Does this look right??
Discussion in '1st Gen Tundras (2000-2006)' started by JustKarma, Aug 21, 2019.
  1. Aug 21, 2019 at 11:47 AM
    JustKarma
    JustKarma [OP] New Member
    2003 silver stone grey
    Stock
    Newbie from MD asking for your opinion.
    2003 Tundra 2WD Automatic 3.4L
    Transmission input shaft seal leaking like crazy. After taking down the transmission and pulling out the torque converter and stubbled upon this.
    The ring around the torque converter shaft. Is this normal? Feels like it’s been rubbing.
    Went to the local Toyota dealership - and couldn’t get answer. Kept hearing “we don’t work on these that much....”
    Smh... anyways - anything would help.
  2. Aug 21, 2019 at 2:49 PM
    JustKarma
    Stock
    Update : turns out the answer is no.
    Bad torque converter and also bad trans pump. The ring around the converter - belongs to the pump. Problem solved. Smh
  3. Aug 21, 2019 at 3:21 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Good that you were able to figure it out. Sorry about the bad news though.
  4. Aug 21, 2019 at 4:35 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Glad you figured out that it is not normal.
    It is the input bushing.
  5. Aug 21, 2019 at 4:50 PM
    JustKarma
    Stock
    Yeah - looks like I’m getting a used transmission. But I do have a little question. While shopping for the torque converter and trans pump, seems like the parts are interchangeable with the V8 trans as well. If I purchased a a3040e trans from a v8 - after changing the bell housing, will it work on the v6? Some people say yes and some say no. And I’m talking about counter parts people.
  6. Aug 21, 2019 at 5:15 PM
    I feel like @Darkness may know the answer to this.
    Darkness likes this.
  7. Aug 21, 2019 at 5:32 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  8. Aug 21, 2019 at 5:37 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Hmm. Usually we try to keep the v8 transmissions on v8s and v6s on the 6s. But technically it should be interchangeable. I think the bellhousings might be the same too.
    Biggest difference is the torque converter stall that I can think of. Maybe gearing
  9. Aug 21, 2019 at 6:00 PM
    JustKarma
    Stock
    Thanks for all the info. The torque converter is the same part number for v6 and v8. But the gearing does worry me. Thanks again for the help. @empty_lord @Darkness @FirstGenVol
  10. Aug 22, 2019 at 8:08 AM
    speedtre
    speedtre New Member
    Inland Northwest
    If you believe Wikipedia, the gearing for all A340E / 30-40LE (2wd applications) is the same, regardless of engine or even vehicle it's used in....
    https://en.wikipedia.org/wiki/Toyota_A_transmission#A340E_(30-40LE)
    Same goes for the A340F (4wd applications)....
    https://en.wikipedia.org/wiki/Toyota_A_transmission#A340F
  11. Aug 22, 2019 at 1:38 PM
    JustKarma
    Stock
    Yeah I saw that. Just to make it easier , I went this morning and pulled a trans from 03 tundra v6 RWD. I’ll deal with all that gearing research when I covert her to a v8 4wd. Just need to get it back on the road and thru inspection.
    Thanks for looking that up @speedtre
    speedtre likes this.
  12. Aug 22, 2019 at 1:59 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Yea that ring is the Pump Bushing so your pump seal and maybe even the pump body could be bad that happens cause it over heated definitely inspect transmission internals before putting a pump and torque converter in it sucks to do the job twice
