VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Aug 18, 2019 at 2:52 PM
    #541
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Cant wait to see how it stacks up on the dyno against the dap.
    TruckyTruck[QUOTED] likes this.
  2. Aug 18, 2019 at 6:21 PM
    #542
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Does the tune improve how quickly the transmission manually shifts in Sequential mode? Stock the shifts are super slow to respond.
    shellshock and TruckyTruck like this.
  3. Aug 18, 2019 at 6:37 PM
    #543
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    That's a good question!
  4. Aug 18, 2019 at 8:53 PM
    #544
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    He can mod your tune for the shift points your desire. He has done it for me.
    Vr0ck likes this.
  5. Aug 18, 2019 at 9:03 PM
    #545
    mountainpete
    Shift points or manual shift change speed? I understand them as two different things.
  6. Aug 19, 2019 at 3:28 AM
    #546
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Yes that is correct ideally you want to lock it in 4th and maintain a target rpm for a specific amount of time. That’s challenge with our trucks. When I had my SC Sequoia dyno’d with the HP tune that was the problem that they were running into same as Matt. They couldn’t keep it in fourth gear to do the tune because it would downshift about 3500 rpm’s. Keith says that there’s a trick to it that he was able to do to keep it in fourth gear running the RPMs necessary to get a good tune. Most tuners are familiar with LS engines they actually have a gear select and can lock the preferred gear in, not available on the Toyota’s unfortunately
  7. Aug 19, 2019 at 4:07 AM
    #547
    coTony
    Tony
    Montrose, CO
    That annoys the crap out of me in the S mode of shifting, why give you the option of shifting if it does not shift when you make the shift.
    Vr0ck likes this.
  8. Aug 19, 2019 at 4:58 AM
    #548
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I can go into better detail on how the transmission and shifting works if you guys really want to know.
    As far as changing shift speed (how fast it shifts?) definitely tune-able.
  9. Aug 19, 2019 at 8:01 AM
    #549
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    2018+ Only Tundra ECU patch notes:
    Phase 2.
    Through more testing and code work we have enhanced our 2018 + ECU tables. Exclusive to OVTune, if you have a 2018 Tundra (and upcoming for 2019!!) we have made big changes to the ECU.
    (due to size limits on older ECUs, some of these features are only available to 2018s) With the 2018+ ECU having more than 4x as much free space available, it will get even more features in the future.
    This will all be available soon via our blog post on it too.
    These features are finished, coded, and now ready to send out.
    Map size increase is 150% more resolution than stock!
    - Ignition BIG MAP - updated versions of our original patch
    - valve timing BIG MAP - updated versions of our original patch
    Supercharged
    - Supercharged Fueling Mod - Fuel Map - similar to older ECU patch
    MSU Tundra, Stroke250, Midway and 5 others like this.
  10. Aug 19, 2019 at 8:15 AM
    #550
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Cool!
    Guess time to upgrade to a newer model.:p
  11. Aug 19, 2019 at 8:23 AM
    #551
    TruckyTruck
    Gary
    I probably don't realize what I'm asking or any implications of it, but I'll ask anyway.
    Is it possible to purchase one of these newer ecu's for an older model? And if so, would there be any benefit of doing that to a truck like mine?
    Again, im not sure it would even work or be worth it. I just plan on keeping my truck, even if I buy a newer one some day.
    Vr0ck likes this.
  12. Aug 19, 2019 at 8:24 AM
    #552
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Won't work :(
    Also, if there is anyone with a 2018 and our flash kit interested in testing a patch for us, please let me know!
    MAF - Delete - with our Airflow compensated Alpha - N fuel model (which will soon be converted to speed density, pressure based, on Supercharged trucks)
  13. Aug 19, 2019 at 8:25 AM
    #553
    TruckyTruck
    Gary
    Thank goodness... I just knew my wallet was about to get lighter. :laugh:
    Vr0ck likes this.
  14. Aug 19, 2019 at 8:26 AM
    #554
    TruckyTruck
    Gary
    If you had to guess, how much better will the newer trucks perform with that much extra space?
  15. Aug 19, 2019 at 8:26 AM
    #555
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    in for 2019 when available :thumbsup:
    Rockgate and TruckyTruck like this.
  16. Aug 19, 2019 at 8:27 AM
    #556
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Depends on how many features we develop. Plenty of room in the ECU to develop a LOT, just depends on what features we want to make, and what features the community is looking for.
  17. Aug 19, 2019 at 8:37 AM
    #557
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think this would be a good read, but only after we have the opportunity to experience what you've accomplished to date (for comparison). ;)
    TruckyTruck likes this.
  18. Aug 19, 2019 at 8:42 AM
    #558
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Pretty AMP'd on all these updates.
    Do you have a run down on order#'s that will be fulfilled soon?
    Order#4815 here.
  19. Aug 19, 2019 at 8:45 AM
    #559
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    At the moment unfortunately it is not going by order number it is going by ECU version
  20. Aug 19, 2019 at 8:46 AM
    #560
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Logical....
  21. Aug 19, 2019 at 9:10 AM
    #561
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    2018 Supercharged cal finished and sent out.
    edit **
    forgot to add for 2018 CALs,
    Worlds first true 3D Fuel table for the Tundra.
    (load based, for Superchargers)
    Based on Engine speed and engine load -
    code snip w/ 3D code pull and actual table :
    VS STOCK TABLE:
    Stroke250, Midway, Watt maker and 2 others like this.
  22. Aug 19, 2019 at 12:15 PM
    #562
    Duneflyer
    Darren
    Yuma AZ
    As he just replied..both
  23. Aug 19, 2019 at 7:26 PM
    #563
    tundrabum
    tundrabum New Member
    I bet this was my tune :) Ran great!
  24. Aug 20, 2019 at 8:23 AM
    #564
    TruckyTruck
    Gary
    Good gravy... Edited for the worst memory in history.
  25. Aug 20, 2019 at 8:24 AM
    #565
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    lol what.
  26. Aug 20, 2019 at 8:34 AM
    #566
    TruckyTruck
    Gary
  27. Aug 20, 2019 at 8:36 AM
    #567
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    stock shift points? or literally "stock tune" in S mode.. as in stock VVT.. stock fuel.. stock ignition.. etc (*extremely* unlikely)
    MrMax likes this.
  28. Aug 20, 2019 at 9:39 AM
    #568
    TruckyTruck
    Gary
    Oops... Talking out of my ass. You are right, it was only the transmission that was stock in S mode...
    Carry on folks, nothing to see here. :oops:
    Totally embarrassed.
    MrMax, Wynnded and shellshock like this.
  29. Aug 20, 2019 at 11:10 AM
    #569
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Hahaha! *pointing finger*
    Just kidding! I appreciate that you had the mindfulness to think and ask about this to give those of us that also have a DAP tune flashed a reminder and refresher as to the what we're comparing our trucks performance and behavior to once the OV tunes are available to more owners. :thumbsup:
    MrMax and TruckyTruck[QUOTED] like this.
  30. Aug 22, 2019 at 9:50 AM
    #570
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Everyone good here?
Thread Status:
