scavenging some power off the alternator of my PRO
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Rattlesnake, Aug 17, 2019.
  1. Aug 17, 2019 at 10:10 AM
    Rattlesnake
    Rattlesnake [OP] New Member
    thinking with the high amp. alt. there would be some opportunity to scavenge some of this output, anyone done that?
  2. Aug 17, 2019 at 10:17 AM
    Rubberdown
    Rubberdown Spilling my guts here.
    I don’t know what you are trying to say. Are you trying to steal electricity or the power it takes to turn the alternator or what are you talking about?
  3. Aug 17, 2019 at 10:30 AM
    Rattlesnake
    electrical power
  4. Aug 17, 2019 at 11:07 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    And use it for what? Electronics like lights and whatnot? Or engine power like a hybrid?
  5. Aug 17, 2019 at 11:23 AM
    Rattlesnake
    I have an electric Porter Cable impact wrench I definitely would like to power when I have need, looking to eliminate a portable generator as part of the gear on the road.
  6. Aug 17, 2019 at 11:25 AM
    Pudge
    CT
    You could probably hard wire in a good high output inverter. Use heavy gauge wire, fuse, and a relay and you should be good to go.
  7. Aug 17, 2019 at 11:36 AM
    Rattlesnake
    I am thinking I can set up an inverter with cables that connect like jumper cables to the battery, with 10A fuse, 1000 watts would do the jobs I am looking at...just pondering this right now.....
  8. Aug 17, 2019 at 1:57 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Just put an aux battery with a isolator in the back. Hook up a high output inverter to the aux battery.
  9. Aug 17, 2019 at 1:59 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Get a power invertor wired straight to the battery.
  10. Aug 17, 2019 at 6:43 PM
    Gungho
    Gungho New Member
    Michael
    2019 Tundra TRD Pro
    3-5x 100 watt solar panel connected to 2x 130 AH lithium Iron phosphate battery and a 1500 watt inverter should give you 2 hours of use per day.
  11. Aug 17, 2019 at 7:52 PM
    Shark Bait
    Shark Bait Not new anymore
    2019 Platinum
    10 amps at 12-14 volts will only give you 120-140 watts.
