Squirrels - 1 / Tundra - 0
Discussion in 'General Tundra Discussion' started by Chucho, Jul 24, 2018.
  1. Jul 25, 2018 at 7:52 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
  2. Jul 25, 2018 at 8:27 AM
    .manny.
    .manny. New Member
    Manny
    2018 Cement Tundra SR5 Crewmax
    WOW! That sucks OP. :(
  3. Jul 25, 2018 at 9:24 AM
    Chucho
    Chucho [OP] New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    Mine started but no throttle response.
    Went in to gear and moved under its own power but that's it.
    When I first started the truck I noticed that the traction control was off.
    tried to proceed to drive and no bueno....
  4. Jul 25, 2018 at 10:34 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Sucks dude! Ins should cover it.
  5. Jul 25, 2018 at 1:50 PM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    man that stinks.
    we keep a ATV up at the farm. some years back we had some mice get inside of it and it was a freaking mess. they chewed up so many different wires, it was such a pain, expensive fix.
  6. Jul 25, 2018 at 10:07 PM
    geno0506
    geno0506 New Member
    Michael
  7. Jul 25, 2018 at 10:18 PM
    PapaGrizz
    PapaGrizz MGM CRÜE
    Derek
    Spokane Valley, WA
    2016 MGM Tundra TRD Off Road Crewmax
    Bummer man! This is covered under your comprehensive coverage; claim it!
  8. Jul 27, 2018 at 12:02 PM
    Chucho
    Rob
    Salem, OR
    Well, Insurance is covering the repair, sounds like it's going to take about 15 hrs of labor once the parts are available.
    They got me a Ram 1500 Hemi as rental also covering the cost until my truck is done.
    JC303, TheBeast, PapaGrizz and 2 others like this.
  9. Jul 27, 2018 at 12:05 PM
    How much is that going to run for the repairs?
    TheBeast likes this.
  10. Jul 27, 2018 at 2:12 PM
    TheBeast
    TheBeast The Beach
    make sure you take preventive measures when you get your truck back. I bet it will happen again if you don't do anything.
    joonbug likes this.
  11. Jul 27, 2018 at 2:12 PM
    Chucho
    Rob
    Salem, OR
    Sounds like $5300.00
  12. Jul 27, 2018 at 2:24 PM
    TheBeast
    TheBeast The Beach
  13. Aug 13, 2019 at 9:56 AM
    Dan2014
    Dan2014 New Member
    2014 Tundra
    $ 6,547.00 is the repair bill. We met yesterday in the same parking lot. My truck got chewed in the exact same place as your.
  14. Aug 13, 2019 at 10:06 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Looks like mice, or rats - not squirrels.
  15. Aug 13, 2019 at 11:33 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
  16. Aug 14, 2019 at 12:45 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Apparently you don’t just have the fastest color, you also have the tastiest! :cookiemonster:
  17. Aug 14, 2019 at 6:17 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Use Peanut butter and put these type of traps close to your tires..
  18. Aug 14, 2019 at 6:38 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
