1997 T100 Map light replacement
Discussion in 'Other Toyota Vehicles' started by se3388, Nov 23, 2016.
  1. Nov 23, 2016 at 8:42 AM
    se3388
    se3388 [OP] New Member
    2025 Tundra I Force Max Platinum Crew Cab, 1997 Toyota T100 SR5 Ext. Cab 4x4, 2014 Tacoma Dbl Cab Short Bed 4x4 TRD Sport
    I have a 1997 T100 4x4 SR5 extended cab and am replacing some of the lights with LED's and am wondering how do you get access to the map light bulbs. I don't see any obvious areas to pry tabs off so some advice would be appreciated, I don't want to go prying around and mar the plastic as replacement parts aren't getting cheaper or more common. I believe it is the same as on the 1997 Tacoma's with the map lights.
    Steve..........
  2. Nov 24, 2016 at 4:00 PM
    se3388
    Got it off, it took some prying but it finally came off without tearing much up.
    Steve........
