
    #66
    Jas4tundra
    Jasmeet
    Stock
    May be 4 cases of water should do it too. Anyways it’s freaking hot water comes in handy.
  7. Aug 21, 2019 at 11:29 PM
    #67
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    Do you know which ones work for our leafs? Do they make bushings for other parts of the suspension?
  8. Aug 22, 2019 at 7:59 AM
    #68
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    I ride empty and only get very small bed bounce on cement interstate sections. Truck is planted through Colorado canyons with an empty bed. That’s with stock tss non trd suspension. Now that I put toytec on its even more planted. Took a hard twisty at 70-75 just because I couldn’t let a bow tie and a ram beat me down the canyon. Keep in mind my alignment is set to my own specs as I do the alignment myself. I in no way condone this type of driving at stated speeds through twisty canyon roads. As far as concrete interstate sections with toytec on. Much smoother. And that’s with tundra standard sway bar and shackles as well.
    Rex Kramer likes this.
  9. Aug 22, 2019 at 12:15 PM
    #69
    Rex Kramer
    Georgia
    I in no way condone allowing a bow tie and a ram beat you down the canyon either.
    fundratss and Rica25 like this.
