Check your shocks after install...
Discussion in 'Suspension' started by lamikela1, Aug 21, 2019.
  1. Aug 21, 2019 at 12:49 PM
    lamikela1
    lamikela1 [OP] New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    I had some issues with leaks on my Fox 2.5's recently and would like to bring this up so that none of you run into the same issues.
    I was doing my 10K mile checkup weekend before last and saw this...
    cb-BI7cztqbyANjzjMwnA4KOvu8sdJbps_yTYvlR_e46f7af36391d8799e5c7cc2b78cc473ccbc0639.jpg
    I brought it down to the local 4 wheel parts and they stated that they have never seen this color shock oil before so I was not sure if this was coming from the shock. When I checked the top of the sock I didn't see anything that could have leaked from the engine compartment. Also, it was not not oily or liquid. Rather it was gummy and sticky.
    Afterwards I sent an email to Fox support and they stated that it was a leak and that they have been using red oil for 6+ years. They also stated that they could have it checked under warranty. All I needed to do was to send it to them. This is my DD so that was a problem for me.
    I then took matters into my own hands. I cleaned the shock up so that I could isolate the leak and after about a week I found that the hose fitting was where the leak was.
    IFeb9Cxkcolv8WfDSwd66ihZnIlTiVgFAwzVP9HB_845f7ffa7d3e57a8767712dd57ae38c0701b0778.jpg
    Once I tightened it the leak was fixed.:thumbsup: I checked all the other hose and fittings to confirm they were tight. I then checked back with Fox on the torque specs but they have none. I estimate that I lost about an once of oil and Fox said that should not be an issue. Also since the nitrogen charge is isolated from the oil with a piston in the res I did not lose any of it.
    So, just a heads up that if you are installing any brand of aftermarket shocks that have remote reservoirs you should take the time to check all fittings to avoid this from occurring. I hope this helps someone from having the same issues.
    Time for a beer!!!:cheers:
  2. Aug 21, 2019 at 2:36 PM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Everyone bashes fox but they have always helped me out with all my stuff glad it all worked out for you tho. Killer set up I love mine
  3. Aug 21, 2019 at 3:31 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Thanks for the PSA :thumbsup:
  4. Aug 21, 2019 at 3:45 PM
    Vizsla
    Vizsla pretend2send
    That’s enough oil loss to replace imo.. Would definitely check nitrogen, the pressure goes down with oil loss.
    joonbug likes this.
  5. Aug 22, 2019 at 6:42 AM
    lamikela1
    Michael
    I do have a nitrogen tank in my garage so I was thinking about checking it. That could also help me determine how much oil was actually lost. There was never any loss of ride quality so it may be fine.
