  1. Aug 16, 2019 at 7:28 PM
    #9091
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    a spill im guessing. the plastic on the bezel is all stained from it too. but lord knows what really happened.
    it ate the paint off the dash right below the clock too
  2. Aug 16, 2019 at 9:09 PM
    #9092
    I also have 3 ford taurus SHO's. Almost 100% yamaha designed engine. I love em.
    because_wumbo-truck likes this.
  3. Aug 16, 2019 at 9:30 PM
    #9093
    empty_lord
    05 rollover special
    The first manual I ever drove alone was a 1st gen sho tarus. It was fun
  4. Aug 16, 2019 at 9:35 PM
    #9094
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Where do you live? I have a spare 2wd bezel in good condition I'd mke a deal on if you have interest. You'd have to change out the switch panel.
    W
  5. Aug 16, 2019 at 10:09 PM
    #9095
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    and the tundra blew another p/s line last night. On a friends freshly resealed driveway. :facepalm:
    had the kit put in that replaces all the hard lines. But seems there's another hard line across the topside of the rack. Guess I know what i'm focusing on this weekend.
    and... anyone know how to clean truck blood off a just resealed driveway w/o making it worse?
  6. Aug 16, 2019 at 10:13 PM
    #9096
    empty_lord
    05 rollover special
    I’d love to take you up on that deal. But the airbag switch is in a different spot so nothing would bolt on.
    SoCalPaul[QUOTED] likes this.
  7. Aug 16, 2019 at 11:23 PM
    #9097
    Heres my 2 1st gens.
    It may or may not make much sense on this forum, but I love these cars!
  8. Aug 17, 2019 at 4:41 AM
    #9098
    There is a famous police chase from 03 involving an SHO. That's how I first became aware of them. Badass cars.
    bmf4069[QUOTED] likes this.
  9. Aug 17, 2019 at 5:09 AM
    #9099
    Did you get these sliders installed? I'd love to see some pics.
  10. Aug 17, 2019 at 6:04 AM
    #9100
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Dump some cheap clay cat litter on it and leave it overnight. Should get most of it, purple power, a stiff scrub brush, and a pressure washer for what's left.
    NUDRAT[QUOTED] likes this.
  11. Aug 17, 2019 at 6:48 AM
    #9101
    Yup, that video made it around SHOforum after it happened. We were saddened by the loss of a 91 mocha. Kinda like losing an 06 blue tundra, rare color.
    Man, purple power is awesome. I tried it once on some valve covers and I won't use anything else now. Good stuff.
  12. Aug 17, 2019 at 7:59 AM
    #9102
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    05
    How does the ATF get back in the trans? The plug on the tail shaft? I don't see a plug on the side of the transmission
  13. Aug 17, 2019 at 8:11 AM
    #9103
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    Hey @SoCalPaul, I'd ensure you keep that receipt just in case. The only battery I've ever had that failed within a year was one of those DieHard AGM's. I did some research and found it was pretty common. Just FYI. Hope you don't have the same issue.
  14. Aug 17, 2019 at 11:05 AM
    #9104
    empty_lord
    05 rollover special
    Hmm, don’t remember on the 2wds. The 4wds are right before the tail section
    How soon do you need to know, I’ll grab a pic of my truck when I have it on the rack in a few hours
  15. Aug 17, 2019 at 11:20 AM
    #9105
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    FWIW - went to the shop today, they looked it up & found I would need a whole new rack. Told them it SURE looked like it was just threaded on.…. He looked some more & found the lines separate. He called Toyota parts, they said yep - two lines, but only come with the whole steering rack. :annoyed: They hang up, told him I'd think on it, was leaving & his phone rings. He looks at the phone & gives me the hold-on a sec. finger. Toyota called back, oops - yes you can get the two lines alone & the seal rings. :yay:
    So I dropped off the truck. Just threaded on, I could do it myself - but I know I'd cross thread them or round off. Cheaper to pay for it done by someone with skills & proper tools. Told him to look into the 'clunk' while he's got it.
    So - today I dropped off the Tundra at the Dr. :evil:
    bmf4069 likes this.
  16. Aug 17, 2019 at 11:47 AM
    #9106
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    That's the fill plug on my truck. I drained 3.5 qts out and put just a hair over 3.5 back in using a funnel and clear hose.
    Greased my driveline ujoints also.
    I'm waiting for my K&N to dry then I'll test drive it. It will be good to go.
    I'm going to empty out the power steering bottle next weekend and refill it
    I'm at 117k all fluids are almost changed
  17. Aug 17, 2019 at 1:59 PM
    #9107
    I'm not sure this is gonna work. @Darkness may be right. You think it's safe to remove 1 camper clamp? I have 3 on each side. This would leave one in the middle and one up front.
    Edit, I'm gonna try it but I'm not sure it's gonna work. I may end up with 6 new holes and no box.
    Filthyphil and Jerry311SD like this.
  18. Aug 17, 2019 at 2:41 PM
    #9108
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I would remove the clamp, you still will have 5 holding that bad boy down.
  19. Aug 17, 2019 at 2:41 PM
    #9109
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Small cosmetic upgrade.
    Everything fit fine just had to cut the rubber boots around the bulbs because I have LED lights.
    Just have to adjust head light beam angle tonight.
    abcinv, Pinay, TX-TRD1stGEN and 3 others like this.
  20. Aug 17, 2019 at 2:43 PM
    #9110
    SoCalPaul
    Paul
    I guess I'll find out. Most of the bad reviews I saw on Amazon were fitment issues. One of the reasons I had Sears install it. The only battery I've had issues with were Optimas.
    You could possibly relocate that clamp. There are also other styles of clamp, you might find one that clears.
  21. Aug 17, 2019 at 3:44 PM
    #9111
    TX-TRD1stGEN and NUDRAT like this.
  22. Aug 17, 2019 at 3:50 PM
    #9112
    Well it fit but barely. Super thankful it worked. The top of the lid actually hits the plastic bed rail and the striker plate isn't flush because the bed isn't flat there. I think it will be fine though.
  23. Aug 17, 2019 at 5:01 PM
    #9113
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Looks good.
  24. Aug 17, 2019 at 8:06 PM
    #9114
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Thank you I love it.
  25. Aug 17, 2019 at 10:52 PM
    #9115
    because_wumbo-truck
    Jon
    Houston, Texas
    Did you wire your led fogs to the stock switch?
  26. Aug 18, 2019 at 3:39 AM
    #9116
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Looks great! Your results are pushing me closer to pulling the trigger. As good as yours looks I'm assuming the Phantom Grey could easily pull it off as well...
    Thanks for the pic
  27. Aug 18, 2019 at 5:22 AM
    #9117
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Question: looking at new suspension front and rear. I’ve decided on
    Bilstein 5100 front/rear $700ish
    Bilstein 6112/Icon rear: $1000ish
    Which one will ride better on road? Which one is a better bang for buck?
  28. Aug 18, 2019 at 5:25 AM
    #9118
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Ooh...
    What do you need for the pro-truck kit?
  29. Aug 18, 2019 at 5:58 AM
    #9119
    because_wumbo-truck
    Jon
    Houston, Texas
    If you do get the 6112s I'd be interested to hear about how you like em and which setting you use. I'd save your money on the rear icons and go 5160
  30. Aug 18, 2019 at 6:07 AM
    #9120
    lsaami
    lsaami Let ‘er buck
    Minnesota
    5160s are $70 more expensive, hence why I want to go icon.
