Coach builder tire rods ? Or other
Discussion in 'Suspension' started by DM 2018 Tundra, Aug 19, 2019.
  1. Aug 19, 2019 at 2:48 PM
    DM 2018 Tundra
    DM 2018 Tundra [OP] New Member
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    drop truck off at tire shop cause of bad bump steer now. They called and said might need upgrade bump stops on front of the truck or tie rods ends. Truck has 8300 miles. So the shop said they can get MOOG tire rod ends or I can get Coach builder. It will take me some days to CB or they can have the MOOG. Has anybody used MOOG? Or are either one will fix it. Thanks for any feed back. Oh they will be closed this Friday and I am headed out of town also. Thanks again
  2. Aug 19, 2019 at 2:52 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Idk your usage but CB are hiem joints, think they have a nice boot now but sealed or needing ser
  3. Aug 19, 2019 at 2:53 PM
    Nm6300'asl
    2022 DC SR5 4x4
    Do you wanna do the maintence on a hiem joint, or prefer no fuss sealed unit?
  4. Aug 19, 2019 at 2:59 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Thank you for ur fast reply. Whatever is better very new to the Tundras and how they work vs the front ends Iam used to. I do know CB will fix the bump steer and they are longer. The MOOG I have never heard anyone talk about them. MOOG has a lifetime warranty with them.
  5. Aug 19, 2019 at 4:04 PM
    Blueknights75
    Ron
    Clayton, NC
    I have used MOOG tie rod ends on my previous truck and they worked fine and a little beefier than the stock OEM GM tie rods. Can’t speak for the CB parts but everything I see being produced and manufactured by them seems to be MUCH beefier and well made.
    DM 2018 Tundra[OP] likes this.
  6. Aug 19, 2019 at 4:31 PM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    I have CB tie rod ends, they are well made and very beefy.
  7. Aug 19, 2019 at 4:33 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Thank you. I like to use CB but will not have them in time and the shop said they use MOOG a good bit. So CB is a better product than MOOG? Will MOOG fix my bump steer. I also have a 6 inch lift. Thanks again
  8. Aug 19, 2019 at 4:34 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Thanks.
  9. Aug 19, 2019 at 4:35 PM
    DM 2018 Tundra
    2018 Limted Tundra
    The shop said to get better tie rod end and that will fix my bump steering. You guys think that’s correct?
  10. Aug 19, 2019 at 4:36 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Shop was saying need more travel?? Not sure what he was talking about
  11. Aug 19, 2019 at 5:19 PM
    Blueknights75
    Ron
    Clayton, NC
    I wish I could answer that question but I have not used a CB product. I can say that MOOG is an upgrade from factory OEM typically. After seeing what CB shackles look like and all of the positive customer experiences plus the fact that you have a lift I would go with the CB tie rods.
  12. Aug 19, 2019 at 5:24 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Thanks Blueknights. David said it would fix my bump steer issues at coach builder. Just don’t have time to wait on them. Lol. Thanks again
